[Review] YLP Sherp S15 (XM-L2 + XP-G3, 18650) - A great EDC you've never heard of
11 posts / 0 new
bilakos10
bilakos10's picture
Last seen: 48 min 43 sec ago
The flashlight was sent to me by YLP for review.
Here's the product's link: YLP Sherp S15
The S15 comes in a hard cardboard presentation case.
The flashlight along with the included battery are seated into foam.
The box also includes a wrist strap, 2 replacement o-ring and a manual.
The S15 comes with a flat black anodization and is e-switch operated.
Its body it totally smooth except from some heat-sinking grooves on the head.
Opposite to the e-switch, there's the secondary XP-G3 led that provides a very floody beam.
The secondary emitter comes with no reflector and is covered by a semi-transparent plastic which is used to enhance the floodiness of the beam.
The e-switch comes with a bright orange rubber cover and sits almost flush with the rest of the body.
It's worth noting that there's an indicator LED installed into it that will glow in red once the battery is low.
The head houses the primary emitter, which is a Warm Cree XM-L2, along with the TIR lens.
The head can be disassembled easily by untwisting the metal bezel.
And here's a closer look at the TIR optic.
The optic creates a wide, artifact-free beam.
The tail houses the copper spring.
The S15 comes with anodized threads, which means that it can be mechanically locked out.
As with most flashlights from YLP, this one also comes with an 18650 cell.
The cell is branded with 2600mAh of capacity and has built-in charging and protection.
User Interface
The user interface of the S15 is adjusted to its dual emitter setup.
Here's all the supported actions:
Turn on/off (Main emitter): Single press.
Turn on/off (Side emitter): Double press for ON, single press for OFF.
Mode cycle: Long press - Main emitter (Low > Mid > High > Low > ... ) , Side emitter(Low > High > Low > ...).
Moonlight: Long press while off.
Turbo: Double press and hold.
Turn on/off Memory: Long press for 15secs. 1 blink = OFF, 3 blinks = ON
It's worth noting that the side emitter works independently from the main emitter.
This means that both emitters can light up simultaneously.
Output
I took my output measurements using the include YLP-branded 18650 cell.
Here's a table with the measured output along with the respective power draw.
As you can see, the advertised max output is pretty close to what I measured (867lm)
I also measured the parasitic drain at 51μΑ, which is very good.
Thermal Regulation
Here's a thermal regulation graph I created.
What we can see in the graph:
  • The max output is sustained for 2.5 minutes.
  • After the 2.5 min mark, the output gradually steps down to 670 lumen.
  • The stepdown output if fully sustainable.
  • The output looks very well regulated.
  • The whole time, the head of the flashlight never got too hot to handle.
Outdoor beamshots
For the last part, here's few outdoor beamshots.
At 10m
At 30m
At 35m
My daily deals thread: ☢ [Gearbest.com Special Deals]
If you need any coupon code, just leave a reply on the thread.
Edited by: bilakos10 on 09/08/2019 - 14:36
Chatika vas Paus
Last seen: 1 hour 40 min ago
Is access to the side led easy? I would prefer a high cri diode on the side.
bilakos10
bilakos10's picture
What do you mean by access to the side led?
The side led is opposite to the e-switch so it’s easy to locate.
Also the holding position is quite comfortable.
Lightbringer
Lightbringer's picture
Last seen: 28 min 57 sec ago
That looks pretty nice!
And I never heard of them before, so I learned something new today. LOL
Both emitters are WW?
Chatika vas Paus
I mean disassembly to replace the led.
bilakos10
bilakos10's picture
Ah now I get it.
Unfortunately I don’t know how easy it would be to change the side emitter.
The head seems to be glued to the body.
fnksb
fnksb's picture
Last seen: 1 hour 46 min ago
Some people change the side LED (me too), but it’s quite complicated. For example, you can pull out the side lens with a strong tape.
Front LED changes more easily. I put Samsung 351D in both =)
Chatika vas Paus
Why it’s complicated? And how strong the tape should be?
fnksb
fnksb's picture
I don’t know anything about scotch tape in your stores Tired
Lift the lens slightly with tape, then use tweezers or a thin screwdriver.
Just do it carefully.
//Of course, YLP does not recommend this Innocent
SKV89
Last seen: 24 min 17 sec ago
Thanks for the review and the excellent photos. The driver seems like it has good regulation and probably very good efficiency too. Do you know if this will fit 21mm mcpcb? I’m thinking of getting this to put in a 4xE21A. The optic seems perfect for this emitter. Thanks.
fnksb
fnksb's picture
Sherp’s MCPCB is only 14 мм…
