Test/review of Vapcell INR18350 850mAh (Red) 2019
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 11 min ago
DSC_9279
Official specifications:
  • Model: INR18350 850mah 10A
  • Size: 18.2*35.1mm
  • Nominal voltage: 3.60V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Typical Capacity: 850mAh (0.2C discharge)
  • Min capacity: 750mAh (0.2C discharge)
  • Weight: Max: 25g
  • Internal resistance: Max:27mOhm AC 1kHz
  • Standard Charge: 500mA, CCCV 100mA cut-off
  • Quick Charge Current: 1500mA
  • Max Continuous Discharge Current: 10A
Vapcell%20INR18350%20850mAh%20(Red)%202019-info
This is high current 18650 LiIon batteries from Vapcell
DSC_9278
DSC_9280 DSC_9281
DSC_9282
DSC_9283
DSC_9284
Vapcell%20INR18350%20850mAh%20(Red)%202019-Capacity
The two cells matches nicely and can deliver the rated 10A
Vapcell%20INR18350%20850mAh%20(Red)%202019-Temp-7.0
Vapcell%20INR18350%20850mAh%20(Red)%202019-Temp-10.0
Vapcell%20INR18350%20850mAh%20(Red)%202019-Temp-15.0
Vapcell%20INR18350%20850mAh%20(Red)%202019-CapacityTimeHours
Vapcell%20INR18350%20850mAh%20(Red)%202019-Energy
Vapcell%20INR18350%20850mAh%20(Red)%202019-PowerLoadTime
Vapcell%20INR18350%20850mAh%20(Red)%202019-TripCurrent
Vapcell%20INR18350%20850mAh%20(Red)%202019-Charge
Vapcell%20INR18350%20850mAh%20%28Red%29%202019-Pulse-1A-10-10-2.5V-IR
Conclusion
This is a good quality high current cell with a fair amount of capacity.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
Superstocker
Superstocker's picture
Last seen: 5 hours 36 min ago
Thanks HKJ!
Dlux
Last seen: 5 days 15 hours ago
Lovely tiny beasts!
Thanks for the test!
vapcell Dennis
vapcell Dennis's picture
Last seen: 1 hour 22 min ago
Thanks HKJ Thumbs Up
