Test/review of TenaVolts AA 2775mW (Black-blue)
8 posts / 0 new
HKJ
HKJ's picture
Last seen: 4 hours 17 min ago
DSC_9122
Official specifications:
  • Product model: NF-LB1
  • Battery size: AA
  • Charge capacity: 750mAh
  • Energy capacity: 2775mWh
  • Output voltage: 1.5V
  • Battery weight: 18g
  • Cycle times: >1000
  • Operating temp.: 32-104°F
TenaVolts%20AA%202775mW%20(Black-blue)-info
This is 1.5V LiIon AA batteries with build in voltage conversion for LiIon voltage to 1.5V.
DSC_9113 DSC_9114 DSC_9115 DSC_9116
I got the batteries in a nice box with specification for both the batteries and the charger.
DSC_9119
The box contained four batteries, a charger, a USB cable and a instruction sheet for the charger.
DSC_9123 DSC_9124
DSC_9125
DSC_9126
DSC_9127
The ring on the bottom of the cell is transparent and will emit blue light while charging, but there is only one led making the light very uneven.
TenaVolts%20AA%202775mW%20(Black-blue)-Capacity
These batteries maintain 1.5V until they are empty.
Discharge%20capacity%20TenaVolts%20AA%202775mW%20%28Black-blue%29
There is no significant difference in capacity at low currents, this means the self discharge is very low.
TenaVolts%20AA%202775mW%20(Black-blue)-CapacityTime
TenaVolts%20AA%202775mW%20(Black-blue)-CapacityTimeHours
TenaVolts%20AA%202775mW%20(Black-blue)-Energy
TenaVolts%20AA%202775mW%20%28Black-blue%29%20load%20sweep
The batteries do not have a hard current limit, but voltage will drop when the load is too high.
TenaVolts%20AA%202775mW%20%28Black-blue%29-Pulse-1.0A-10-10-0.7V-Pulse-1.0A-10-10-0.7V-IR
The internal resistance looks smooth for a electronic regulated battery.
LoadTest1A
The output will change little when load is applied or removed.
Spectrum1Aload
It looks like the buck regulator runs at about 1.4MHz. The noise is less than 30mVpp, but I cannot measure lower with the current setup.
Charger TS-C1
DSC_9128 DSC_9129
The charger is a box with a semitransparent lid.
DSC_9130 DSC_9131
DSC_9132
Power is connected to the micro USB input.
DSC_9133
Behind the lightning symbol is a green led to show the charger is powered.
DSC_9137
It has specifications on the bottom.
DSC_9135 DSC_9136
The slots are standard 2 level slots for AA/AAA batteries.
DSC_0042 DSC_0044
The TenaVolt are AA batteries.
TenaVolts%20TS-C1%20%28TenaVolts%29%20%231
The battery is charged with about 4.6V to 5V and uses an internal charge regulator, it will terminate the LiIon charge at around 50mA.
TenaVolts%20TS-C1%20%28TenaVolts%29%20%232
TenaVolts%20TS-C1%20%28TenaVolts%29%20%233
TenaVolts%20TS-C1%20%28TenaVolts%29%20%234
Not much difference with the other slots (The voltage varies slightly).
TenaVolts%20TS-C1%20%284xTenaVolts%29
With four batteries the voltage is lower, this means slightly longer charge time.
Voltage%20sweep%20%231
Voltage%20sweep%20down%20%231
But what happens if a Alkaline or NiMH battery is put into the charger? It looks like it has a PTC that will limit the current. Initially it may draw all the current the USB output can deliver but after a few seconds the current will be limited. This means a NiMH will be charged continuous with around 130mA. Alkaline will be charged with higher current!
Charger Tear-down
DSC_0045
I could break the charger open with a spudger.
DSC_0046 DSC_0047
There is two small circuit boards inside the charger and no electronic on this side.
DSC_0048 DSC_0049
DSC_0050 DSC_0051
On this side is 5 resistors and one LED, as the test shows above four of the resistors (R2..R5) are PTC’s and the last resistor (R1: 10kOhm) is for the LED.
DSC_0052 DSC_0053
Conclusion
These batteries has less capacity than normal NiMH, but run at a higher voltage, making the energy about the same. This makes them ideal for most equipment that has trouble with NiMH batteries. They also weight considerable less than NiMH, this can be significant in some circumstances. There is one disadvantage: Battery meters do not work with them.
The requirement to use a special charger is a disadvantage, but if it is damaged or disappears it is possible to modify any AA USB charger for this purpose (Requires soldering skills).
Notes and links
Batteries and charger was supplied by TenaVolt for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
flydiver
Last seen: 8 hours 11 min ago
Timely write-up for me. I have about a dozen of these now. Initially got them hoping they would work in an underwater strobe, then learned they would not. Oh well.
[Specifically say; (NOT FOR CAMERA FLASH USE)]. I don’t recall seeing that when I bought them. Don’t know if it was added due to feedback issues, or I simply did not register the warning.
Had a couple applications requiring 1.5v in mind for them for the first set and they worked well. Got more and tried more normal uses. Work fine. Have not tried very low draw applications like remotes. Looks like they might be fine there….until they aren’t.
The construction and finish of the batteries is quite good. Consistency seems very good.
I personally don’t have any issues with the dedicated charger.
Pete7874
Pete7874's picture
Last seen: 20 hours 25 min ago
Thanks for the review.
I am not seeing these Tenavolts in your comparator dropdown. Maybe you haven’t added them yet?
HKJ
HKJ's picture
Adding is automatic, but it do not work before I upload it. It is fixed now.
Superstocker
Superstocker's picture
Last seen: 5 hours 41 min ago
Thanks HKJ!
xxo
Last seen: 1 day 13 hours ago
Thanks much for the review!
I just got a a set of these from the amazon deal, they seem to work well.
A few things I noticed:
Running a tenavolt in a xeno xo3 on high was noticeably brighter and ran hotter than a eneloop by a good amount. After about 37 min the light shut off and I immediately checked the Voltage – it fluctuated wildly from about 0.26 to 0.60 Volts.
Running Tenavolts in a life gear AR flashlight/lantern (3 AA’s in series/direct drive) the tenavolts were noticeably brighter as well, but after 8-9 hrs of run it started to get dimmer than a identical light running on eneloops and started to flicker. It continued to flicker for an hour or so without getting super dim but I decided to shut it off and recharge the tenavolts at that point.
While the cells were charging I pulled one and put it on an xtar VP2 charger on the 4.35V setting @ 0.25A, it seemed to be charging, but since the Voltage is always around 1.52V there was no easy way for me to be sure with a quick DMM reading so I put it back in it’s proper charger.
BTW charge times I got were just about exactly 2 hours.
3D printed battery adapters for sale: http://budgetlightforum.com/node/69377
flydiver
These will charge on (some) normal Li-on charger but they will not charge correctly. There is no feedback for the charger to determine what the cell is really doing. IMO, don’t even bother trying. I did just to experiment, as some users were claiming that they could do that in [Slickdeals]. The Li-on chargers varied on whether they would even try or not. They will do nothing at all on a NiMh charger, at least not mine, and I have a bunch of different ones I tried.
If you look at the discharge graph you can see they do OK at 1A, hang in at 1.5A, and start to fall apart after that. Eneloops do better under higher draw and inherently have more capacity. These are not well suited to sustained draw much above 1.5A I think.
HKJ
HKJ's picture
A LiIon charger will not fully charge these batteries, they need more voltage than 4.2V and I also doubt 4.35V is enough to charge on any reasonable time.
My guess is that they uses a very small linear charge IC, this means feeding them 5V when empty will reduce charge rate because the IC gets hot.
