Does anyone have new cells, part number (on the pink wrapper) 141 that have nonstandard Line #1(Under the wrapper) markings?
I have a few sets of 30Qs from over the years including 2 sets I purchased (a week apart) from a “trusted vendor”. All of my old sets have consistent markings. The first new set was PN 138 with proper lot markings from 2019, the second set is PN 141 and contrary to a few other posters has a “L30Q” Line #1 of the lot code.
I’m a n00b at this, just here to learn.
This wholeseller does high volume sales and his Q30 is the same as my link above… 136
My next orders will be from this site.
On my laptop hooked to an overwhelmed hotspot, dial-up speeds today.
Are you able to test them to see if they have around 3000 mAh capacity? You could also put them in a high drain flashlight to see if they are able to perform as expected. If you’re buying them from a trusted supplier, like LiionWholesale, you should be good.
Scary thing is that there are “141” version cells with proper markings still floating around. Still though, I have no reason not to recommend this vendor, theyve been good to many people myself included.
