So I’m cleaning out my battery inventory after buying 18 Sanyo 18650GA and found some mysterious green batteries. They came out of a battery pack for a Sony Vaio laptop I found at the thrift store. The wrap is translucent vivid green like a leprechaun’s jacket, black top cap ring, 3 spoke positive terminal and have some markings on them.
First line SE US18650GR
Second line T 7C11JPF21G with what looks like a backwards RU on the end.
No other markings or codes. The negative terminal isn’t flat, but has a raised inner part like a big, flat button.
I checked the web and they are a dead giveaway for Sony 18650GR’s, but I dont know the capacity as they don’t have a G followed by a number to designate capacity.
Any idea on the capacity? I will eventually capacity test them, but wanted to get a benchmark so I can see how many electrons have escaped over the years…
Only 2100? Rats I was thinking the ‘7’ may have designated 2550. They are around 2008 or 2007 vintage I think. When I got them two were dead beyond salvaging, but I got 4 that weren’t completely dead like the other laptop batteries I harvest. I’ll probably stick them in a power bank someday.
Sorry, but all are in error concerning the Sony GR-Gx Series cell capacity (“x” designates the model revision number which has its own capacity but still a continuous maximum current discharge of 2 times its internal load ie 2C, except those in Gx “D” where it is 3C):
US18650 “x”:
x (mAh given for Nominal Capacity):
GR-G1x: 1400 mAh
GR-G1D: 1250mAh
GR-G2x: 1600 mAh
GR-G2D: 1450 mAh
GR-G3x: 1800 mAh
GR-G3D: 1650 mAh
GR-G4x: 1950mAh
GR-G4D: 1800 mAh
GR-G5x: 2150 mAh
GR-G5D: 2000 mAh
GR-G6x: 2200 mAh
GR-G7x: 2400 mAh
GR-G8x: 2600 mAh
GR-GH1x: 2800 mAh (class of cells intended for the same uses, but chemistry totally different because Nominal Voltage of 3,75v instead of 3,6v and Maximum charge voltage of 4,30v)
Use the two lines of codes printed on wraps of your Sony Cells… I do not see what’s complicated, and on the contrary: I love Sanyo but their old system with wraps and insulators colors and thermal printing for the model code and the datecode, that’s boring and especially complicated.
I ran a capacity test on the 4 cells with my Zanflare C4. One was 1660 man, second was 1917man, third was 1820mah, and the 4th was 1860mah. So it seems like these lives a hard life or they were low capacity to begin with.
