Freezing temperatures affecting floodlight Electronics
11 posts / 0 new
DOC1500
DOC1500's picture
Hey guys I don’t have the specs of the flood lights that I have out behind my house, this is a generalized question.
My multi LED flood lights behind my house appear to be a little more dim than they are in the summer.
Do the freezing cold temperatures have that much of an effect on the electronic components that drive the LEDs that would cause the light to appear dimmer ??
A lie is a lie even if everybody believes it.. The truth is the truth even if nobody believes it.
John 3:16 --
2 Cor 5:17
BlueSwordM
BlueSwordM's picture
Last seen: 8 hours 16 min ago
Do they have battery packs?
DOC1500
DOC1500's picture
No. 110 volt
John 3:16 --
2 Cor 5:17
Scallywag
Scallywag's picture
Last seen: 1 day 8 hours ago
DOC1500 wrote:
No. 110 volt
The LEDs don’t care. I can’t speak to the electronics in the driver circuit, though.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
DOC1500
DOC1500's picture
Scallywag wrote:
DOC1500 wrote:
I’ll see if I can dig up more information on the internals and specs of the lights.
No. 110 volt
John 3:16 --
2 Cor 5:17
DOC1500
DOC1500's picture
No battery pack connected directly to 110 volt
John 3:16 --
2 Cor 5:17
toddcshoe
toddcshoe's picture
Last seen: 2 hours 47 min ago
I think Scallywag was referring to the driver circuit for the LED’s. The may be affected by the frigid temps and take a while to warm up or just not work at peak efficiency in those temps. I have a LED bulb in the back porch light that takes 10 minutes to get to max brightness when it’s below freezing.
"Everywhere I go, there I am"
TexasToasted
TexasToasted's picture
Last seen: 1 week 6 hours ago
Fluorescent flood lamps are dimmer in the cold. A lot dimmer.
Lightbringer
Lightbringer's picture
Last seen: 4 hours 43 min ago
Check to make sure “110V” is actually 110V, and that nothing else is on that circuit (heaters, etc.) that’d pull the voltage low.
bobflux
Last seen: 1 day 11 hours ago
At cold temperatures:
- Electrolytic capacitors Equivalent Series Resistance (ESR) goes up (way up below freezing). As ESR increases, this is like having a resistor of higher value in series with your cap, so it will be much less effective. For example when the high voltage input cap (after the rectifiers) freezes it will no longer deliver smooth voltage so your light will flicker at twice mains frequency. If your lights do not flicker when warm, but flicker when cold, this is why.
- Ceramic capacitors with cheap dielectric (Z5U, Y5V) lose a lot of capacitance. If these are used instead of wide temperature range caps like X7R, depending on what they do in the circuit there may be consequences.
- Transistors generally don’t care, MOSFETs have lower ON-resistance when cold.
- The voltage reference in the driver which is used to set current will probably drift a little bit too
Most likely culprit is capacitors.
snakebite
snakebite's picture
Last seen: 1 day 21 hours ago
the esr of lytics rising with cold is the biggest issue.
most led fixtures use the cheapest ones that just barely do the job.
leaving no margin.
otoh the leds are more efficient cold.
after it runs a bit and reaches equilibrium none of this matters.
it might be dimmer at startup but slowly brightens as it warms up which may not be noticed.
