Continued from this topic: https://budgetlightforum.com/t/-/674
I bought it for a, a L2M (black), that had purchased a weak earlier at the ITC-shop. You guy's kept braging about solarforce hosts, that I had to try one...
Haven't tried with the intended light, but it fit's a UltraFire WF-502B . Even with the belt clip.
It's kind of a tight fit, but I think it's been tailored for that. After the Champions League games, I'll post some pictures, and try to see if it fit's other lights.
Edit: I like it a lot. It's hard as a rock, and seems that's built to withstand rough use. Only time will tell.
Here are some pics.(they are too big...)
Top: http://i198.photobucket.com/albums/aa220/juhha/lanternas/19102010077.jpg
Side: http://i198.photobucket.com/albums/aa220/juhha/lanternas/19102010078.jpg
Fits a Ultrafire WF-502B, even with it's belt clip: http://i198.photobucket.com/albums/aa220/juhha/lanternas/19102010079.jpg
A Seraph Sp-9 fit's as well, but only without the thick rubber rings removed.
Without: http://i198.photobucket.com/albums/aa220/juhha/lanternas/19102010080.jpg
With: http://i198.photobucket.com/albums/aa220/juhha/lanternas/19102010081.jpg
Does not fit the UltraFire U4-MCU: http://i198.photobucket.com/albums/aa220/juhha/lanternas/19102010082.jpg
Does fit the Dereelight DBS V3, only without the belt clip off, but it won't close: http://i198.photobucket.com/albums/aa220/juhha/lanternas/19102010083.jpg
Everything that has a small head, and the body diameter is 30mm or under, will fit. Above 30mm, it's a mega tight fit. Even if it's heavy duty, if the flashlight has a lot of knurling ( s ), it will be a pain to put in/out off the holster.
Sorry about the crappy pics, and will post a pic with the L2m, when it arrives.
