(TC66C)Will phone explode if we use 87W charger to charge it
9 posts / 0 new
RD tech
RD tech's picture
Last seen: 22 min 56 sec ago
TC66C:https://www.aliexpress.com/item/32968303350.html
Youtube link:https://studio.youtube.com/video/6HouHseZTCI
For mobile phone charging, we have met a variety of questions: Is the original charger the best? Do you need to unplug the phone after fully charged? Do You need to discharge the phone to 0% before you charge the phone for the first time?
somedays ago, I watched a video on TIKTOK,  one man use a 87W macbook charger to charge a iPhone and of course I know the result, but the comments are interesting, one is that "87W, your phone will explode because we just use 5W charger to charge our phones", it is funny but I just want to do this test to show you what will happen.
We use a high-power charger to charge a phone. Usually the output of a iPhone charger is 5V/1A, and you will find if you use a iPad charger(5V/2.1), it costs less time to charge. But if we use higher power charger such as 87W laptop charger, will the phone explode?
Of course not, we can have a test, we use high power charger to charge the phones, and we can use our USB tester to test the charging current and voltage, and we need a iPhone and a Android phone to test, the remaining power of them should not be too much or too little.
OK we have three chargers, one 87W charger for MACBOOK, it has USB-C port; one 45W xiaomi USB-C charger; one 65W charger and it has three ports, the max power of USB-C port is 45W. Will they make the phones explode when charging?
and we choose TC66C to test because the USB port are all USB-C
from let to right: 45W xiaomi charger, 87W macbook charger, 65W Zmi charger(45W on USB-C).
then we test the voltage when we use them to charge a iphoneXR
We will use them to charges phone one by one
 of course we test the Android phone
the final result:
the remaining battery of android phone is high so the current value is small
we can see they can just charge the phone and nothing happened
Here is the reason:
We use USB-A port as an example, it has four metal strips, they are VCC/D-/D+/GND, VCC/ GND are used to transport port and D+/D- are used to deliver DATA. When you use quick charge mode to charge a phone, they will deliver voltage signals that changes according to a certain standard, once the signal match the phone, the charger will provide high voltage or high current.
In USB-C charger, signal are transported by CC lines, charger will tell the charging information to the phone, and the phone will choose voltage and current it supports. If the phone doesn’t support every protocol, the charger will provide 5V output.
Just like this:
PD charger: I have 5 charging mode
Phone: Roger that, I want 5V/3A charging mode
PD charger: OK, I will provide 5V/3A output
Phone :Roger that PD charger: 5V/3A charging mode is ready
Phone: OK, I got that, now I want 9V/2A charging mode
PD charger: Roger that, I will provide 9V/2A output
Phone: OK
PD charger: 9V/2A charging mode is ready
Phone: OK, I got that, please keep 9V/2A
So, it has no problem to use a high power charger to charge a phone, the chargers will not output the voltage and current directly, you phone decides the charging mode, and it will not explode.
Thank you for reading
If you have any interest in USB tester or power supply, please contact me
this is my shop on Aliexpress: https://rdtech.aliexpress.com/store/923042
Edited by: RD tech on 11/01/2019 - 23:26
raccoon city
raccoon city's picture
Last seen: 1 hour 6 min ago
But will it blend?  ;)
RD tech
RD tech's picture
you mean the influence of using other chargers? if you use formal charger, they are high quality, and it has no problem
raccoon city
Sorry, I'm just making a little joke.
There's a Youtube channel where they take different items and put them in a blender and destroy them.
They ask, kinda sarcastically, "will it blend?"
wle
wle's picture
Last seen: 12 hours 5 min ago
no, the “87 watts” is just the power supply
it is not the charger
the actual charger is inside the phone
it only takes what it needs as long as the input voltage is correct
so the 87 watter will just give 5 or 10 of its watts
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
mrheosuper
Last seen: 6 days 1 hour ago
I Remember the day i plug my laptop charger into my new phone in front of my friends, my friends ‘s faces were priceless !!!
if you know what you are doing, you won’t have to worry about anything
Forgot my pen
RD tech
RD tech's picture
got it, thank you for telling me this
RD tech
RD tech's picture
wle
yes, it is the phone that decides the charging mode, not the charger
RD tech
RD tech's picture
yes, it reminds us that we need to care about the commen knowledge in our daily life
