Haikelite HT70 4*SST70 6500k 17000 lumens 18650 Flashlight
GB Price: $129.99 ($199.00)
Freeme's Coupon: Reply on this thread
Can't wait for our reply??
Discounted Price: from $135.99
Coupon: BGHT70
Specification:
Brand |
Haikelite |
Light beads |
SST70 |
Color temperature |
6500k |
Lumens |
17000lm |
Range- |
1500m |
Battery |
18650(Not included) |
Size |
235 x 86 x 51mm (leght x light head x barrel) |
Weight |
840g |
Features:
1. Using four LUMINUS SST70 lamp beads
2. Can choose the color temperature of the lamp bead: cool white / neutral (the lamp is SST70 P2 grade)
3. Maximum brightness of 17000 lumens, up to a range of 1 500 meters
4. Has a tactical mode to switch between daily use or search and rescue
5. Use 2 sections / 4 sections / 6 sections / 8 sections 18650 rechargeable power lithium battery (not included). It is recommended to use 18650 3000mAh power lithium battery
7. One-handed, simple and fast operation
8. Built-in advanced intelligent temperature control settings, can automatically adjust the brightness according to the working state of the flashlight and the outside temperature
9. Compatible standard tripod interface, standard screw head
10. Lock function to prevent accidental light
11. Double-coated tempered anti-transparent purple optical lens, higher light transmittance
12. Using metal aluminum reflector
13. Aviation grade aluminum alloy military standard three-stage hard anodizing anti-wear surface treatment
Package included:
1 x Flashlight
1 x Carry Strap
2 x Waterproof O-rings
1 x Manual
Screws
