Here’s some cool stuff I want to sell. If you pay by 3pm your stuff will ship same day.
SOLD Nichia E21A 5000K R9080 quads on MCPCB from Virence
2.5A max.
Paid: $35.90 for the pair
Selling: $12 for the pair
I will leave them on the CPU coolers for an extra $8 each.
Neither has seen any real use. One is flawless, and one has a small chip on the coating of 1 of the 4 LEDs. The chip has little or no visible effect on total output. -
https://www.dropbox.com/s/9w64d7p1gcujf07/E21A.JPG?dl=1
https://www.dropbox.com/s/6lobpp0zldgyb7d/E21A%20Ref.JPG?dl=1
SOLD A pair of XM-L2 (3000K CRI 80) on 20mm Noctigon from MtnElectronics
Paid: $22? for the pair
Selling: $9 for the pair (with free zoomies and drivers if you want too. Lenses/fasteners are not shown but are included.)
https://www.dropbox.com/s/m4hfl8btcr6ezdc/XM-L2.JPG?dl=1
A pair of high capacity 26650 batteries from MtnElectronics.
One tests over the rated capacity! They are protected cells, but I bet you could remove the protection board from the top if you wanted them to be unprotected cells.
Paid: $30 for the pair
Selling: $7 for the 4770mAh one (tested at 1 amp last night on my Opus C3100)
Selling: $9 for the 5238mAh one (tested at 1 amp last night on my Opus C3100)
SOLD TS100 Solder iron and various tips!
These things are awesome! It runs on 12v to 24v. At 24v it reaches 350 degrees in like 6 seconds! Not much longer to get to 400 degrees either. I like to power them off my bench top power supply for the full 24v performance. Includes everything you see, solder iron kit with tip, plus 2 other tips. Power cord is 6 feet long. Software version 2.17. It has cool settings, including one for Left-handed people. It has some cracks in the body but feels solid and works good.
Paid: $77 for the set
Selling: $39 for the set
https://www.dropbox.com/s/irter7za4c4bllr/TS%20Kit.JPG?dl=1
https://www.dropbox.com/s/2c4zx4dg0e19fns/TS%20Screen.JPG?dl=1
https://www.dropbox.com/s/z6ytrm3wsnb6qu0/TS%20Tip.JPG?dl=1
https://www.dropbox.com/s/yj5wayb6erw67kv/TS%20Tail.JPG?dl=1
https://www.dropbox.com/s/n2hfy0qqi8p4gu7/TS%20Left.JPG?dl=1
https://www.dropbox.com/s/rfj7ckwdcd9xr24/TS%20Right.JPG?dl=1
Lenk Solder iron
Works great as a second soldering iron to create two-handed tweezers.
Selling: $4
SOLD FET Driver – 20mm from MtnElectronics
- FET Firmware: guppydrv Rev.2
- Turbo Timer: 60 Seconds
- Zener Mod?: No
Selling: $6 each
https://www.dropbox.com/s/qdis7oj0mfft4wf/Guppy%20Front.JPG?dl=1
https://www.dropbox.com/s/pz29px7f90kmtcw/Guppy%20Back.JPG?dl=1
SOLD XM-L2 (3000K CRI 80) from Mouser.com
Selling: $2
https://www.dropbox.com/s/9ixll869f5kf5cj/Mouser%20XML2.JPG?dl=1
TIR? Reflector – 21mm (front) x 13mm tall. Use for 5mm x 5mm (or smaller) LED
Selling: $2
My Spectrometer Tests:
The “pairs” can be split if anyone wants. You don’t need to buy both LEDs, or both batteries.
About CRI_Grade
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
D-C-Fix Diffuser Film
So I only created this post hours ago, but decided to drop all the prices significantly anyway. Let’s find this stuff a new home!
About CRI_Grade
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
Interested in that TS100 set and the leds (on mcpcbs only). How much for shipping to the philippines?
I can’t estimate shipping costs without your address. If you would like me to quote, PM me your address.
I PM’d you my location info in case this helps you.
About CRI_Grade
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
Only the batteries and cheap solder iron remain.
About CRI_Grade
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
Added 2 drivers to the list. The drivers, batteries, and solder iron remain.
About CRI_Grade
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
I added an LED and TIR reflector to the list. The FET drivers are now sold.
About CRI_Grade
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
The XML2 is sold
About CRI_Grade
SST-20 4000K
219b R9080 4000K
COBs_5700K_CRI95+
E21A R9080 5000K
