My old old S6 has a retainer ring that just doesn’t stick. It’s like the threads aren’t deep enough for it to bite, and as a result every time I pull it apart the switch falls out.
Any suggestions on how to keep the switch in there?
Which threads have gone bad?
If the retainer's threads are just worn out, then you might as get a new retainer.
If the tail's threads are bad, then installing a c-clip would also work (make sure to remove the anodization before installing it).
I wouldn't recommend directly soldering the PCB to the tail as it would probably fail in the long run.
