Sugestions for a house lantern
12 posts / 0 new
hammerJoe
Last seen: 1 month 5 days ago
Its not unusual for the power to go out in my area and I would like to get a couple of led lanterns to replace candles for these situations.
What would you advise to get?
Edited by: hammerJoe on 02/06/2020 - 00:09
raccoon city
raccoon city's picture
Last seen: 2 hours 3 min ago
I would think the BLF LT1 or the upcoming BLF LT1M-Mini, depending on how large of a lantern you want.
Lightbringer
Lightbringer's picture
Last seen: 21 min 27 sec ago
The old Zanflare T1 was nice (got 2), but they were discontinued then resurrected under another name.
Maybe someone has more info about those…
hammerJoe
I think a small portable lantern that could light a medium size room that could last for hours would be fine.
Serlite
Last seen: 14 hours 3 min ago
If it’s indoors with rooms painted in light colours, you could also get away with ceiling bouncing a normal flashlight to light up a room instead of getting something more specialized like a lantern.
Something that runs on a 26650 like the Sofirn SP33 would be my choice in that case – it was invaluable during my last power outage.
hiuintahs
Last seen: 2 days 16 hours ago
If indoors just use a flashlight with ceiling bounce. If it won’t tail stand place in a mug. For outside, need to use a lantern because there is no ceiling. I prefer the ceiling bounce to a lantern. For that reason, I only have two lanterns, whereas I have many more flashlights.
gravelmonkey
Last seen: 3 hours 32 sec ago
Get a combination of slip on diffusers for lights you already own and a blf LT1 lantern.
Keep in mind that small lights running on high brightness setting will get super hot.
Head lamps are most efficient as they only put light where you need it, but also most inconvenient/uncomfortable.
For home aesthetic and backup power outage lighting, I really like battery powered fairy light strings, most have simple user interface, OK runtime between battery changes and the distributed nature of the light causes less glare than a single point source.
raccoon city
By the way, on AliExpress, there are a bunch of cheap diffusers that fit the Convoy S series and the BLF A6.
Vegas LED Fan
Last seen: 2 days 20 hours ago
There are lots of simple light strings using 3mm LEDs that operate off 3 AAA cells. You could power them with 18650 Li-ion batteries instead if you are into simple DIY. A single 18650 cell or several cells in parallel will light the light string for many hours. I know this works because I retrofitted some Christmas decorations that relied on 3AAA cells to operate on a Li-ion battery.
The electricity almost never goes out because we have underground utilities. I have a couple of tent lights and three of those small collapsible lanterns (3 COB strip type) for emergency lights. You would want to put a diffuser inside globe of the collapsible lanterns to reduce the harshness of the light. They are so cheap ($5 on eBay) as to be considered throw away lights. The tent light shown below runs on a single 18650 battery or 3 AAA batteries, has 3 brightness levels, and 60 LEDs for the brightest. I looked at the current price from eBay sellers in China and it costs $5 with shipping. It will light a large tent so would light a small room quite well.
Agro
Agro's picture
Last seen: 47 sec ago
I second that, as long as you have enough flashlights.
Diffuers are not great, though they are the most budget-friendly option.
LT1 is great but quite expensive, especially if you need several.
LT1 in the living room with flashlights elsewhere would be a fine and moderately priced choice.
If you have a powerbank and would like to use it for illumination,
string lights like https://www.aliexpress.com/item/4000516832224.html are a good option.
FollowspotDude
Last seen: 1 hour 44 min ago
I have quite a few LED lanterns which I’ve bought over the years. Sadly, some of my favorites (Fenix CL20) aren’t made anymore. I’m a fan of the Mr. Beams MB480 lanterns. Runs for 30 hours (high) on 3 D cells. It’s best attribute is the lovely 4000K neutral white light it puts out. It feels far more cozy than the cheap, nasty blue-white lanterns you’ll find everywhere else. And when the price is right, they’re under $20.
I did order the BLF LT1s, but I haven’t received them yet…and for the occasional user they’re overkill.
cm64
Last seen: 6 hours 45 min ago
@FollowspotDude
The LT1 is a bit overkill BUT they are very nice Sad Sad
