XANES XT02
10 posts / 0 new
ajven
Last seen: 40 min 47 sec ago
XANES XT02
This is nice flashlight, very well made, but I struggle to remove driver, any ideas?
Edited by: ajven on 10/01/2019 - 04:51
1stein
1stein's picture
Last seen: 1 hour 46 min ago
Why don’t you unscrew the retaining ring? IMHO this looks like a regular driver mount.
I’m not familiar with this particular model, but if were in your shoes first I’d screw out the “pill” (threaded cylinder in which the driver is placed), then desolder LED leads, then unscrew the retaining ring (you should use some nose-pliers, put them into two bored oposite holes and unscrew the ring). Now the driver should be possible to take out.
PS:
I can see the pill has no holes for nose-pliers. If you find difficult to screw in/out the pill you can first unscrew the retaining ring, lift the driver into vertical position (beware of leads still attached to the LED) and put nose pliers into holes through which the leads go the the LED – this means going deeper into pill. On the other side of the pill (where the LED is mounted) there must be two through out holes for two wires (+ and -)
ajven
Thank you, missing holes on pill was problem, I don’t want damage threads. Wire holes was great idea. Thumbs Up
1stein
1stein's picture
Happy if that helped! Beer
ajven
A few pictures, not bad for about 9€ Smile
small but deep reflector:
SST20 4000K CRI95
8*7135 version, TINY13a (I want to flash it)
1stein
1stein's picture
Very similar to Convoy S2. Thanks for pictures.
Perhabs even rebranded Convoy S2…
MascaratumB
MascaratumB's picture
Last seen: 32 min 49 sec ago
Was going to say that! These S2 shaped tube lights can also be found with other brand’s logos, such as Manta Ray, Utorch, and others. (Well, at least the S2+ shaped have them).
If it has the host quality as Convoy, it may be good, but a better driver won’t hurt Wink
I only have one S2, with SMO reflector, Osram White flat and Led4Power Driver. A “mini-pocket-thrower-tube-light” Big Smile
Enjoy your light, ajven!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
jasontheguitarist
Last seen: 1 week 2 days ago
Does this mean that they have a retaining ring that works with a 7135×8 driver? Even Convoy never figured that one out for some reason.
ajven
yes, it has
dick33
Last seen: 1 week 6 days ago
Got this light but with 4×7135 – 1400mA. Was suprised that the MCPCB under the led is ordinary aluminium and not DTP copper.
Your version with 2800mA has DTP board?
ajven wrote:
SST20 4000K CRI95
It’s visible the white-metal edge of the MCPCB, or is this copper?
