13,000 lumens from a single 21700 cell. Yes, it also has normal modes.
92 posts / 0 new
jp9mm
Last seen: 8 hours 3 min ago
Can’t buy it …. no moonlight mode Hat
texas shooter
Last seen: 2 hours 50 min ago
I’ve taken a few looks at the battery from different sources. It’s single contacts on each end. The top of the battery appears to have a plastic reverse polarity shield. In this video you can see the tail cap has a long tail spring https://www.youtube.com/watch?v=WQKzGhf3c2k Hopefully this will allow other standard length batteries to fit.
richbuff
Last seen: 1 hour 32 min ago
richbuff wrote:
Yokiamy wrote:
Oh, mine is almost here, in Germany now :BEER:
When you get it, can you tell us about the battery? Please let us know if a solder blob top battery or spring top battery will work in the flashlight.
Please also post about your impressions.
texas shooter said: “...it’s single contacts at each end. ...”
That’s good news, thanks for noting that and reporting that. That means that normal unprotected batteries with solder blob or a spring soldered onto the anode will probably work.
For less performance, use smaller flashlights, and for most performance, use largest flashlights.
Yokiamy
Yokiamy's picture
Last seen: 6 hours 7 min ago
I’ll keep you posted, hopefully it will arrive today, otherwise it will be tuesday at early due to a national holiday monday.
texas shooter
richbuff wrote:
richbuff wrote:
Yokiamy wrote:
Oh, mine is almost here, in Germany now Beer
texas shooter said: “…it’s single contacts at each end. …”
I believe no battery modification will be needed. With the positive ends shield being so deep. The lights anode contact is going to have to extend out some.
richbuff
That would be great if normal unprotected cells can be easily made to work in the light.
A review was posted in the German forum:  m.youtube.com/watch?v=lANIdO5gq9I
Thanks to elakazam for posting the link, thanks to Charles BridgTec for your valuable review.
FlashKat
Last seen: 4 hours 2 min ago
Imalent 21700 batteries are very long compared to regular 21700 batteries.
Yokiamy
Yokiamy's picture
Ok, just got it.
A 40T does not work due to its length (or lack off actually)
A normal cell will work but it needs a magnet or so, since you will need a giant blob of solder, since the unprotected cell rattles in the tube.
Nice light, does not look like 13k lumens, floods more than a KR4, gets hot quick.
The screen printing is sloppy, the threads are very thin.
https://imgur.com/gallery/q2IXRau
richbuff
Thank you for your valuable pics and observations. I’m going to ask my favorite modder to provide me with a few soldered spring top unprotected 40T cells. I hope to get mine soon. Thanks again!
mortuus
mortuus's picture
Last seen: 2 hours 49 min ago
they did it on purpose so that standard highdrain cells doesnt work.. i hate that…. olight does it too.
...where Frugal meets with Flashlight!
Yokiamy
Yokiamy's picture
Turbo is super bright, but it plummets almost immediately
mortuus
mortuus's picture
expected. its kinda waste of lumens only… regulated is what 2500 ?
Hikelite
Last seen: 2 weeks 2 days ago
10Klm or the advertised 13Klm, it does not matter, if there are more lumens more plummeting. Same host but more amount of dissipated heat produced by the LEDs.
But then again, someone might say they want to use only the 5000lm function, the 10k is not compulsory which of course is just fine. Problem is if something has the same host and only claims 5000lm and might handle that just fine no one gets excited as much as Utopian claims excite.
Yokiamy
Yokiamy's picture
Well worded Hikelite.
Will do some lumen measurements soon, if it didn’t had the dreadful proprietary cell, now i constantly need to charge it after doing a small test
mortuus
mortuus's picture
Yokiamy wrote:
Well worded Hikelite. Will do some lumen measurements soon, if it didn’t had the dreadful proprietary cell, now i constantly need to charge it after doing a small test
yeah i bet its annoying when u can use standard 40t cells or whatever… i hate this kind of forced design.
Hikelite
mortuus wrote:
.. i hate this kind of forced design.
It is actually quite convenient and standardized, saves a ton of trouble if a charging function is in such high demand.
The conflict comes at the moment when the manufacturer has fundamental issues understanding how to deliver what it wants or it could be that it is their deliberate choice to claim something then make it in such way it can’t deliver.
texas shooter
Is there another spring that could be used?
Yokiamy
Yokiamy's picture
You need a very long spring to try that. Not recommended though.
T.b.h. a KR4 with xpl hi is probably a better choice, since the output plummets immediately.
Yokiamy
Yokiamy's picture
2000
uselessuser
Last seen: 2 hours 37 min ago
Does anyone have an idea how to get it open? I’d like to swap out the LEDs, but I don’t see any obvious angle.
Yokiamy
Yokiamy's picture
it looks like the bezel should come off, it’s seems it’s screwed into the head, it is slightly protruding.
Get a rubber or other flat grippy surface and try to open it holding it down firmly while turning it
uselessuser
Thanks! I’ve tried that, but my efforts went unrewarded. Has anyone done this successfully?
The FailureMan
Last seen: 3 days 14 hours ago
Got mine few minutes ago. Unprotected batteries work well If you add some coins to the negative end.
Do not use crappy batteries from bangood or etc. Flashlight works for 10 seconds in turbo then Red led flashes due to voltage drop. You will have to reinstall the battery If this happens.
Jack Kellar
Jack Kellar's picture
Last seen: 13 hours 31 min ago
The FailureMan wrote:
Got mine few minutes ago. Unprotected batteries work well If you add some coins to the negative end. Do not use crappy batteries from bangood or etc. Flashlight works for 10 seconds in turbo then Red led flashes due to voltage drop. You will have to reinstall the battery If this happens.
The FailureMan
Jack Kellar wrote:
Thanks, video helped.
And I applied few small drops of thermal grease into the thread. Hope this will help to dissipate more heat.
Jack Kellar
NP Thumbs Up Keep us posted if anything changes!
Yokiamy
Yokiamy's picture
Mine still functions as should.
However it gives a ton of light, i still prefer my KR4.
So if anyone’s interested, i’m willing to sell it for a reasonable price.
JordanZHP
Last seen: 2 hours 15 min ago
Did you remove the spring to install the coins?
Cesconetto
Cesconetto's picture
Last seen: 2 days 14 hours ago
Estou tentando um reembolso da Imalent sobre essa luz, apesar de todos os esforços a luz insiste em não funcionar como deveria…. mesmo com tantos videos e postagens dos problemas desse projeto a Imalent insiste em não admitir o erro nessa luz…. lamentável… Apartir de agora, Imalent nunca mais! Ganaciosos!!!
Lumintop Mini e Micro - Emisar D18, D4S e D4 V2 - Acebeam TK 16 Osram, W30 e K65 Gtvn - Imalent MS12 e MS 03 - Manker E11 e E14 II - Nightwatch NI40 - Fenix E18R - Amutorch E3 S
Jack Kellar
My dude, nobody’s gonna understand you here if you don’t speak English.
