insane eternal Ultra High CRI & CQS Car lightning W5W T10 C5W LED lamps with TRI-R LEDs
5 posts / 0 new
SunLike
SunLike's picture
Last seen: 6 hours 54 min ago
all of this LEDs W5W (T10) and C5W are shit! =(
I try more than 10 types of W5W
some types of w5w and w10w
It will die after 1-6 month!
The most tenacious what I find was this
But after some month some of the lines of leds will die. But it will work with leftover LEDs.
Why? Because of hot. I mean it is not with aluminum pcb, it is with glass textolite what can not let heat away from the leds. And it is with ordinary smd resistors. When car is muffle – it is about 12v, when engine is work – it is about 14v. Current with 12 and 14v is different.
Also there is really cheap leds with tiny crystal and they work to the limit (works with maximum current)
I upgraded C5W by aluminium radiator 14×14×6mm, but it is also with glass textolite with poor thermal conductivity.
Now I finalized drawing the pcbs for C5W (C10W) and finally (15-20 hours) pcbs for W5W (T10) LED lamps with TRI-R 3030 smd LEDs SunLike and NSi CCR – Constant Current Regulator & LED Driver (I call it smart resistor)
How much time need to draw pcb board?
If someone interesting, C5W will cost about 5$
W5W (T10) will cost 5-10$ (depends from led quantity)
1pcs 3030 SunLike led cost 0.5$ in my web-site
BelMORDOR’s Ламповщик|Lampman
Edited by: sb56637 on 12/11/2019 - 12:14
oweban
oweban's picture
Last seen: 6 hours 14 min ago
What size festoon will that be?
I’ve been trying to find good T10 and 31mm festoon globes for SO long. Infuriating that either nobody makes ~5000K in them, or they say they do but they’re 6500K when they arrive.
Scallywag
Scallywag's picture
Last seen: 1 day 4 hours ago
A long time back, like 4 or 5 years, the best answer I found was a spring-loaded festoon adapter that ran a power lead to a square pcb loaded with LEDs. The product was aimed at RV lighting and had two other adapters included as well. Mine was roughly 4000K, though I have no doubt it is low CRI. But that may be another strategy to look into, using the adapters.
(I tested and a Google search for “festoon adapter LED” shows examples. )
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
SunLike
SunLike's picture
D12×34mm (W5W – T10)
But you can cut it to D11×29mm. And it can be without round D14mm part (with 4 leds – marked 10%G)
SunLike
SunLike's picture
My first SunLike lamp for car’s salon
Compare of size W5W D11×33mm and COB SunLike
