https://www.aliexpress.com/item/32996402921.html?spm=a2g0o.cart.0.0.3a363c00QbmmxD&mp=1
I bet this would offer 13,000 lumens if cooled, and no driver needed. $33. Unfortunately , 220 V.
Is there no easy way to get this board to run on 110-120V?
……….230 Lumen per watt Samsung 301b. But 30 percent loss due to on pcb driver, the money savings, so not the usual 19,000 lumens. Unfortunately, a driver, fan, heat sink costs too much, when you compare to $10 USD buying 10,000 lumens of halogen light, and Metal halide, not too far behind……… Solution, epoxy mount two on a metal can, cut steel off and mount your heat sink in the distilled water (15% antifreeze , 1% redline water wetter for corrosion resistance.). You would get 1.5 hours at 200 watts using a gallon can. This could be extended with a pir and dimmer. You would have a $80-$90 26,000 lumen light in a compact form factor that wouldn’t take up too much space on a truck. Not enough with which to really paint a wall with 100% confidence, as 80,000 is really the bare minimum. But with two, you could paint half a wall, or a bathroom. And have a respectable light. Once price drops, I would make four using 8 of these boards. Not because I need to, but because I can (in future).
