groupbuy: Astrolux S43/S43S copper with LH351D high CRI
13 posts / 0 new
M4D M4X
M4D M4X's picture
Last seen: 24 min 37 sec ago
Hello my dear friends!
Today i present my latest groupbuy!
feel free to ask questions or post your opinion below
for all 4 versions you can use my
Code: MC8A6 to receive 20% OFF
all 4 share the same base features – please use my shoplinks for detailed Info!
Product name: Astrolux® S43(S Copper) New LED Strong Light EDC Flashlight
Brand: Astrolux
Model: S43S
Emitter Type: NEW:  4x LH351D
 4x XP-L HI
Driver: NarsilM V1.3
Output: LH351D: 3500lm continuous, 4000lm max with high CRI95
 XP-L HI: 3600lm continuous, 4600lm max
Light Temperature: 3 options:
 LH351D 5000K neutral white
 XP-L HI 5000K neutral white
 XP-L HI 6500K cool White
Range: 184 Meters
Mode: Including Default UI and Alternative UI.
Detailed operation instructions, please see the following 2 instructions.
Lumens: 0%-100% Lumen
Battery Configurations: 1x 18650 or 18350 Battery (18650 included)
Working Voltage: 2.8v-4.25v
Material: Aerospace grade aluminium alloy
Waterproof: IPX6 waterproof
Color: Black
Weight: 60g without battery
Size: 88.7mmx 27mm (Lengthx Diameter)
Feature Functions: – 4 LED Bulbs
– Battcheck mode displays battery voltage
– Lockout lockoff function
– Charging Indicator
– USB Rechargeable
– Removeable tactical safety harmmer
Astrolux® S43 $28.46
4x LH351D New LED High CRI 95 Strong Light 18350 18650 EDC Flashlight
Astrolux® S43 $32.96
4x LH351D New LED High CRI 95 EDC Flashlight
+ 1Pc 30Q Power 18650 Battery
Astrolux® S43S Copper $32.96
Astrolux® S43S Copper $37.46
 all new deals are posted here:
deals.m4dm4x.com
ask MARTIN@M4DM4X.COM - i will try to save you money!
Edited by: M4D M4X on 05/20/2020 - 08:31
M4D M4X
M4D M4X's picture
reserved
deals.m4dm4x.com
treellama
Last seen: 12 min 10 sec ago
Does the LH351D really make it to 95 CRI?
TheAuditor
Last seen: 27 min 5 sec ago
Ordered one
Bonum commune communitatis.
Yarp.
MNLegoBoy
Last seen: 14 min 14 sec ago
Not that I know of, might be a certain bin for it though
Wowtac A1S BSS, Sofirn C8T, Wurkkos WK30, D4s, BLF LT1, Wowtac W1, Some other no names
"You can't be scared of the dark, if there's no dark to be scared of"
-Me (Probably)
M4D M4X
M4D M4X's picture
deals.m4dm4x.com
4nnonym
Last seen: 39 min 31 sec ago
How much longer can the S43S sustain turbo compared to the S43?
D'AVerk
Last seen: 4 days 6 hours ago
Is there solved completely inefficient power model as on version with Nichia 219C?
Or old well known but awfull FET+1 scheme like maukka tested http://budgetlightforum.com/node/63356
Blggg
Last seen: 55 min 17 sec ago
Has anyone got a beamshot photo of the LH351D version? Is it more throwy than the Nichia version?
osb40000
Last seen: 3 days 15 hours ago
Do these lights have low voltage cutoff? Planning on using some unprotected cells with them, assuming they do, or they’d at least blink to let the user know. Thanks.
TrueRMS
Last seen: 13 hours 40 min ago
I’m sure it isn’t. Not that the nichia is throwy to begin with but the LH351D has the largest die area of any 3535 emitter out there. It’s gonna be more flood then any other emitters offered in the S43 series.
Lightenzaza
Last seen: 51 min 38 sec ago
Do you know why your code is giving me 20% ; from canada .
Caught a sickness . I found out i'm not alone .
p12gt,tn12v4(nw),s1(3d),tk15,s2+(sst-40),pd35tac,fd65,tk35 ue 2018,d4v2(3a),fw3a(1a),sp32av2.0,sp31v2.0,sp40,lt1
M4D M4X
M4D M4X's picture
yes
the groupbuy is over... Sad
deals.m4dm4x.com
