convoy c8+ tubes on s2+
5 posts / 0 new
forsh
forsh's picture
Last seen: 36 min 37 sec ago
does anyone have info if a convoy c8+ tube would fit a s2+
same threads or what
also does anyone know what thread they are
im thinking making steel tubes as a test
thanks all in advance
chris
best wishes from finland
Convoy mad
Convoy c8 x4
convoys s2 x2
FW1A pro
Henk4U2
Henk4U2's picture
Last seen: 7 sec ago
They definitely do NOT fit.
Following numbers are a bit ballpark because I only have an (old) set of calipers.
Especially the pitch. Using a gauge on the pitch of the tube would be a better idea.
S2: OD=21.8mm pitch=1.3mm (maybe 1.25)
C8: OD=22.8mm pitch=1,5mm
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Hank33
Hank33's picture
Last seen: 11 hours 41 min ago
Hi forsh, did you get your S2+ host from Kaidomain and/or the Convoy one? I’m just wondering if the Kaidomain S2+ host is same material/quality as the Convoy S2+??
“The true mystery of the world is the visible, not the invincible.”
forsh
forsh's picture
S2+ is on its travels to me , I think it’s original convoy and all my convoys are original convoys
I did buy a s2+ from bg also and that also on its travels
More updates in the next few days
I’m planing to make a few tubes out of stainless and normal steel , I’ve access to a mill and lathe at work , and lots of thread making tools and gauges , I’m pretty average at welding and pipe work , out lathe is a dirty old beast so making threads with it would be a bit hit and miss , but we have pipe threading dies from small to massive
More updates to come
Convoy mad
Convoy c8 x4
convoys s2 x2
FW1A pro
Hank33
Hank33's picture
Sounds good and looks like you have lots of fun activities coming up! Have fun Smile
