The Acebeam M50 is an Micro-USB rechargeable aluminum keychain light that is available with three different LEDs (SAMSUNG LH351D / OSRAM KW CSLNM1.TG / NICHIA 219C). The Samsung LH351D LED provides 200 lumens for super bright with such a small and compact size of the M50. The OSRAM LED produces a beam that throws further for those looking for a beam that can cover more distance.The Nichia 219C LED option which provides a 90+ CRI rating for true-to-life color rendering perfect for those accustomed to warmer beams or are looking for a beam that won’t wash out any color especially for critical electrical, mechanical, or medical work. Acebeam M50 only requires you to twist the light to access either the low or high modes. Fully tighten the lens to get high mode or simply loosen slightly for low mode. With the micro-USB recharging, the light will be full charged within 1 hour !
I’m wondering if the photographer was supposed to put the o-ring in the empty o-ring slot.
Waiting for one of these lights to come along with low voltage protection for gifts. “Battery charging is needed when the brightness is dimmer” tells me this is not the one.
I guess that’s a lot to stuff into this small of a light.
Wait, they made a new cell size for this light? The 10180 would have been better.
However, I’m very excited about the availability of these emitter choices in a tiny TIR keychain light, especially the OSRAM KW CSLNM1.TG, which should (hopefully) produce a surprising amount of throw for such a small light. EDIT: The official spec is 1300cd.
I might have to get one. Is there a discount code available? Or where should we buy to get the best price?
