change sst40 to sst20 in S2+ and add TIR optics?
13 posts / 0 new
LamontGrady
Last seen: 2 weeks 1 hour ago
I ordered some S2+ with SST40 and would like to change one to SSt20. Aside from this LED, (16mm right?) what “gasket” do I need? https://www.aliexpress.com/item/32975568763.html?spm=a2g0s.9042311.0.0.60864c4dCTEitj
7mm hole? 9mm hole? round or butterfly shape? https://convoy.aliexpress.com/store/group/Gasket-Lanyard/330416_512723652.html?spm=2114.12010608.0.0.66b67394S8jPq4
Also, do these TIR lenses just drop into S2+ for sst20, sst40, 219c, and xml2? https://www.aliexpress.com/item/1577614278.html?spm=a2g0s.9042311.0.0.60864c4db7WY0w
ggf31416
Last seen: 2 hours 39 min ago
I’m not sure the smaller SST20 will be happy at 5A.
KevinZA1988
KevinZA1988's picture
Last seen: 13 min 31 sec ago
5A is pushing it. I don’t push my SST-20 LED’s past 4.5A for turbo runs. At 4A you will be safe.
The SST-20 is in the 3535 (3.5 × 3.5 mm class).
Get the TIR optics from Yajiamei. They fit the 3535 LED’s perfectly and give a good beam. I suggest you get the 10, 15 & 20 degree optics.
LED lens Diameter 20mm Bead surface(10 15 20 25 30 38 45 60 85 degrees lens) XPE/XPG lens ,XP-G2 Lens
https://s.click.aliexpress.com/e/eG0qpt1W
No need for a gasket.
Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
LamontGrady
Interesting. Are those optics different than the way more expensive ones I linked to?
KevinZA1988
I haven’t tried the optics from Convoy, but I know Yajiamei Optics are great and the go-to single LED optic on BLF. I have many of them in modded lights.
LamontGrady
This is where I got the idea. I ordered them asking him to change to sst20 but he didn’t.
Reddit thread SST40 S2+
KevinZA1988
Why do you want the SST-20 from Convoy?
LamontGrady
Also, I assumed the thermal protection they mentioned would help?
KevinZA1988
The thermal protection does help a bit, but when the light is below the temperature threshold the LED will get full current on high mode, if the battery voltage/type of battery can supply enough power.
Nooner
Last seen: 3 hours 39 min ago
FWIW I’ve been using a 5000K sst20 in an S2+ with the newer sst40 driver and have had no issues.
I’m using it as my bicycle light. It stays on high for extended runtimes.
BlueSwordM
BlueSwordM's picture
Last seen: 1 min 4 sec ago
5A is about perfect.
What is pushing it is 6A though.
5A is about perfect for some nice brightness and superb throw from a light this size.
Ryzbor
Ryzbor's picture
Last seen: 41 min 43 sec ago
So this 21mm won’t fit? http://www.leddna.com/30-degree-frosted-21mm-reflector-collimator-led-le...
And will a Luxeon V fit under a 3535 size TIR?
virence.com rosy 3500K R9080 Wizard Pro
KevinZA1988
I don’t have an S2+ anymore, so I’m not sure if that optic will fit. I know the Yajiamei Optics fit without any modifications. And I can confirm a Luxeon V does not fit under a 3535 optic, it’s 4040. You can use a reaming tool to open the optic a bit but then you need to raise the optic a bit with a shim to make up for the lost height when reaming it, otherwise it’s out of focus. I just reverted back to a reflector for my Luxeon V.
The best results I had WITH 20mm Yajiamei beaded optics were SST-20, XP-L HI, XP-L HD, LH351D (in that order throw to flood). And I have only tested 10, 15, 20 degree 20mm Yajiamei beaded optics.
