[Review] Lumintop GLOW I
1 post / 0 new
Mocarny
Mocarny's picture
Last seen: 20 hours 56 min ago
Lumintop GLOW I
At the end there will be a Summary for those who like only particulars, in each topic I will bold the key sentences, or maybe color them too for better reading experiences Wink Enjoy!
Obrazek
For VERY large photos: click -> on the photo page right click -> "Open image in new tab"
I got this flashlight from Lumintop for review:
Table of Contents:
- General parameters
- Package content
- Appearance, parameters
- UI, runtime and charging
- PWM
- Waterproof
- Light pattern, tint
- Usage and my experiences
- Nitpicking
- Summary
General parameters
(copied from Aliexpress page)
Product Feature:
Dutch Imports Turbo Glow head with over 2 hours long lasting glow, easy to find the light in the dark
Utilizes LED with 50000 hours lifetime
Magnetic tail cap enable for hands-free
Built-in Micro USB rechargeable with indicator, no need to remove the body with charging
Large keychain hole for a keychain or lanyard carriage
One mode 40 lumens with 1 hour 10 min max runtime
Built-in 3.7V/80Mah 10180 Li-ion battery, 57 min to fully charge
Handy and light-weight, size 47.4*14.5*12.1mm, net wight 16.1g including battery
TIR optical lens creates a soft and balance beam
Make of aircraft-grade aluminum alloy with military-grade type III HA matt finish
IP68 RATED DUST AND WATERPROOF PROTECTION, IMPACT RESISTANCE TO 2 METERS
2 Years free repair, limited lifetime warranty
Accessories:2*O-ring, 1*Keychain, 1*User manual, 1*Charging cable
Package content
Simple cardboard box, eco friendly, I am a big fan of this type of packaging
Obrazek
Inside:
Obrazek
- Keychain
- 2 spare o-rings
- USB charging cable
- Manual
Obrazek
Obrazek
Tailcap is removable, it holds only on magnet (very strong magnet)
Obrazek
Obrazek
After detaching the tailcap, you can attach a flashlight by it's magnet. Holds tight.
Obrazek
But even without detaching the tailcap you can "stick" it. Holds loosely, but still holds.
Obrazek
Obrazek
You can also detach this glowing bezel, and spare o-rings are for this part.
Obrazek
If you want to know:
Obrazek
Yes, it can tailstand, especially after detaching the tailcap. But it is not meant to be a tailstanding flashlight, as EDC Pico.
And this turbo glowing gasket is some kind of ancient Maya technology, they were making dose even before making their famous calendars. I compared it here to famous glowing FW3A gadget.
Obrazek
After 7 min
Obrazek
After 25 min
Obrazek
After 45 min
Obrazek
And the Glow is so much better than the FW3A gadget (brighter, glows longer)
UI
1 mode 40lm. Turn on by tightening the tailcap. To be honest, I like 2 modes EDC Pico more, but on the other hand, here it is simpler, just 40lm. It is enough for every keychain light situation.
Runtime
Obrazek
Brightness drops slowly for an hour, to 50%, then drops quickly
Charging
Build-in charger, micro USB. To charge you need to unscrew the tailcap part, but both parts are holding together (different and better than in EDC Pico)
Charging indicates by a red light
Obrazek
Fully charged indicates by a green light.
PWM
I did not notice any
Obrazek
Waterproof
Uch, did not check... Declared IP68 so great. If it is the same waterproof as EDC Pico (probably yes), then great. But When unscrewing it to charge, I broke one o-ring and now it is not waterproof anymore. Some manufacturing problems, maybe sharp things inside cut this o-ring, it was not my fault. But it broke before waterproof test.
Obrazek
Not good...
Lumintop told me they will fix this problem. Let me know if you hat this issue.
Light pattern, tint
40lm and the beam pattern
Obrazek
TIR optics, the same as in EDC Pico. Because of this glowing gasket, a beam is slightly greenish on the edges.
Obrazek
Obrazek
Obrazek
It is just a good keychain light. Nothing more to say. I am enjoying this glowing gasket, because it glows very bright and long. Strong tailcap magnet can be very useful too. 40lm is not that much, but just enough for keychain light. I think I will gift it to my brother. Smile
Nitpicking
Everything about all shortcomings
1. After unscrewing it several times, the o-ring was cut in half by some sharp things inside the flashlight. Lumintop told me they will fix this issue, but if you break this o-ring, they will send you a new flashlight.
2. Tailcap holds on only by magnetic force. I don't trust it, because it is not as secure as a thread. But maybe I'm weird.
Summary
Lumintop GLOW I has a good glowing gasket, advertised as special army technology (special ancient Maya army technology. Special ancient Maya technology in parallel universe). It is really good, to be honest. Glows long and bright. What else? One 40lm mode, cold tint, micro-USB charging, strong magnet on the tailcap and price ~ USD23
Do i recommend it? For USD16 you can have EDC Pico that has 2 modes, is brighter and...and...idk. But for me it is worth buying only if you like glowing gadgets and like to have a strong tailcap magnet in keychain lights.
Pros:
+ Strong magnet
+ Good quality glowing gasket
+ When charging now you don't have to split it into two parts
Cons:
- In my case, o-ring was cut in half when unscrewing the tailcap for charging
About host - threads, knurling o-rings and so on
If they fix an issue with this o-ring, then Rating: 9/10
If not, then Rating: 5/10
About light - Tint and so on
Rating: 7/10
1 - very bad flashlight hurts to look at, terrible quality, not worth any (even very low) price
5 - average flashlight, at a reasonable price - for the average person "great". Or better flashlight, but overpriced
10 - flashlight meets all my expectations in a given category (e.g EDC, headlamp, thrower), it's durable and neatly made, perfect light tint, worth its (even slightly inflated) price - just pure perfect, so I doubt any light can get a 10 from me
I hope you enjoyed!
Edited by: Mocarny on 03/17/2020 - 13:56
