What’s Inside the Package?
Inside the Box, you will find the flashlight, A string to fix to the flashlight for easy carrying, Metal ring, Plastic washers, Extra USB cover, Carrying case, Manual and welcome pamphlet.
The packaging is made from recycled cardboard-like material which is always good to see. The packaging is simple and well padded for protection inside the box with a soft sponge material in black.
Overall great packaging as always, simple and effective. This will guarantee you receive your product in one piece no matter where you are.
The ThruNite TT10 flashlight has a solid weight to it that’s instantly noticeable once you pick it up. Also, it does not feel cheap and you can feel how premium it is once you have it in your grasp.
Emitter: (Cree XHP70.2)
Also with the features and weight, I can see why this is called a tactical flashlight as it could be used for self-defense if you are so inclined. Even if you are not trained mainly due to the sturdy metal construction this flashlight could be used as a blunt instrument if the need should arise in a tight situation, no joke.
The button layout is quick and easy to understand and you will need to charge this out the box which is not much an issue. Being rechargeable also is great for saving on batteries when used in conjunction with the various light modes.
The flashlight is also waterproof and impact resistant which means it can be sued in a variety of environments which a regular flashlight could never survive. Because of these features you can as I mentioned earlier use the TT10 in a professional or Home setting easily.
1. Operating modes include Firefly, Low, Medium, High, Turbo, Strobe light modes.
2.Lockout mode to prevent accidental presses.
3.Very bright producing Max 3700 Lumens of light and with a shine distance of 879 ft / 268 m.
4.Easy access dual tactical switch for easy access and quick functions when you need it most.
5. Rechargeable 5000mAh Lithium to hold lots of charge for the flashlights many functions.
6. Easy LED to indicate charge level and when flashlight needs charging.
Why buy this Product?
1.Great Build Quality with solid metal construction.
2.Super bright with great beam distance and coverage.
3.Many modes to choose between.
4.Easy access buttons for key features such as strobe.
5.Cool accessories such as a carry case.
6.Rechargeable to save on batteries.
7.Great tactical features for domestic or professional use.
8. It is waterproof and impact resistant.
CONS:
1. The dual tail switch can be kind of awkward to get used to.
That’s really all the cons I have for it. It’s a very well made product and Thrunite has told me that if you order one through Amazon and send them an email, they will include a free flashlight keychain as well.
Due Dilligence: This flashlight was sponsored by Thrunite, but it was not paid for. The opinions are from my own testing and I have no incentive to either praise or bash this light.
If you are someone looking for a true ‘tactical’ light, this could be a strong contender. First responders, police and anyone else needing full access to turbo by a single push of a button could prove very useful.
