[M4D deal] Nightwatch NI40 with Luminus SBT90 Gen2 interest list OPEN
474 posts / 0 new
Rayoui
Rayoui's picture
Last seen: 1 hour 1 min ago
With this thing pulling 24 amps, it doesn’t surprise me at all.
Tom E
Tom E's picture
Last seen: 6 hours 55 min ago
All these beamshots are nice but has anyone actually measured throw and lumens output on a specified cell at a specified voltage? Seems strange Bluzie got one to take pics of but no measurements? I'm in the 2nd batch I guess, waiting for it to be shipped.
Th558
Th558's picture
Last seen: 7 hours 42 min ago
Th558 wrote:
Found this on YouTube. Head is 52 degrees at 15 seconds. Doesn’t make sense. Maybe he turned it on earlier?
NI40
Here are some comments from TLF by the user who posted this video (LightintheNight). I’m kinda confused now cause according to Nagonka the 40T was 32% brighter than the Shockli.
I do not know if this works like this …. but I tried with very simple means to display the first 4 minutes of the control with temperature measurement. Safe far away from professional and only for good eyes, but just handy Wink
Edit: a few more comments …
- Use found a full Samsung 30T battery with 4 or 5 charging cycles, but now has a deepTop ;-(
- the lamp was running all the time on Turbo, in another attempt in high regulates them The first few minutes hardly down
- the 30T had just after the 4 minutes turbo only 3.8 V
- the 30T brings a slightly higher turbo brightness than all the 26650 batteries that I have tried before
- the lamp was not quite cold to start, because I previously 26650 batteries have measured briefly, ie the whole should be extendable by 10-15 sec
Have times a few details added above, was with 30T battery …
@ hjelpestikker With these batteries, I had compared the starting brightness …. The difference when starting on Turbo (pure data without conversion): – Shockli 5500: 367 – Keeppower 5200: 372 – Thrunite 5000 (evidently protected): shut down – Imalent 4500 (mE protected, but left): 369 – ijoy 4200: 366 – Samsung 30T (21700): 376 (not quite full, in the video then complete even 388 ) For comparison: at high, the value was at all around the 300 Lg LitN
mr_magoo
Last seen: 12 hours 24 min ago
I hear ya! Cant wait till someone from blf gets one to do a proper review..
I personally dont have good equipment to measure (just my phone) but I will when I get mine. I’ve got a shockli and a some golisi cells coming, should be here before the light.
I’d like to stuff this led into several different size lights to find it’s best home. I’m thinking its going to be something with a 3” head or
bigger, and 3 or more cells. I have a tn32 with a bad driver, that will be first. I’ll have to get creative to make it work.
Tom E wrote:
All these beamshots are nice but has anyone actually measured throw and lumens output on a specified cell at a specified voltage? Seems strange Bluzie got one to take pics of but no measurements? I’m in the 2nd batch I guess, waiting for it to be shipped.
BaronVonEissler
BaronVonEissler's picture
Last seen: 4 days 18 hours ago
I agree. Looking forward to you and other testing it.
To the best of my knowledge and based on output,The life of a Golisi on max[increments of 5 min.] will not be much more than my buddies MT35 W/XHP 50.2. Turn on was 4100L
5 minutes-3.83V
10 minutes-3.62V
It drains the battery as to be expected. That is why I have 3 X Golisi and 4 X Aspire. Cool
Tom E
Tom E's picture
BaronVonEissler wrote:
I agree. Looking forward to you and other testing it. To the best of my knowledge and based on output,The life of a Golisi on max[increments of 5 min.] will not be much more than my buddies MT35 W/XHP 50.2. Turn on was 4100L 5 minutes-3.83V 10 minutes-3.62V It drains the battery as to be expected. That is why I have 3 X Golisi and 4 X Aspire. 8^)
I got a modded triple XHP50.2 3V light that hit over 30 amps off a fresh GOLISI, so high amps draw is fine with me. The main thing is how this light does on throw, compared to the 220 kcd rating. It's the simplest thing to measure, in fact I find it wayyy easier than doing beamshots, though results may and will vary. I got 3 light meters and they have about a 5% variance range.
This SBT90.2 sure looks like it beats the dedomed XHP50.2 and the dedomed SST40 in throw, and of course much higher in lumens. Not sure where it is head to head with a XHP35 HI in throw, but the XHP35's require a special driver because of the 12V and restricted amps.
Th558
Th558's picture
As far as I’m aware the XHP35 HI doesn’t throw as well as the SST40 but it’s pretty close. Besides having a slightly smaller head the Acebeam K75 is around 40-50% more intense than the BLF GT/Astrolux MF04. Acebeam T27 XHP35 with its 70mm head does 340kcd and the FT03 (same head size) does 367kcd with a Dedomed SST40. Obviously everyone’s measurement are a bit different but it does seem like the SST40 outthrows it by a bit and the SBT90 outthrows them both. According to that Chinese video though the SBT90 intensity was slightly less than the SST40. Even when comparing bluzies pics it seems pretty close to FT03 and a bit behind the M3XS-UT (250Kcd). Doesn’t make sense to me though. The SBT90.2 should be outthrowing the SST40. Hope that made sense. Lights are shipping soon so I guess we’ll just have to wait for some proper tests.
Tom E
Tom E's picture
Th558 wrote:
As far as I'm aware the XHP35 HI doesn't throw as well as the SST40 but it's pretty close.
I assume you mean the SST40 DD, not the factory SST40 with dome. Things are getting a bit strange now, since I assume the SST40 is only produced with a dome, but we can buy dedomed variants, but I have to assume the DD is done after market, not by the factory, so there's no protective film/covering over the phosphor I guess?
Not so long ago, the XHP35 HI was the best factory LED available for throw, but clearly the OSRAM's 1mm and 2mm factory domeless throwers should have everyone beat, but at a cost of low amps, low total lumens output, and having a tight pencil beam. I haven't been sure how the SST40 DD fits in, comparatively, but glad you provided that info above. Of course it can be driven hard with decent lumens output and it's large surface should have a decent width beam. The newer XPL HI V4 bin LED's should also be competitive I would think, but again, not sure where it is in direct comparisons, but with the XPL HI's, all depends how many amps you can get out of one.
Th558
Th558's picture
tm07 dedomed his FT03 and it went from 235kcd to 367kcd. Someone else said his was 357kcd. Unfortunately they are not available without a dome. Hopefully Luminus decides to make some. Could make some really good budget throwers.
Tom E
Tom E's picture
Neal lists a bunch of comparative throw #'s of the LED variants for this Nightwatch NI40 Stalker here,  which is pretty useful info if it's correct, and if it is using a true FET based driver as I suspect it does, based on the power(W) numbers listed.
Looks like KD still is selling the DD SST40's here: http://kaidomain.com Luminus-SST-40-Dedomed-White-6500K-LED-Emitter
BaronVonEissler
Th558 wrote:
He said everyone’s should ship next week. He’s paid for 100 pcs.
Post #220 on Thursday 7th of November
I know you are just the messenger man and I hope this is true.
Unless we count the weekend, tomorrow is the last day of the week. No more shipping today it is 8:44pm Hong Kong time now.
I have learned to lower my expectations in many areas of my life. This is one of them! Serenity is a by product of that.
I am not expecting it to be shipped tomorrow based on my Two emails to Neal that went unanswered on Oct. 23rd and Oct. 29th.
Th558
Th558's picture
He said he’ll receive them this week and they’ll also ship the same week. Mine hasn’t shipped yet though. Someone above said the stock is supposed to arrive on Monday which is 3 days ago. I did message him yesterday asking if I’ll receive a tracking number when it’s shipped to which he said yes. Tried emailing him a few days ago. Didn’t work. I only message him on FB now. Sometimes he doesn’t reply but these last few days he’s been replying pretty quickly.
https://www.facebook.com/profile.php?id=100005099148932
BaronVonEissler
Thanks. I will just wait. You can be “Our” Informant. Beer
g_damian
g_damian's picture
Last seen: 4 hours 12 min ago
Got mine! shockli black 5500 only around 16A (battery was not full).
2.5m to the wall. All on max. D80v2 SST-40, GT mini XP-L HI, M21A CULNM1.TG (6A), NI40 SBT90-2:
Album with all pictures
BaronVonEissler
Thanks
Why would you test it with a battery that is not fully charged?!
Th558
Th558's picture
Nice. I would love to see that same pic with all the lights fully charged.
Th558
Th558's picture
Neal said he’s received 20 pcs. Mine will ship today. Yay! LOL I think he also said he will receive the rest of them this week.
g_damian
g_damian's picture
Update:
I measured 17A max. Other also report not the best performance with shockli black.
Lux at 6.7m:
  • D80v2: 1289 (58 kcd)
  • GT mini: 2151 (96 kcd)
  • M21A: 5025 (225 kcd)
  • NI40: 4124 (185 kcd)
Ceiling bounce:
  • D80v2: 247
  • GT mini: 148
  • M21A: 116
  • NI40: 525
  • NI40 on high: 253
Low performance of GT mini in my case is probably caused by springs, because sometimes I use longer cells with integrated charging in GT mini. The measurement was taken with VC6 and it resulted with reduced springs tension.
BaronVonEissler
Mine shipped yesterday, November 17, 2019. Cool
baustelle
Support from Neal is inadequate or actually almost zero.
No answer for emails(for weeks) also no reaction for chat inquiries at nealsgadgets…
BaronVonEissler
I am glad that it shipped. However, almost 1 month [initial email, sent Two]with UNANSWERED questions is UNACCEPTABLE. The questions had nothing to do with shipment, it was a question about conflicting information regarding step down listed on his website and what a user experienced.
If he was a dealer in USA he would be out of business! I am not alone in the frustration regarding his inability to respond to his customers. We should not have to chase him on FB or wherever else he can be contacted.
I hope the light never has an issue. If so, I expect nothing after this experience.
Tubercle
Last seen: 5 hours 37 min ago
Mine still hasn’t even shipped.
I don’t know why I’m ordering from Neal as the last order was a PL47G2 from him and I waited 38 days for it (to just be shipped) and it came w/ massive problems (like the head/optics being misaligned, and the rubber o-ring falling into middle of the optic and sticking there, causing beam artifacts. Sounds like he picked out the factory-seconds and mailed those out. I guess I really wanted a SB90.2 light. But now the FT03 is gonna come out w/ a SB90.2 light I might just cancel and wait for that.
Cloud
Last seen: 8 hours 24 min ago
How do you enter the turbo on NI40 with SBT90.2?? Instructions says double click. I have been messing with it for 15 minutes and still can’t figure out from which mode double click turns on the turbo. Was able to access it a few times though
Does anyone know?
Th558
Th558's picture
Does anyone know?
People on TLF are saying you have to take the rubber out and shorten it by 1mm to get the switch to function properly. https://www.taschenlampen-forum.de/threads/nightwatch-ni40-mit-luminus-s...
Cloud
Wow……
RageAgainst...
Last seen: 1 month 1 week ago
Interested
BaronVonEissler
Th558 wrote:
Cloud wrote:
How do you enter the turbo on NI40 with SBT90.2?? Instructions says double click. I have been messing with it for 15 minutes and still can’t figure out from which mode double click turns on the turbo. Was able to access it a few times though Does anyone know?
Unbelievable! Great quality control! Does not sound like an isolated incident, more like a defect.
I think I will sell the light to my cousin Otto just for the LED.
Th558
Th558's picture
It’s pretty easy to fix but yh it shouldn’t come like that from the factory.
BaronVonEissler
What do you mean when you say we have to “take the rubber out?”,The rubber boot off the switch? A rubber o’ring or something within the switch?
Th558
Th558's picture
The rubber that covers the switch. It seems like what they’re saying is cut 1mm of the inside part of the rubber that touches the switch.
This is the quote from Duke on TLF:
I shortened the Nubsie in the switch rubber by ~ 1mm, which was too tight for me.
Now it’s better
Have no idea what a Nubsie is. Googled it and it doesn’t seem to be a word in English or german. Well there’s no translation anyway. Maybe it’s a spelling mistake.
