Emisar KR4 stuck in strange mode
10 posts / 0 new
Turby3Pots
Turby3Pots's picture
Last seen: 5 days 23 min ago
Just received an 8 LED mule Emisar KR4 in the mail.
Turned it on and off a few times and now it is nonfunctional.
All I am able to do is hold the button down and it will ramp up, blinking heavily, until it goes solid and shuts off. No amount of clicking or battery pulling can get any other response.
Anyone have any suggestions? I cannot find any answer to factory reset option in the user’s manual.
Hank Wang
Last seen: 37 sec ago
The tailcap is not fully screwed in, you will need to screw the tailcap tightly.
When the tailcap is not fully screwed in, and you press the switch, it will be in the factory reset mode, just as you see now.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Turby3Pots
That completely fixed it, thanks hank!
Yokiamy
Yokiamy's picture
Last seen: 3 hours 35 min ago
I experienced the same problem, i found out that tightening the tailcap solved the problem (as Hank described)
Probably a bad contact causes just too much voltage drop for the MCU to stutter.
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 33 min ago
If the tail is loose, power isn’t connected.
However, a small amount of power can trickle through the switch, so pressing the switch powers up the light even when the tail is loose.
When the switch is held at boot time, the light enters factory reset mode. This mode ramps up while blinking, for about 3 seconds, as a warning… then performs a reset and ramps back down. The user can about the reset by letting go early.
So… because the tail was loose, the light was basically stuck in factory reset mode.
Yokiamy
Yokiamy's picture
Thanks for the explanation TK!
Turby3Pots
Yep it just makes too much sense.. It felt like it was trying to tell me something, the blinking getting brighter and brighter like it was warning me, and then the solid as a success message.
But I couldn’t (maybe still don’t) see how it was programmed to consider for a “loose but still slightly connected” tailcap? How was I supposed to enter this mode originally?
SammysHP
SammysHP's picture
Last seen: 3 hours 50 min ago
There is no other way to do factory reset via the “hold button while tighten tailcap” with this flashlight (and I suggest to explicitly ignore the button event after boot, ToyKeeper). The other way is 13H from off.
ToyKeeper
ToyKeeper's picture
It’s not really a programming thing. It’s just a strange quirk of the way the circuit is designed. It can receive power without the battery tube installed at all, if you’re careful. Basically, put a battery between the head and the tail, with the inner tube in place but not the outer tube… then press the button. The light can turn on, but only at relatively low brightness levels.
When doing this though, power flows through the switch. So letting go of the switch forcefully turns the light off by physically disconnecting power.
It might be nicer if the light ignored button events at boot time, but then it would need a way to sense whether the light was actually just turned on, or if it was merely rebooted. That way, the 13H method would work, but the loosen-tailcap-then-hold-button method would not. Maybe the SRAM decay trick could be used for this. Then it would actually be able to tell the difference between a loose tailcap and an intentional reboot.
At the moment though, it has no idea whether the user did a 13H factory reset or a loose-tailcap reset.
Hank Wang
Actually it’s much more easy to loose and tighten the head to do the factory reset instead of the tailcap.
