Sofirn C8G New Version UI Fail again
14 posts / 0 new
Stefan333
Last seen: 6 days 14 hours ago
Received today the new Version of the C8G with Standby Mode and Moon Mode.
Well, to get into the Moon Mode you have to turn off the Light with the Tail Switch, use both hands to press and hold the side switch an than turn the light on again with the Tail Switch… Facepalm
Uhm, maybe they could integrate a little rain dance around the flashlight in the next Sofirn UI to go to special Modes.
Not possible to go to moon from Standby, no moon Mode in Ramping mode.
They had such a good UI in the C8F… Sad
In the future i will wait for the first reviews before buying any new Sofirn light.
mattlward
mattlward's picture
Last seen: 9 hours 38 min ago
That really does sound like a fail… on most reasonably sized lights, I think ML is a required mode. We use lights to see and if our eyes are dark adjusted and we do not have easy access to a mode that is friendly for dark adjusted eyes… it just does not make sense!
I am seriously in love with the FW1A and FW3A and D4V2, but they all missed the boat on ML mode. I have built many triples and quads over the years that have a sub 1 lumen mode just for the purpose of using them when my eyes are already dark adjusted.
I will get off the soapbox now.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Photonica
Last seen: 16 hours 32 min ago
“Hidden Eco” mode really is hidden!
Quote:
Output Selection
Group 1: With the light switched on, single click the functional switch to cycle through Low→Med→High..A fast double click actives turbo mode,as soon as the Temperature on the driver reaches on 50 Celsius,there is a stepdown to high mode.
Group 2: With the light switched on, press and hold the switch switch to ramp up and down. The range is 10LM – 2000LM, it blinks when reaching max or min brightness. Ramping changes direction when press button again within 1.5 seconds, same direction when ramping again after 1.5 seconds.A fast doubleclick directly ramps to turbo mode,as soon as the Temperature on the driver reaches on 50 Celsius,there is a stepdown to high mode.
With the light switched on, 3 fast clicks to activate Strobe mode, press and hold to cycle through Strobe-Beacon-SOS, single click goes back to normal brightness.
With the light switched on, 4 fast clicks change Group 1 to Group 2.
With the light switched off, press and hold side switch and click tail switch to activate Eco mode.
Mode memory:brightness levels will be maintained,it turns on with the remembered mode
djozz
djozz's picture
Last seen: 5 min 57 sec ago
mattlward wrote:
…I am seriously in love with the FW1A and FW3A and D4V2, but they all missed the boat on ML mode. I have built many triples and quads over the years that have a sub 1 lumen mode just for the purpose of using them when my eyes are already dark adjusted.
This is not to disagree with the entire story but the lowest mode on my D4V2 (3000K SST-20) I measure at 0.16 lumen, which I would classify as “sublumen”.
Bearbreeder
Last seen: 2 hours 11 min ago
Moonlight?
Never use it
Nor do most non flashaholics outdoors, or indoors
Cereal_killer
Cereal_killer's picture
Last seen: 4 hours 44 min ago
Bearbreeder wrote:
Moonlight?
Never use it
False. I keep a light on our night stand that literally ONLY ever gets ran in the very lowest sub lumen moonlight level. My non flashaholics wife uses it every single night…
ZEUSFL
ZEUSFL's picture
Last seen: 3 min 49 sec ago
In fireflies E07, the "momentary mode" if you click 5 times is like a kind of lock mode. the only way to get out is by releasing the tail cap. This will reset the light.
I found that awkward.
Imalent MS18
Acebeam X80-GT
Fireflies E07 x2
Emisar D4S V2 26650
LTC
Last seen: 3 hours 5 min ago
ML is subjective to individual. One might or might not need it.
Imagine you are on a camping trip in a tent with your buddy. ML will definitely be appreciated.
And many others will tell you, why do you need ML on a dedicated thrower. It’s a thrower.
Any, ML is a bonus to me. Use it when you need it.
Bearbreeder
Cereal_killer wrote:
Bearbreeder wrote:
Moonlight?
Never use it
And yet most lights that folks actually use for work and sports outdoors dont have moonlight
They get around without it just fine
99.9% of campers in tents dont use moonlight
Or i should say they dont use FAKE moonlight
LTC
Bearbreeder wrote:
Moonlight?
Never use it
Then I’m the one belongs to the 0.1%. I even use it in my room when my wife is asleep. That is what I call consideration…
ZEUSFL
ZEUSFL's picture
+1 I use the moonlight very often to don't use wake up my wife as well.
Imalent MS18
Acebeam X80-GT
Fireflies E07 x2
Emisar D4S V2 26650
mattlward
mattlward's picture
Not sure how… my FW’s and D4V2 are both way brighter than the D1 and any of my ReyLight’s on ML mode. If I hold the tail switch or side button to go to the lowest mode, it is just not that low.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
mattlward
mattlward's picture
Bearbreeder wrote:
Moonlight?
Never use it
I suspect that is due to the fact that most never see a good moonlight or firefly mode. I find that I use lowest to mid level far more than I use the upper half of the power range.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
ZEUSFL
ZEUSFL's picture
In Fireflies E07 depending if you are using ramping mode by steps the moonlight is more bright. But if having the light on you click 3 times you go to the smooth ramping and that one have a more dime moonlight (fewer lumens)
Imalent MS18
Acebeam X80-GT
Fireflies E07 x2
Emisar D4S V2 26650
