Test/review of Shockli IMR14500 1050mAh (Orange) 2020
28 posts / 0 new
HKJ
HKJ's picture
Last seen: 11 hours 2 min ago
DSC_2399
Official specifications:
  • Nominal Voltage 3.7V
  • Capacity: 1050mAh
  • Maximum current: 12A
  • Chemistry: LiIon
Shockli%20IMR14500%201050mAh%20(Orange)%202020-info
This is a very high current 14500 battery.
DSC_2397 DSC_2398
DSC_2400 DSC_2401
DSC_2402
DSC_2403
DSC_2404
Shockli%20IMR14500%201050mAh%20(Orange)%202020-Capacity
The two cells matches very well and can deliver a lot of current.
Shockli%20IMR14500%201050mAh%20(Orange)%202020-Temp-7.0
Shockli%20IMR14500%201050mAh%20(Orange)%202020-Temp-10.0
Shockli%20IMR14500%201050mAh%20(Orange)%202020-Temp-15.0
Shockli%20IMR14500%201050mAh%20(Orange)%202020-CapacityTimeHours
Shockli%20IMR14500%201050mAh%20(Orange)%202020-Energy
Shockli%20IMR14500%201050mAh%20(Orange)%202020-PowerLoadTime
Shockli%20IMR14500%201050mAh%20(Orange)%202020-TripCurrent
Shockli%20IMR14500%201050mAh%20(Orange)%202020-Charge
Discharge-Shockli%20IMR14500%201050mAh%20%28Orange%29%202020-pulse-0.5%2010%2010-IR%20backup
Conclusion
This looks like a new generation of 14500 cells with both higher capacity and higher current.
It is a good battery.
Notes and links
The battery was supplied by shockli.com for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
BaronVonEissler
BaronVonEissler's picture
Last seen: 1 week 8 hours ago
Thanks.
Looks like a great battery. No other 14500 battery on your comparator comes close to the amount of current it can draw.
You can't hide me from me.
EasyB
Last seen: 3 hours 53 min ago
Thanks, this is a big step in 14500 performance. Looks like similar IR to the windyfire 600mah which has been the best high drain cell, but with capacity that rivals the best available.
MascaratumB
MascaratumB's picture
Last seen: 5 hours 36 min ago
Thanks for the test HKJ!
I guess this will be a good contestant to the Vapcell H10!
Any clue when this will be available? Evil
AliExpress doesn’t have it yet Silly
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3/ 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Superstocker
Superstocker's picture
Last seen: 2 hours 37 min ago
Thanks HKJ! It looks like a really good cell.
SKV89
Last seen: 51 min 24 sec ago
Just when I thought 14500 couldn’t get any better with the Vapcell H10A. This is just crazy! I hope the manufacturer could use the same formula to make a 26650 cell! I think we can get 7000mah at 30A+ !
JaredM
JaredM's picture
Last seen: 7 hours 59 min ago
+100
Th558
Th558's picture
Last seen: 14 hours 18 min ago
Same as Vapcell H10?
Ventsi
Last seen: 21 hours 30 min ago
Thanks for the review, HKJ!
Are you gonna be testing the Vapcell H10 as well? From other reviews it seems like it has more capacity than the orange Shockli, it would be interesting to compare their voltage curves.
HKJ
HKJ's picture
I do not know about H10, but I have a L10 from Vapcell.
djozz
djozz's picture
Last seen: 1 hour 6 min ago
The L10 is rated for1050mAh/3A while the H10 is rated for 1000mAh/10A. I’m not a battery expert but given that they have similar specs and are released in the same period I would expect that the H10 and this Shockli are the same cell.
Ventsi
Seems like it for sure. However someone made a test of the H10 and reached close to 1000mAh, actually it surpassed 1000 at 0.1A, iirc. Although it could be because of different measuring equipment, that’s why I love HKJ’s website, where everything is tested in the same conditions.
The orange Shockli can’t even reach 950, should have been marketed as 950 and not 1050 for sure.
SubLGT
Last seen: 36 min 51 sec ago
The H10 has been tested here:
Test Vapcell H10
Quote:
This is a decent cell but I recommend staying under 7A/20W for better performance and less voltage sag.
The capacity for the two Vapcells I tested was 957mAh and 958mAh at 200mA (0.2C) down to 2.5V.
DC Internal Resistance = 39.9mOhms (milliohms) average for the two cells.
Ventsi
It’s also important to see the curves, I think.
For example the Samsung 30Q might have less capacity than 35E, but the way it holds voltage under load means it’s actually better than the 35E for everything that requires even remotely high drain. Not only that, but the 35E’s higher capacity only shows below 3.0 volts, at that point any flashlight enthusiast would be charging their battery already.
I’m not a specialist though, I just find HKJ’s graphics really interesting and helpful.
Barkuti
Barkuti's picture
Last seen: 7 hours 20 min ago
Not much else to say besides SubLGT and djozz's comments. Even if the angle shots aren't the same, it can be clearly seen that both Vapcell H10 and this badly overrated Shockli cell come from the same OEM and are the same cell with certainty. Any differences arise from the different test platforms and/or battery grades. The top cap shape tells me the battery OEM is Heter.
From a responsible and professional point of view, the ratings of these cells are what Mooch already said: 900 mAh and 10 A. 900 mAh is a minimum capacity value which any cell should meet, whereas 10 A is the highest current for which the discharge curve still looks 0K.
P.S.: 1050 mAh and 12 A? That's enough Facepalm Shockli, that's enough.
Wed, 04/01/2020 - 22:05
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Ventsi
Is Heter a good brand? First time I hear about them.
Barkuti
Barkuti's picture
Ventsi, Heter is one of the big battery manufacturers in China. There are others like BAK, Lishen, Power Long Battery, and some lesser players like Yongdeli. Heter may not be the biggest (don't really know), but they have fairly good technology. Enerpower properly rewraps some of its cells, check Test/review of Enerpower 18650 3.2V 1800mAh (Blue), for example. You will clearly see the same top pole geometry, manufacturers usually stick to just one or two top pole geometries, as far as I know.
Ventsi
Thanks, didn’t know.
SKV89
I think they are likely not the same. I had the same assumption when Shockli released the black 1000mah shortly after Vapcell relesed the gold 1000mah. But when I tested the Shockli, it was much higher current but lower capacity.
Comparing the HKJ’s graph and Mooch’s graph, the Shockli makes about 840mah at 10A and 820mah at 15A whereas the Vapcel H10 makes 800mah at 10A and 755mah at 15A. Though they are measured using different equipment but the difference is pretty significant to believe they are different cells.
!https://lygte-info.dk/pic/Batteries2012Small/Shockli%20IMR14500%201050mA...(Orange)%202020/Shockli%20IMR14500%201050mAh%20(Orange)%202020-Temp-10.0.png!
!https://lygte-info.dk/pic/Batteries2012Small/Shockli%20IMR14500%201050mA...(Orange)%202020/Shockli%20IMR14500%201050mAh%20(Orange)%202020-Temp-15.0.png!
Barkuti
Barkuti's picture
SKV89, embedding images whose links use special characters doesn't works in the simple post editor.
The temperature difference is also huge (I wonder how did Mooch hit such high figures). But still not very meaningful in my opinion. Once HKJ tests the H10, we'll have a better picture.
In any case, I still believe both H10 and this cell come from the same OEM. This is a niche product, and the manufacturer may not be stringent consistency wise. There are other variables which may affect results, I tested some batteries in an EBD-M05 some weeks ago and found myself surprised with the differences I found versus HKJ's comparable cell curves. My testing room was at 16 - 17 °C, while HKJ tests at 25 °C ambient, now that I think of it.
But well…
SKV89
Thanks for fixing it! You have good points. I will buy some to test and do hope I will be pleasantly surprised like last time with the Shockli 1000mah 3A.
Scallywag
Scallywag's picture
Last seen: 1 hour 24 min ago
Damn, and I just recently got my 1000mAh black Shockli 14500s in. Well, at least those are native button-tops.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
berfles
Where can I buy these? I don’t seem them on their web site.
moderator007
moderator007's picture
Last seen: 1 hour 36 min ago
The Vapcell H10 has been restocked at Liionwholesale.
Ordered several a few days ago Thumbs Up
Chatika vas Paus
Last seen: 11 min 55 sec ago
Out of curiosity, I asked when it will be available on Ali
“hello, maybe at the end of next month”
Sari33
Last seen: 11 hours 58 min ago
How are currently the Sofirn 14500?They was in review 2 yar ago
Thanks
d_t_a
Last seen: 33 min 28 sec ago
Sari33 wrote:
How are currently the Sofirn 14500?They was in review 2 yar ago Thanks
Sort of off-topic for this message thread.
I’ve bought a number of Sofirn flashlights with batteries included (usually I take the battery option since batteries cannot be shipped to our country as is, and has to be included with a flashlight)..
I’ve had quite a number of Sofirn batteries now, and I generally do capacity test and compare them (do capacity test, measure AC IR with YR1030 resistance tester, and measure their weight with a digital scale). I hadn’t really done measuring of dimensions (diameter/height) — all some are visually different.
In my limited experience, Sofirn uses different batteries under the wrapper. I’ve detected at least 3 different types of Sofirn “4000mAh” 21700, at least 4 different types of Sofirn “5000/5500mAh” 26650 and maybe 3 types of Sofirn “3000mAh” 18650s. Sofirn labels their 14500 “900mAh”, I haven’t compared Sofirn 14500s much, but I’ve noted they come in slightly different “sizes”, some Sofirn 900mAh 14500 are a bit shorter, some are a bit taller, and while usually the capacity test range from 800-900+ mAh (using MC3000 to do capacity test). So it’s likely a bit difficult to say which “Sofirn 14500” one will be getting, as it changes over time..
Chatika vas Paus
They were supposed to be available at the end of June, and they are still not available. Anyone know when it will be available for sale?
