Rating: Manafont.com [RECOMMENDED]
http://Manafont.com
RECOMMENDED
Pros:
- Nice selection of some unique flashlights
- Excellent live chat support
- Courteous, professional, intelligent employees speak excellent English
- Responsible, prompt, professional handling of RMA issues
- Detailed product descriptions with excellent photography of flashlight features
- Generally very fast turnaround time from order to departure from warehouse
Cons:
- Selection of flashlight products still not as big as the mega-retailers
- Some advanced search and sorting functions on their website would be nice
Quick tip: More stuff is coming, if the manufacturers cooperate with them. :-)
I am going to buy something, I just don't know what it is yet.
Add the pro - have supplied review lights. this has to be a good thing!
I just used a great part of my meager pension to buy the
Ultrafire C3 Cree XP-G R5 1 Mode (AA/14500)
and I must say Im impressed with the fast shipping and good communication.
So far so good. If its the norm for the rest, it looks good, but one have to see.
Let us know, how the cheapest XP-G light on earth is ... once it arrives. (especially the O-rings
Shipped this morning - decided I really wanted this one.
Don ... how do you afford all these lights? ... robbed a bank, sold your soul to the flashlight-devil, or won the lottery?
And that's likely to be it for this year unless something really interesting (and cheap) appears. I do like C3's so that one was hard to resist.
There are so many Ultrafire C3s out there. Some are Q5 other are Q3 and XPG R5.
I do think there is XP-C also.
And probably others too. But the body shape is unmistakeable - and often the build quality unacceptable. The recent aluminium one is a very good light, and I have hopes for the R5 when it arrives in another week or so - it was shipped a week ago and two weeks is typical for HK Post to here.
There have been some stainless steel ones with the XP-C, and various Aurora clones with another wild assortment of emitters - the three Aurora C3 clones I have have XP-Es (Claimed Q5s) in them and lousy build quality even by C3 standards. One of them also has the greenest Cree I've ever seen.
The Ultrafire X1 Has memory mode but you have to wait
1minute and 20 seconds.
Always starts on high.
Told Manafont about the problem they have done nothing, they have not changed the product description
even after I have told them about the issues.
The Skyray S-A5 is brighter and better, it also has perfect Memory Mode.
Received my order from Manafont a couple of days ago, 2 bodies, 2 drop-ins, and a couple of 18650 cells (Ultrafire 2400mAh, protected). The 504 and 501 bodies are good, and the drop-ins work well, but the cells are a bit of a disappointment - they are described as protected, but they're not, no protection pcb to be seen.
Anyway, the cells are supposed to be 2400mAh, so I charged one to 4.2V on my Swallow 2, (cutoff at 0.05C) and gave it a discharge at 1 Amp - I got a whopping 201mAh out of it! Voltage started at 3.7V under discharge, so it was obvious something was wrong fairly soon. No wonder it looked a bit dodgy in one of my lights! I have a couple of Trustfires, 2500mAh (actually protected) which deliver very close to their rated capacity under a 1A load.
Well, I guess you can always get a faulty cell, but I'm a bit miffed that they don't have a protection pcb as advertised. I'll test the other one tomorrow and post results.
Edit: I forgot to mention, the drop-ins were very well packed - wrapped in bubble wrap and put back in their blister packs.
Cheers
Well, I just finished testing that second cell - it returned 1207mAh. So it seems like these cells are junk! I definitely won't be buying any more.
I think I may have found the reason for the dismal performance of the first one. These cells have been "reclaimed" from battery packs, and have a plate spot-welded on to each end, to cover up the old spot-welds after the tabs have been ripped off.. There was a substantial dent, hidden underneath the plate on the negative end, which must have caused some damage inside the cell. Anyway, live and learn!
Cheers
Recieved order from manafont!
This should go to dealer rating:
- Fast response
- Fast shipping
- Excellent english support with email notification for every step they make (not needed but very neat)
- Outstanding care in packaging and packaging method
- Goods were in perfect mint condition
Thumbs up!
I bought:
504B body (new design)
Ultrafire r5 1 mode dropin
30 leds ornament blinking thing powered by an 3x AA holder. Still can't belive it was only 2,88$
I bought:
Got the same 2 products. The drop-in work better with 2 batteries(8.4v) have not tried with anything higher.
The body is good, nice tight fit but not that deep.
The 504B body is perhaps a bit longer than expected and unprotected 18650 fits barely, a protected one is a much nicer fit.
Not really a fan of dual RCR123 setups. Too much potantial trouble if one cell gets damaged or em i being overworried?
I like the beam on the wall very much. Have to add tin foil for better heatsinking the dropin to the body since in stock form there is quite a gap.
Manafont carries the Lumapower MRV SE for $18.65 shipped, which is a little cheaper than wsdeal ($20.26 shipped) if buying a single flashlight. I haven't tried Manafont yet, but it looks like the same flashlight.
http://www.manafont.com/product_info.php/mrv-lg104-q5-5mode-q5-led-flashlight-p-1744
It's best to buy from focalprice($20.80) as they are the retail site of wsdeal. No-one has complained about quaity issues.
http://www.focalprice.com/LF522B/MRV_Super_Bright_LED_FlashlightTorch_Bl...
Any particular reason to like Lumapower MRV SE or it is just personal preference?
Who is your question aimed at?
It is bright, it throws remarkably well, it has a nice low which will run for around 36 hours from an 18650. It is smaller than anything else I have that throws that well - it fits in a holster used for a P60 light.
It was (briefly) available for $5 plus shipping. For the cost of a single cheap 18650 cell you got a very good light. See here for details. I will write up a review some day.
"Who is your question aimed at?"
Anyone who might got an idea.
Don took care of the explanation that would be hardly told any better.
The MRV is probably the tightest thrower for that price.
After my earlier posts (#13 & 14) Jim from Manafont emailed me directly, and said he'd learned from BLF about my incorrectly described and faulty cells, and offered a refund or exchange. I replied requesting a store credit for a future purchase, and a few hours later, it's been done.
Now that's service you can be happy with!
Cheers
@didge
Very nice, thanks Jim for putting your customers first!
Manafont is really putting effort to be the one of the best retailers if not the best.
I emailed them about the "write a review issue" which shows the reviewer with full name which actually bothers me a lot! I hope they can solve it or i believe there will be not much reviews going on.
I would never agree to post a review under my real name.
I never use my real name in the internet at all, exept for my personal email. I use an inkognito email account for logon to forums. In the one, I use for this forum for example, my alias name is Hans Meier, which is a very common german name as like John Smith would be in english locations. Also I never post pictures of myself ,my home or family members. My privacy is the most expensive thing I have.
And surprise! They solved it in less than an hour. Impressive.
Looks like Manafont is keeping a close eye on BLF. BLF ROCKS!!!
Yikes! Thanks for mentioning it. Hopefully they'll put this on the top of their TODO list. Please let us know if it gets resolved.
Ok, that's a good start. Could a representative from Manafont please let us know when the security bug has been fixed?
Thanks.
Wouldn't this only be a positive for you since he pays and you get the light?
This is the problem:
http://forums.oscommerce.com/topic/330479-what-is-the-oscsid-why-you-mus...
Your link to the c3 r5 contains the osCsid in the url. Unfortunately, they use paypal address so no free light for you.
First of all, that is not my link. It is from this thread from Vectrex: http://budgetlightforum.cz.cc/node/718
Second of all, I'm not trying to get a free light. Seems like you're trying to accuse me of something?
You really got some personality problems.
Ah! Thanks agenthex, that's part of the problem. I wonder if Oscommerce has found a workaround for that, because it's inevitable that sometimes users will post their session ID by accident.
I jest.
Is something wrong with my links? I just copied them from Manafonts page... can't find anything wrong in them.
@Vectrex:
I just now changed the link in one of your posts that ended in something like osCsid=defw422r43tWEFm34352. It appears there is an issue with the catalog software they are using that it applies user information based on the session ID, which is part of the URL.
I am trying to get the osCsid to show up on my URL at Manafont now, and it's not appearing. I wonder if they fixed this already?
Ah, OK... thanks.. wasn't aware of that problem... I don't even have an account there... I wonder what user information is in there
What probably happened is that Vectrex posted the link, however he never bought anything (it's a psudorandom, but unique id). But midieval came along, used the linked, maybe bought something/created an account, and the id is now associated with him forever and ever. Now someone else used the same link/sid and they're using midieval's account. [Un]fortunately, MF rely on paypal's info for payment/shipping, and we mostly miss out on the lulz.
However, people can still have fun with that original link if they have it cached...
I'm not sure midieval10 would like that..
Surely as committer of the original sin, you can see the humor in the cascade of events you've caused.
Well, it's one thing if it's an honest "mistake" (mine) - which was caused by an imperfect software on Manafonts (original sinner) page... the login should always be required. It's a completely different thing to purposely post ways of using the now corrected error in a way that is causing potential problems for one or more users of this forum. (and someone might do it)
You Sir... have a strange definition of humor.
Gasp, a German who lacks faith in schadenfraude.
On the internets, we are all Germans. Ich bin ein Berliner.
I'm already feeling bad enough for indirectly causing trouble...even if it's not my fault. The post you posted would have certainly crossed a line for me, if I were midieval10. But we are likely on very different pages, when it comes to practical jokes. Maybe I'm a bit touchy when it comes to accusations on flashlight forums (even if it is supposed to be a joke)... but remember the history why BLF exists in the first place...
I'm already feeling bad enough for indirectly causing trouble...even if it's not my fault. The post you posted would have certainly crossed a line line for me, if I were midieval10. But we are likely on very different pages, when it comes to practical jokes. Maybe I'm a bit touchy when it comes to accusations on flashlight forums (even if it is supposed to be a joke)... but remember the history why BLF exists in the first place...
I don't find agenthex's "jokes" funny at all. He keeps trying to funny, trying to go on and on about a serious matter. I was trying to point out a flaw in the system and all he does is try to exploit it.
It's not your fault, Vectrex, that this happened.
Jebus Chris, absolutely nothing of import happened. At worst, you'd have a gotten a free light, since MF has to mail another one to the other user. The lackluster humor of the original situation was quickly overtaken by that of your overreaction to it. Your fortune in this regard has been that you didn't highlight this in a real den of wolves like somethingawful or god forbid 4chan.
Y so srs?
Just imagine... what would have happened if hundreds had used the link and Manafont weren't so quick and unbureaucratic... and Christmas time is coming ... are you gonna dry those teardrops of children not receiving the cool flashlight they wanted?..
Wow, that review alone makes me want to order something from Manafont. So what do I order? Hmmmmmmmmmm......
Don wrote:
"But as I said long ago, you are more likely to be killed by a dead fish dropped by a seagull in the Sahara Desert than by a lithium ion cell going bad."
