Test/review of Ravpower RP-BC015
1 post / 0 new
HKJ
HKJ's picture
Last seen: 12 hours 38 min ago
Ravpower RP-BC015
DSC_2567
DSC_2568 DSC_2569
A four slot NiMH only charger from Ravpower that is USB powered.
DSC_2561 DSC_2563
DSC_2562
The charger was in a cardboard box without much information.
DSC_2564
The box included the charger, a USB cable (Flat type), a instruction sheet and 8 AA NiMH batteries.
DSC_2570
The charger has a micro USB input. It only uses 5V and the supplied cable is with a USB-A plug in the other end.
DSC_2586
There are no buttons, only a fairly dim led for each slot. The leds is red while charging and green when the battery is full.
DSC_2571
The charger has specifications on the back.
DSC_2573 DSC_2574
DSC_2593
The connection are the common two level style for AA and AAA batteries.
supportedBatteryTypes supportedBatterySizes
DSC_2575 DSC_2576
Measurements
  • Below 0.8V the battery is assumed to defect and the red indicator blinks.
  • Power consumption when idle without batteries is 28mA from USB
Ravpower%20%28eneloop%29%20%231
With a single battery the charger current is nearly 2A, it looks like it terminations on voltage and there is no top-off or trickle charge.
Ravpower%20%28eneloop%29%20%232
Ravpower%20%28eneloop%29%20%233
Ravpower%20%28eneloop%29%20%234
The 3 other slots are similar, but for some unknown reason I have a lower charge current in them.
Ravpower%20%28eneloopPro%29%20%231
Ravpower%20%28fujitsu%29%20%231
Ravpower%20%28leise25%29%20%231
The 3 high capacity cells are charged fine, but the curves make me doubt the termination is just voltage, the charger may be smarter than that.
Ravpower%20%28eneloopAAA%29%20%231
With AAA batteries the current is reduced to 1A, again the charging looks fine.
Ravpower%20full%20%28eneloop%29%20%231
A full cell is detected in about 5 minutes, this is fairly fast.
Ravpower%200.5ohm%20%284xeneloop%29
The charger was not that happy about a weak charger or long cable (The leds where not stable). It charged the batteries fine enough, but the termination was a bit slow.
Ravpower%20%284xeneloop%29
With full power input the charger uses 0.5A charging current for all four batteries.
Temp7631
M1: 35.6°C, M2: 39.4°C, M3: 40.4°C, M4: 37.1°C, HS1: 53.2°C
Temp7632
M1: 38.0°C, HS1: 45.7°C
PoweronNiMH
The charger is starts in about 2 seconds when power is applied.
Charge1
The charger only has 1 charge circuit and will switch it between the slows. With one slot in use it will get all the charge current.
Charge2
Charge3
Charge4
With more slots in use the charge current will be distributed between the slots.
Charge%20Solar%20NiMH
The charger will not work reliable with a unstable voltage.
Conclusion
This is a compact charger with a total of 2A charge current, that is distributed between the batteries in the charger. This means a single battery will be charged fast and four batteries will take four times as long.
It passed all my test without any trouble, this makes it a good charger.
Notes
Ravpower batteries review
My USB charger tests
