Lumintop FW21 Pro (10,000 lumen) vs Nightwatch NSX3 (9,900 lumen)
71 posts / 0 new
@Lojik
Last seen: 3 weeks 2 days ago
I’m leaning toward the Nightwatch. People have reported respectable turbo runtimes with good heat dissipation on the NSX3. But the newness & Anduril of the FW21 Pro has me questioning my inclination toward the Nightwatch. Any comparison info would be greatly appreciated, Thank you.
richbuff
Last seen: 2 hours 59 min ago
I have both. I started off by ordering four NSX3 9,900 lumen, but I only received one, because the supply dried up. So I jumped on three FW31 Pro and I just received them yesterday. One major difference between the two is the switch. Both are in the rear, but on the Lumentop, the switch is electronic, instead of clicky. The Lumintop is shorter, because the reflector wells are not as deep, and also because the switch on the nightwatch takes up more length.  The user interface on the two lights is totally different. That depends on your preference. Also, even though the head diameters are almost identical, the reflector wells on the Nightwatch are deeper, larger diameter, and moderately overlapping. The reflector wells on the Lumentop are shallower, smaller in diameter, and non-overlapping. This results in the hotspot of the nightwatch that is tighter, and the hotspot on the Lumentop is a little bit larger.
I like both, and I think you should buy both, and whichever one you don’t like you can sell or give to a friend. By the way, if you know where I can get more of the Nightwatch 9900 lumen, please let me know because I’d love to buy two more of them.
For less performance, use smaller flashlights, and for most performance, use largest flashlights.
tatasal
Last seen: 1 hour 41 min ago
Neal has the Nightwatch NSX3 xhp50.2 version now.
@Lojik
It sounds like I may slightly prefer the NSX3. I like clicky buttons. I also like the double click for turbo. The tighter hotspot also sounds a bit more up my alley as it will likely “appear” brighter. I debated going for the floodier one of the two but now I kinda just want the Nightwatch, something about the shape speaks to me. I was about to order the FW21 Pro about a week ago or so, then I heard about the Nightwatch. At first it seemed like a cheaper gimmicky kind of light, but as I read reviews and people’s first hand impressions, I got a feeling that the NSX3 was pretty special. The FW21 doesn’t seem too special and I get the feeling the turbo mode lasts a lot less than the NSX3.
By chance, do you know which one steps down from turbo earlier and which one holds a higher lumen output after step down? Do you maybe have a personal opinion on which you feel is more useful after the turbo step down?
Thank you so much for your impressions.
richbuff
The FW21 Pro has user adjustable thermal regulation setting. Default is 45C, and the user can adjust higher or lower. Both lights are hot rods, so the higher modes should be used only very briefly. I do not thermal test my lights; that is, I only use the highest modes for a second or two to scan a large area very briefly.
I am going to check Niels’ website again, and if it looks like he has them in stock, ready to ship, I’m going to order two of them.
forsh
forsh's picture
Last seen: 3 weeks 5 days ago
lumintop has them in stock, ive just ordered a fw21pro, directly, ordered it 2 days ago, now its on its journey
great communication if needed , victor is very nice to speak and deal with
https://www.facebook.com/groups/163189738353433/?ref=share
Join my Facebook FW3/4/1 selling and buying group guys
forsh
forsh's picture
icpart
Last seen: 2 hours 52 min ago
I am consider to buy SST40 version of Nightwatch, I really don’t like very much 6500K 3V XHP50.2 of FW21Pro . If they release 5000K version of both lights that will be great. Also Nightwatch have better cooling fins on head compared to FW21Pro. Also Nightwatch is a cheaper.
@Lojik
Neals has 15% off of new arrivals so the FW21 Pro is technically the same price without a battery, The promo code is “NDNA” and brings it down to about $55 USD too right now.
@Lojik
So you’d ultimately prefer the FW21 Pro? Is that the one you mean you’d order a few more of if in stock? Which one would you keep and which one would you give away to a friend between the two lights?
richbuff
I like both, and I just received three of the FW 21. I only have one of the nightwatch,  even though I originally ordered four,  because I only received one. I am going to check Neil’s website to see if I can order a few more of the nightwatch, if he has them in stock, ready to ship.
@Lojik
Hmm, Thank you. Maybe getting both IS the way to go.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 24 min ago
Yep, save yourself the angst.
djozz
djozz's picture
Last seen: 12 min 44 sec ago
I have the NSX3 with different emitters (I put high CRI LH351D led in it), but as an advice I very much suggest it over the Lumintop FW21 Pro. The nightwatch at least tries to make the most of shedding heat for this compact format (although at the full 120W nothing will be enough), the FW21 does not even make an attempt at it. While at these power levels heatshedding is the single most important design goal. Making 10,000 lumen is dead-easy these days, but making it actually usable is very hard.
hodor
hodor's picture
Last seen: 8 hours 30 min ago
Djozz, what are your thoughts on the NSX3 build quality? Seems like it could be a nice host.
djozz
djozz's picture
Build quality is good. Modding was a while ago but I recall it was easy. I did not like the driver, I used a 17mm BLF-A6 driver soldered in a brass converter ring (from Simon) to bring it to 22mm. I did not get the leds perfectly centered in the three reflectors, that can be because the leds were not precisely centered on the pads during reflow, or the MCPCB is not perfectly tailored for the reflector, I don’t know which. With the big dies of the LH351D’s it does not matter, the beam is fine.
hodor
hodor's picture
Hmm, tempting!
ysgramor
Last seen: 3 weeks 6 days ago
I have only the FW21Pro so I can’t compare, but, regarding turbo runtimes: with the FW21 they are not as bad as I’d have expected. I set the thermal regulation at 82°C and with a Molicell P42A I get 12-15 seconds before stepdown, at room temperature. And when it steps down, you can always kick it back to turbo by double clicking again, and get a few more seconds. Being so light, you can hold it cigarette style by the tailcap end, and you can get 40 seconds, maybe up to a minute of total turbo runtime before it becomes too hot to hold even by the tail… if you don’t fear frying the LEDs or battery, that is.
Even 12 seconds are more then enough I’d say, for the intended use of this light… this is essentially a quasi-EDC, it is smaller and lighter than the NSX3, it has a clip… it’s a light to carry around and use at a “low” level it can hold indefinitely, and if you need a few seconds at 10000 lumens well, you can have it.
The main drawback of this light would be the ugly tint and horrendous tint shift.
Heat dissipation is a bit overrated with this class of flashlights I think. Even the NSX3 won’t hold the 10000 lumens for more than… 30 seconds maybe? It’s still not enough to be an appreciable advantage over the FW21Pro in real world usage: what can be a real world situation where you need 10000 lumens for more than 15 seconds but 30 seconds is enough?
tm07
tm07's picture
Last seen: 6 hours 37 min ago
anybody know what is the amp draw this two light?
Sunnysunsun
Sunnysunsun's picture
Last seen: 2 hours 2 min ago
The 53A goes just over 30s on turbo before stepping down using a new 30T. You can re enable turbo repeatedly afterwards but it always steps down. 3 xhp50.2s is simply too hot for most lights outside of a gigathrower form factor.
I’ve been tempted by the 21PRO but am weary about quality control from what I’ve read about the FW3A series and also my HL03’s flaw. Anduril is really tempting though but I think I’ll hold off.
Rockenrooster
Last seen: 13 hours 52 min ago
I just ordered this light (FW21 Pro)! I’m interested in your guys feedback as this will be my first 21700 light. (been using 18650 lights for years, started with a SSC P7)
richbuff
Rockenrooster wrote:
I just ordered this light (FW21 Pro)! I'm interested in your guys feedback as this will be my first 21700 light. (been using 18650 lights for years, started with a SSC P7)
Welcome to BLF!
We want to hear your feedback, too!
andreas0401
andreas0401's picture
Last seen: 1 hour 15 min ago
Lumintop FW21 Pro 3x XHP50.2 10000Lumen vs Nightwatch NSX3 NS53A 3xXHP50.2 6500k 9900 Lumen
Starkm32
Starkm32's picture
Last seen: 55 min 34 sec ago
Is the 15% discount code good for the new NXS3 (near) 10k version?
Got Lumens
Got Lumens's picture
Got the FW21 Pro with the offered Samsung cell.
Works well and the build seems solid.
The light could use a better tint.
The clips hoop slightly protrudes, and is a tad bit larger than the tail caps diameter.
It gets hot. Use 100% sparingly. I'll get some beam shots this week.
Neutrālisflashaholic
mortuus
mortuus's picture
Last seen: 1 hour 57 min ago
yeah the light does like the 10k lumens for like a second then drops faster in the blink of an eye the lumens… having the xhp50 in 5000k tint or so would be nice or even warmer.
...where Frugal meets with Flashlight!
@Lojik
Thank you so much for taking the time to do this comparison, it was really helpful. It showed that the lights were essentially identical in initial output and the decision comes down more to UI or preferred host. I ended up going with the Nightwatch NSX3 due to the decent body’s design for heat dispersion. You are much appreciated good sir.8
Rockenrooster
Just got my FW21 Pro in the mail today. The dang thing gets super hot. For longevity, I calibrated the sensor and set the limit to 40C which is pretty close to getting too hot to hold for me.
It smokes a black paper plate in 2 secs lol. I wonder if it can catch it on fire!
In my VERY unscientific ceiling bounce test and using a LUX meter app (phone placed on floor), it goes up to 1200 lux compared to my Convoy M3’s ~650 lux. Then it throttles to about 150 lux lol. (Please note that these are relative tests and the lux numbers are in no way comparable to other peoples results!)
This is with using a P42a Molicell 21700.
mizou51
Last seen: 6 hours 39 min ago
What a strange race we are facing in 2019/2020….the more lumens possible in a lowest possible time ?
It started with imalent flashlights 3 years ago…
i would like to see a small light that can sustain 3000lm for 10min.
Rockenrooster
Would be kind of hard in a small body.
You need mass for heat-sinking.
Now if I needed 10k lumens for work, I would be looking at 2x, 3× 4× 21700 Lights that are big and heavy.
mizou51
I know I know…we are talking about 80 to 150w and even more than 200w for 10klumens ! Cpu cooler are much more bigger and feature fan designs…
I was talking with Dale from Haikelite about fan cooling for the big 3xxhp70.2 lights
But considering the current thread I would like to see the small light with exact time specs. For example a 3000lm light should sustain it for 5min mini. Like tig welder are rated with running coefficients…
