Luminus SST-10R Red - anyone?
11 posts / 0 new
blitzwing
Anyone tried one?
I just ordered a few for experimentation.
http://kaidomain.com/Luminus-SST-10-R-620nm-Red-LED-Emitter?search=Luminus%20SST-10-R
The 90 degree viewing angle doesn’t inspire really, but we’ll see.
I notice they have a P60 dropin for sale with this emitter.
buck91
buck91's picture
Last seen: 6 days 6 hours ago
What do you use a high powered red light for? Unless you are building a blinkie to use as a safety light for walking/jogging/biking.
Ryzbor
Ryzbor's picture
Last seen: 6 min 10 sec ago
Sadly kaidomain doesn’t offer any true 660nm Photo Red leds.
virence.com Nichia E21A 3000K + 4000K mix Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K
blitzwing
Will be used for hunting.
Sirius9
Sirius9's picture
Last seen: 1 week 4 days ago
Forward Current: 1500mA
Power Dissipation: 5.0W
Reverse Voltage: 5V
This math kinda does not add up!
Is it better than Cree XPE2?
Cereal_killer
Cereal_killer's picture
Last seen: 6 months 1 week ago
What doesn’t add up?
Reverse voltage is the voltage at which damage will occur when a potential is applied backwards across the diode (positive into cathode).
Going off the iF and power ratings it should run at 3v at 1.5A.
blitzwing
For those interested I got three of these from Kaidomain to mod some torches with.
I’ve used a 2.1A driver from Fasttech, I had some lying around.
For starters, it’s like the solder pads on these were silicon coated – I had no end of trouble getting solder to stick to them! Worst I’ve ever encountered.
Anyhow, I installed one in a Brynyte S28 which has a deep, smooth reflector around 57mm. And the emitter works very well in it – very bright, tight hot spot and faint spill.
I also installed one in a Brynyte B158 (aspheric, around 50mm). I did not expect the wider viewing angle to work so great and to some extent I was right.
The spot is larger than an XP-E2 in the same torch but probably at least as bright.
Not a failure by any means and I’m interested in comparing them at night – I expect similar range from the two B158’s but a larger spot from the Luminus equipped one.
Definitely a good choice for a large reflector based light for those wanting a red thrower.
Oh, and XPE centering rings fit. Smile
Also the topic of red, I got a red triple P60 dropin from Kaidomain while I was at it and it’s damn cool!
DavidEF
DavidEF's picture
Last seen: 16 hours 9 min ago
90 degree viewing angle is not wide. It’s actually quite narrow compared to what we normally use in lights. Curious what emission angle you’d expect to use in the Brinyte B158 by comparison? CREE 660nm Photo Red XPE has an emission angle of 130 degrees.
- The YKK Philosophy
blitzwing
Whatever the case, it’s producing a larger spot than the XP-E2 and they’re the same dimension and both are focused well enough that you can see the bond wires.
1stein
1stein's picture
Last seen: 2 weeks 2 days ago
I’ve tried this LED in replacement of my XP-E2 red with 60deg Carclo round optics. The reading my luxmeted was giving idicated about 15% loss vs XP-E2 so I’ve put there back the Cree LED.
blitzwing
I’m liking this LED having tried it at night and mounted on top of a rifle.
For whatever reason the spot out of the B58 is about 20% larger than the one with the XPE2 and it looks a bit brighter to go with it. (tho it is run harder) and I really like it out of the S28.
