HELP! Soldering to LED PCB
13 posts / 0 new
John5box
John5box's picture
Last seen: 6 days 16 hours ago
I have just tried building my first light with:
XHP70.2 on a 16mm PCB with 17mm direct drive driver in the UF1405 from MTN electronics with 2×26650
Maybe I’ve gone too high as a first go!
I had the torch put together and it looked to me like everything was soldered correctly BUT when I turned it on the LED came on but then the PCB began to smoke and the wires from the driver desoldered from the board! What am I doing wrong? Is the LED just too hot for a 16mm PCB or is it an issue with my heat sinking?
Completely in the dark, if only I had a good flashlight. New modder looking for illumination!
chops728
Last seen: 14 min 19 sec ago
Might have a Direct Short on the + side —- too little heat sinking will cook the LED—Both wires desoldered
John5box
John5box's picture
Thanks for this! So is that an issue with the PCB or just bad soldering on my part?
chops728
A direct short means it was grounding to the reflector or the host —- hard to say what it is without seeing pics —- take it apart and examine it—I had to burn up a few things before I learned to check for shorts with a DMM before powering up
e1000
Last seen: 44 min 16 sec ago
what driver exactly? If you didn’t choose the zener mod, it’ll go poof
Skylight
Skylight's picture
Last seen: 19 hours 37 min ago
Did you use thermal paste and have you pressed the 16mm star down firmly? If the wires desolder, it sounds like the thermal paste is not good enough.
Always looking for: used or damaged flashlights for repair and MODDING
John5box
John5box's picture
Thank you guys, it’s the 6v Zener mod, thermal paste looks pretty good, I’ll check for a short and see if that’s the issue
Thanks again!
mikelights
mikelights's picture
Last seen: 2 hours 10 min ago
Hey I did a very similar mod to my 1405 but with a xhp 70 not 70.2, I made a video on it This is a link to the thread. Just thought you’d be interested since i think it comes out very well with the aspheric lens ! Share pics when your done I’d love to see some
Current collection
Olight -S1R turbo S -I3E EOS -S mini brass -S2A -X7R -S mini copper Sofirn -SP33 Nitecore -TM06S Thrunite  -TN42  ThorFire -S70S -TG06S -TK05 Manker -Mk34 Noctigon Emisar -Meteor M43 -Emisar D4 -Emisar D1 -Emisar D1S -Emisar D18 Rofis -TR31 Lumintop -BLF GT -GT Mini -IYP365 -Tool AA 2.0 -FW3C Acebeam -X80GTvn -W30 Imalent -R90C -MS18
Product Reviews
Chargers:
Opus BT-C3100MiBoxer C4-12MiBoxer C8Folomov A1
Flashlights:
BLF GTTN42TG06SEmisar D4GT MiniS70STM36EDC-C4BLF Q8W30
Custom Builds
XPL-HI C8, Aspheric XHP-70OSLON D1S
Lightbringer
Lightbringer's picture
Last seen: 10 hours 8 min ago
Did the LED come on bright or just glow dimly but with good/expected color? Or did it go blue and dim?
Blue and dim means it’s being pushed way over peak output, and is generating more heat than light.
Lightbringer
Oh yeah, you might wanna lap the pcb nice and flat, and especially the shelf it sits on. Sometimes the lathing process leaves a tiny nipple in the center that unless ground flat will stick up like a very shallow thumbtack and keep the pcb from sitting flat on the shelf.
clientequator
clientequator's picture
Last seen: 1 week 4 days ago
did you check if your flash light reflector is touching soldered wire on led board? This mean a direct short and will melt wires.
John5box
John5box's picture
Thank you all for the advice! I’m just waiting for another driver to arrive! In the meantime I’ve changed the thermal paste to a well recommended one that isn’t electrically conductive and managed to get a stable light from the LED with 6v which is impressively bright, so I can’t wait for the driver to arrive
chops728
Get you a cheap DMM and check for shorts before you power it up —— I built a light yesterday and if I wouldn’t have checked —the driver would have been toast — I had a direct short on the + side
