Rey Engine
34 posts / 0 new
ReyLight
ReyLight's picture
Last seen: 8 hours 4 min ago
Rey Engine
16374126
Hi everyone, I am developing the new Rey Engine. As you all know, ReyLight is a community driven brand, and your support and input are essential to its development. I want to make products to fit your demands as much as possible, and I want to gather your opinions and ideas about the groups in the new driver.
Since the output of the flashlight ranges from 1% to 100%, I want to know your preferred output spacing. (LAN and Pineapple is moonlight-2-20-100%). Since there will be secondary light in one of our upcoming flashlight, I also want to know where you want to put the secondary light. There are certain functions such as strobe and strobe frequencies that I am built into the UI.
Here are some thoughts:
Config:
8+ clicks to enter configuration, it will give 5 solid flashes, each flash stands for a given function.
Config #1-5 (or more)
1.Select a mode group, from G1-G8, (or more)
2.Mode memory on/off.
3.Moonlight mode on/off.
4.Reverse mode order, L-M-H to H-M-L.
5.Reset.
6.Your input here~~~~~
Mode groups:
Red or white fast strobe,
Red or white slow strobe,
Red or white random/crazy strobe,
Red or white SOS,
Red or white beacon,
Red or white beacon with white or red background,
Alternation of white and red strobe with background,
Red or white heartbeat strobe,
Red or white breathing,
Please comment in this format.
Such as:
1.Red25%- red100%- white2% – 25% – 100%
2.Red100%- white100%
3.White100%- white strobe
4. red25, red100, wht50, wht100
5. 1, 20, 50, 75, 100
6. 15%, 40%, 75%
Hidden group: When the light is on, press and hold the switch for 1.5-4 seconds.
This can give you a quick and direct access to a special mode group, such as strobe, beacon, etc.
I sincerely deeply appreciate your time and input.
30163740
g_damian
g_damian's picture
Last seen: 14 min 3 sec ago
I really like moonlight-2-20-100 on pineapple, it’s perfect in my opinion. I don’t use strobes so cannot comment on it.
Lund1660
Definitely no strobes, totally useless in my opinion.
wle
wle's picture
Last seen: 11 hours 43 min ago
do it just like anduril
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
wle
wle's picture
your UI looks like BLF A6
which is good
i;ve always wanted mode spacing like this
1 2 4 8 16 32 64 128 256 512 1024
with a really fast way to switch , like BLF A6 – half tap on the button, with a long tap going back one level
i consider that the next best thing to ramping
(though i have never seen a good ramping UI til anduril)
wle
-Greg Lemond.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 56 min ago
Hi Rey! First, I will be honest: I don’t own any of your lights, yet! Only some lights with your “old” drivers! I will need to save some to finally get one of your lights Blushing
Anyway, I will give you my input on this, based on my assumption of what could be good or “useful”.
Here’s my proposal, picking your own suggestions.
- Having a range of modes from which you can choose (from 1 to 5/6, in which “1” is a true moonlight and “5/6” is the highest output). By this I mean, having the possibility to have only 1 mode or all the 6 modes in use.
- Having double click for turbo from any mode (and a double press to get back to the previous mode).
- Having that longer press to access RED with a further half press to alternate between “low RED” and “high RED” levels (and eventually RED strobe if you really want it). Again, a longer press to return to the regular white LED. Of course, this part would only work well with reverse clicky switches.
As you suggested, having the possibility to turn the memory ON/OFFm, turn moonlight ON/OFF and to choose modes from lower > higher / higher > lower modes is appreciated.
These are only suggestions with some the intents of:
*having that true moonlight,
*having shortcut to turbo,
*having the possibility to choose the amount of modes in use,
*have RED light outside the regular cycle,
*not having blinking modes.
Hope you find it useful in some way!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
trakcon
trakcon's picture
Last seen: 5 hours 47 min ago
I really appreciate the number of group mode options available in the Dawn’s modified Bistro UI. I like being able to have 5-6 well spaced modes, ranging from very low moonlight (could be lower on the Dawn) to max regulated. I rarely use FET/Turbo, but appreciate being able to get to it in the hidden modes with medium (really quite long) press enabled.
Thanks, Rey!
Yokiamy
Yokiamy's picture
Last seen: 4 hours 4 min ago
I love the mode spacing on my current reylight’s (Ti-Lan and Pineapple), i really appreciate the true moon mode.
However, if i for instance turn on the light, and when i have turned on memory (just found out recently it has that feature, didn’t even know that) and when it has memorized a high mode, i would love to be able to select a lower mode (for instance with a long press, just as the original BLF X6 or A6 firmware) instead of going into a even higher mode.
So for me, please keep the standard UI and use a reverse mode by using a long press.
mattlward
mattlward's picture
Last seen: 1 week 1 day ago
Hey Rey, I am also a fan of the Pineapple modes. I would like to see a longer press reverse to the next lowest mode. I would think the secondary could be selected by an even longer press as well. One of the things I like about your drivers is their simplicity. I can hand a Pineapple to anyone and they can make it work!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Pwsmith
Last seen: 7 months 2 weeks ago
Well this is exciting! I love anduril and would love to have it on a reylight somehow.
Tixx
Last seen: 1 month 1 day ago
which is good
wle
Photon Freedom had a good one a decade or so ago and still is a good one!
And yes, I love the BLF A6. Had a few lights built using it because it has a good moonlight, nice levels, the reverse order with long half press….
Tixx
Agree! I don’t mind if blinkies are hidden. Triple click or something (Like Zebralight). I use at night when walking home and crossing streets at night. Stop signs are sometimes meaningless and need to attract attention to myself. But your suggestions are excellent!
SKV89
Last seen: 2 hours 9 min ago
I really like the UI in the TiLan and Pineapple. I think it is good the way it is. Just wan to request that you don’t glue the mcpcb to the shelf. You have the best host and great driver, but just don’t like the emitters.
trakcon
trakcon's picture
I’ve been eyeing a brass Pineapple V3, but will likely want to swap the emitter. Is the mcpcb glued down? That could be a problem.
SKV89
Yes it is glued. Rey said it is removable but I don’t have the technique to do it without damaging the pill
Barkuti
Barkuti's picture
Last seen: 11 min 21 sec ago
wle wrote:
I've always wanted mode spacing like this
Powers of two, yeah. But…
What do you mean with output? I mean, all of you. Because light output ≠ current output.
If we refer to driver output current the mode spacing needs to be bigger than just twice, at least if we aim to see a doubling in light output for each subsequent mode.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Yokiamy
Yokiamy's picture
which is good
wle
You know the human perception of light output is not linear?
There’s a reason flashlight manufacturers use mode spacing of 1, 10, 30, 100% Cool
CRX
CRX's picture
Last seen: 14 min 18 sec ago
I might have something like this:
Operation:
Single click – On/Off
Single tap – Mode sequence (Looped)
Double tap – Shorcut to 100% White
Triple tap – Shortcut to 100% Red
Configuration:
10 clicks to enter configuration, after voltage readout it will give 6 solid flashes, each flash stands for a given function.
Is voltage readout and/ or a thermal stepdown a possibility?
Config Menu:
0 .Cell voltage readout possible? in actual blinks (3.8v = 3 blinks, – 8 blinks)
1. Select a mode group, from G1-G15
2. Moonlight mode on/off.
3. Mode memory on/off.
4. Reverse mode order, H-M-L to L-M-H.
5. Thermal config stepdown possible?
6. Reset. (Default. 100%, 20%, 2%, 100% Red) H-M-L-R
Mode groups:
(Double tap shortcut to 100%, Triple tap shortcut to 100% Red)
1. 100%, 20%, 2%, ML
2. 100%, 30%, 5%, 1%, ML
3. 100%, 35%, 10%, 2%, ML
4. 100%, 40%, 15%, 5%, 1%, ML
5. 50%, 10%, 1%, ML
6. 100%, 20%, 2%, ML, Red 100%
7. 100%, 30%, 5%, 1%, ML, Red 25%, Red 100%
8. 100%, 35%, 10%, 2%, ML, Red 100%, Red breathing
9. 100%, 40%, 15%, 5%, 1%, ML, Red breathing, Red 25%, Red 100%
10 100%, 40%, 15%, 5%, 1%, ML, Red 100%, Red 25%, Red breathing
11. 50%, 10%, 1%, ML, Red 25%, Red breathing
12. 100%, 30%, 1%, Red 100%, Red Beacon, Red Strobe100%, White Beacon, White strobe 100%
13. 100%, 30%, 1%, Red 25%, Red breathing, Red heartbeat strobe.
14. White 30%, Red 100%, Red 25%, Red breathing, Red heartbeat
15. White 30%, White breathing, Red breathing, Red 25%, Red 100%
Hidden group: (White tactical strobe)
wle
wle's picture
wle
yes, that is exponential, not linear
wle
-Greg Lemond.
anonymous_user
Last seen: 7 hours 2 min ago
wle wrote:
wle
wle
Isn’t “1 2 4 8 16 32 64 128 256 512 1024” actually a geometric sequence?
raccoon city
raccoon city's picture
Last seen: 20 min 51 sec ago
anonymous_user wrote:
Isn't "1 2 4 8 16 32 64 128 256 512 1024" actually a geometric sequence?
I believe it is an exponential sequence, but I think modes work better when you multiply by about three (instead of two) between modes.
DavidEF
DavidEF's picture
Last seen: 17 hours 21 min ago
That was my understanding as well.
- The YKK Philosophy
Alitd
Last seen: 7 hours 20 min ago
This is what Krystal should have offered.
Hidden is intuitive but turning off and back on quickly can trigger accidentally.
I have x2 Lan, a Pineapple and the Krystal….I love your work.
ReyLight
ReyLight's picture
Thanks for your input.
Let’s assume that I was at low mode, and I want to get to high mode; if I click rapidly (let’s say 2-3 times within 1 second), I will be forced into the hidden mode.
ReyLight
ReyLight's picture
Zebra uses electronic switch, reverse clicky is quite different. 1click= next mode, 2 clicks= next 2nd mode, 3 clicks= next 3rd mode.
It can ealisy cause some confusion.
hodor
hodor's picture
Last seen: 45 sec ago
I love the spacing of LAN/Pineapple. One thing I would note though is I occasionally overshoot or over estimate how much light I want / need and inadvertently enable mode memory. Not sure if anyone else has this problem Blushing . Also, handing these lights to muggles is a guaranteed switching of mode memory. Personally, I would like to see config mode require more than 8 clicks.
ReyLight
ReyLight's picture
I can imagine that.
rngwn
rngwn's picture
Last seen: 3 hours 41 min ago
Since the perceived brightness is exponential, I’d say:
ML-1.5%-6%-25%-100%
perhaps adding and extra moonlight-only mode activated by double-tap to prevent accidentally ruining night vision.
Searching for High CRI leds since 2010...
Has finally gotten to the bottom after 10 years of delving deep into that rabbit hole of them high CRI lights...
High CRI, high quality lights doesn't need to be expensive, or is it?
hodor
hodor's picture
Are we talking clicky or e-switches? For e-switches, mode memory with shortcuts to firefly, via hold from off, and double click to turbo are Thumbs Up
ReyLight
ReyLight's picture
Reverse clicky.
MascaratumB
ReyLight wrote:
MascaratumB wrote:
[…] – Having a range of modes from which you can choose (from 1 to 5/6, in which “1” is a true moonlight and “5/6” is the highest output). By this I mean, having the possibility to have only 1 mode or all the 6 modes in use.
- Having that longer press to access RED with a further half press to alternate between “low RED” and “high RED” levels (and eventually RED strobe if you really want it). Again, a longer press to return to the regular white LED. Of course, this part would only work well with reverse clicky switches. […]
Hi Rey! Glad you find it useful!
I do understand your perspective and concern about the double click making us enter the “hidden” mode (Turbo). I guess that in a reverse clicky will always be hard to control the amount of pressure and the timing to make it act correctly.
Some time ago I made some demonstration videos with the guppy3drv firmware by doctor Jones. In this driver/UI you can choose some configurations where you can double click for turbo from any mode and a half press takes you back to the previous mode.
I tried to demonstrate that you can “manage the timing” of the double click, but it is true that it is not always possible to get it right.
However, take a look here.
Maybe there is another option instead of 2 fast clicks, but I really, REALLY, think that having the possibility to enable/disable a double or triple click to turbo would be awesome in a reverse clicky flashlight!
Hope this helps Wink
I also made another video showing it with forward switch but I guess it will not be useful in this project.
