I recently picked up a cheap , used BORUiT RJ-3000 headlamp at a flea market. When I got home with it , I saw the power wire that runs from the battery pack into the LED headlamp housing & circuit board was hanging totally loose & not attached to the circuit board. Therefore , the BORUit is un-operable ! Looking at the power wire there are x4 wires , white-red-green-yellow, inside it. To possibly have a chance to maybe fix this , I need a diagram of the circuit board to show exactly where each of these wires are attached. Does anyone have any info ? Help will be very appreciated.
Is it this one? https://youtu.be/z8dNTSA0EGU?t=59
No , that’s not the correct one. I need the round shaped circuit board that’s located inside the center/main LED housing , which the on/off—mode selection button is attached to. Thanks for your help.
Like freeME showed , I checked youtube.com for some info about how to re-attach the loose x4 wires of the battery cord to the LED circuit board. However , the only BORUiT RJ-3000 circuit board pics and info I saw , were for the circuit board that’s attached to the 18650 battery holder/box. It’s not the correct board. I need info to re-connect the loose x4-(red,white,green, yellow) wires of the battery power cord , that leads from the battery box to the other circuit board which controls the x3 LED’s and the on/off-mode switch. Anyone has some info ?
Hey did you still need this? I need to try to fix my RJ3000, the middle LED went out, so I need to crack it open and check it out. Can try to post pix if you’re still needing it.
Hello Talysdaddy : Yes , I still need help with pics to try to repair my RJ3000.
I appreciate your offer. Thank you.
Sorry for the delay, hope this helps!
Your reply & help with pics is “Better late then never ”. Now , I’ll have to see if I can find my headlamp ,
so that I can try to apply the fix to it !! It’s been nine months since I started searching for this LED diagram
for the Boruit RJ3000. Thank you for extending the help.
