FW3A Anduril firmware version?
10 posts / 0 new
USLight
Last seen: 2 days 3 hours ago
For the FW3A, have there been different versions of the Anduril firmware released throughout production?
I get the impression there has been some tweaking by ToyKeeper as things have evolved …
If so, is there a way through the UI to ascertain which version is currently flashed on my FW3A?
It was ordered through Amazon from Lumintop Direct on 18-Jan-2020.
Thanks!
P.S. Is it me or does the gray FW3A anodizing have a blueish tint? Maybe it’s just the lighting …
anonymous_user
Last seen: 1 hour 44 min ago
If your Andruil is new enough to have the version check, then you can access it by doing 15 clicks from off. It will blink the version number in the format YYYY MM DD.
https://www.youtube.com/watch?v=mrAM7HylEA8
USLight
Thanks “anonymous_user”! Unfortunately it looks like the firmware version on my FW3A is not new enough, 15 clicks didn’t do anything. Sad
USLight
Was it a conscious decision to leave the firmware version check feature out for the FW3A (if so, why?), or was it something that was just added later after the FW3A was released.
SammysHP
SammysHP's picture
Last seen: 2 hours 11 min ago
It was added later.
atobe
Last seen: 15 min 7 sec ago
It was added to Anduril after (Oct, 2019), FW3A was released in summer 2019 time frame I think. I don’t think lumintop is doing new firmware on current productions either. So they should all have the same firmware.
ᕦ(ò_óˇ)ᕤ
USLight
Well I have to say that I haven’t really had the FW3A for long but have exercised many of the features and so far haven’t had any problems – everything has worked perfectly so far.
Hats off to Toykeeper and the rest of the FW3A team and thanks for all their efforts! Thumbs Up
Noir
Noir's picture
Last seen: 6 hours 15 min ago
For older Andúril versions that don't have the version check function yet, it's possible to determine the version with the help of the features it has. Here is a very helpful post made by d_t_a which lists features and the firmware dates when they were introduced.
Lumintop currently seems to be shipping lights with 2019-06-27 firmware, the FWxx lights that I bought in the last three months all came with that version (i.e. with reset function, but without version check function). I have had older lights, like my FW3C, that came with 2019-05-22 firmware, and of course the very first FW3A lights came with an even older firmware (without 2-level lockout).
d_t_a
Last seen: 11 hours 11 min ago
I’ve tested FW3A with different Anduril versions — I can’t be too sure which exact Anduril firmware, but they are by trying out Anduril functions that were added.
Eg. my first FW3A doesn’t have the manual/automatic memory toggle (I believe this is the 2019-05-22 firmware).
Next FW3A has manual/automatic memory toggle (so it’s newer), but doesn’t have the “factory reset” function.
The latest FW3A I ordered now has the “factory reset” function (via 13 clicks-hold), but doesn’t have “firmware version check” function).
So it looks like Lumintop does install new firmware when it’s available (as Toykeeper mentioned when I asked her). (Installed Anduril version may not always be the very very latest available firmware, but at least they do update it regularly)…
USLight
Looking forward to the day when it is trivial to upgrade flashlight firmware to the latest version.
