How Good is D2 Steel Knife Blades?
41 posts / 0 new
moderator007
moderator007's picture
Last seen: 2 hours 53 min ago
I recently started gainng a interest in knives again, mainly china knifes. I see alot of budget china knives use some sort of stainless alloy. While some use D2 steel usually at a little higher price point. Then you have the high quality china knives that use M390, which from what I have read is close to the top of the line.
I recently purchased a TwoSun TS21 with D2 steel blade. I must say I’m quit impressed by TwoSun’s fit and finish on the titanium scales and the complete build. I’m not a machinist by profession but do machine alot as a hobby or when something calls for it. So I know what to look for and I got to say for a knife the chinese have really uped they’re game. Excellent machine work and blade sharpness right out of the box. I could go on with the quality of the build, but most have probably already seen what I’m talking about.
Back to the main question, I haven’t had the D2 steel long enough to know how good it is, sure I can read about it, which I have. But I know a lot of knife lovers here could probably give a better real world experience. How good is it and how does M390 compare? I plan on using the knife, instead of a shelf queen. I purchased a QSP Woodpecker last night just because it used M390 and it looked like another china quality knife. Did I waste money buying the better steel when its not needed in a EDC knife or was it money well spent? Curious to hear others experience’s with these 2 steel alloys.
lazerEagle
lazerEagle's picture
Last seen: 1 hour 23 sec ago
I think D2 is just a good budget steel that if heat treated properly will hold a good edge for a while and take a beating.
source: https://www.bladehq.com/cat—Best-Knife-Steel-Guide—3368
- the best way to predict the future is to create it -
Alitd
Last seen: 7 hours 54 min ago
Without having experience with those 2 knives, I cant say for sure. Too many variables.
The heat treat can be very different on any steel and that’s if you know for certain that you got what you paid for. The same steel at a different Rockwell performs differently. Very few tests, other then use to confirm. One pro to buying from a named company is consistency and knowing what you got.
D2 is less stainless than M390. M390 should hold an edge longer.
Does anyone NEED super steel for edc? I’d say rarely. What are you cutting and how often? Carpet?
How often do you want to sharpen? Are you good at it? Super steels can be more difficult to sharpen.
I have knives in D2 (Mini Grip) and M390. Both great steels.
moderator007
At my work, I may cut rope, boxes, rubber, plastic and wood with a few other odd materials thrown in. Carpet, I have used one to cut carpet before, yes. I use it for what ever needs cut or trimmed, its a tool to me. I’m not saying I cut all that in one day but over time, I do cut alot of things, I do use it as intended.
I had visited bladehq’s steel charts several times and that’s been pretty useful. But Im interested in how it does in real use like I’ll be subjecting it to.
No problem in maintaining the blade as you probably guessed I have had lots of sharpening experience over the years. I looked for a easier way than by hand and recently purchased a edge pro clone and some good quality stones. Its still quit a bit of work for scarry sharp but easier being able to hit your angles correctly ever pass.
I’m more use to steels that were sold 15 to 20 years ago like 400 series.
xxo
Last seen: 2 hours 37 min ago
D2 holds an edge well but rusts easy and like most “super” steels, can chip if abused. Easy to sharpen on a sharpmaker if you are maintaining a good edge, but can take a long time to re-profile an edge that is set at the wrong bevel angle or has been damaged. I have not used M390.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 4 hours 12 min ago
I haven’t tried any of the “super steels” like M390 but I can say sharpening even S30V can be a pain sometimes – I’m also a complete novice at sharpening so take my opinion for what it’s worth. The peace of mind higher more stainless steels offer is nice, but that depends on how likely your knife will be to get wet too (saltwater fishing vs cutting material at an indoor job for example).
I’ve heard the D2 and M390 from well-reputed Chinese brands like Civivi and others is pretty good. My Elementum has held up well although it hasn’t had a ton of use to really test it.
Swabs
Swabs's picture
Last seen: 5 days 10 hours ago
I like D2 tool steel, and 14C28N Sandvik blades.
A reputable Chinese knife company such as Real Steel, Ruike, CJRB, Bestech, TwoSun, and Civivi have been great for me. Their D2 and Sandvik blades have been heat treated great, and that is what makes all the difference in the world.
My Future's So Bright...well, my flashlights are anyways.
ChrisGarrett
ChrisGarrett's picture
Last seen: 5 hours 5 sec ago
Bob Dozier loves it for his knives.
But…there’s D2 German steel and then there’s the other shit.
It’s not as much a stainless steel as some would think, so oiling it after use is probably a good idea.
Chris
Chronovore
Last seen: 11 hours 16 min ago
D2 is highly dependent on heat treatment. A lot of the reputation driving its popularity today is based on more expensive American knives with better heat treatments. A major criticism and source of misplaced controversy regarding Chinese D2 is that it doesn’t live up to that reputation. Well, of course it doesn’t. These are less expensive mass-production knives. In my own experience, Chinese D2 is “okay”.
On the low end with companies like Kubey, Ganzo, Petrified Fish, etc.; it’s a big win over the 8Cr13Mov we were seeing at similar prices a few years ago. Versus 8Cr13Mov, Chinese D2 has slightly worse corrosion resistance but much better edge retention. It does take a little more work to sharpen but you won’t have to do it as often.
With companies like Civivi and Bestech, you might get a little better quality but it doesn’t stand out as much. I’d much rather have 14C28N, VG-10, or N690 in the $50-100 range. Those steels can hold a very nice edge and are much more stainless. I have limited experience with M390 but apples to apples with a budget heat treatment, the M390 should be a win on both corrosion resistance and edge retention.
Souichirou
Souichirou's picture
Last seen: 2 hours 41 min ago
I agree with some points but the ontario rat 2 is a solid knife that uses D2 steel and can be found around $40-50, I personally have one in my camping gear as a beater knife hasn’t failed me yet. I consider it a “Chinese D2” though its manufactured in Taiwan the steel is more than likely sourced from mainland China.
I agree VG10 is probably the best of the bunch easier to handle and sharpen and live with all in all, I like 14C28N BUT cant seem to get it as sharp as my VG10 knives.
moderator007
That’s pretty interesting that D2, VG10 to 14C28N seem to be more popular for your EDC type knife. That opens up a lot more choices for me. I like steel that gets scary sharp but I dont like to spend hours sharpening it either. Sounds like spending more money on higher grade steels may not be the best option for me.
I have seen a few china grade steels tested on youtube and most came out to be pretty accurate but you always have those that are out to cut corners.
Chronovore
I don’t have experience with the Rat series but their D2 models have a good reputation. I think Chinese D2 shines at that price and below. I compare it to 8Cr13Mov because at similar prices, you gain a significant increase in edge retention and only lose a little on corrosion resistance. AUS8 is similar enough to 8Cr13Mov in corrosion resistance but seems more variable in edge retention. Heat treatment and blade geometry matter a lot. Here is an interesting comparison between Ontario’s AUS8 and D2:
https://www.youtube.com/watch?v=t_KHSuwr5vY
Of course, D2 is semi-stainless. The corrosion resistance isn’t terrible. It’s just low enough to be a problem in some environments. It can require more vigilance in keeping it clean and oiled. I own a bunch of knives in Chinese D2 and I’m carrying one right now. With basic maintenance, I’ve never had it rust on me. I just like the idiot-proof hedge of more stainless steels like 14C28N, N690, VG-10, etc. Since they are easier to sharpen and do hold a decent edge, I tend to prefer them over Chinese D2.
For stainless, I like VG-10 or N690 better than 14C28N. I put 14C28N in the same ballpark as Tangram’s Acuto 440 or a good 9Cr18Mov like you get from Civivi or Real Steel.
polarweis
polarweis's picture
Last seen: 1 day 12 hours ago
How do you sharpen? Stones etc?
Some blade shapes are easier to sharpen then others too.
I personally really like 12c27 and 14c28n sandvik steels. Take a nice edge and feel really tough.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
xxo
If it’s real D2 it will rust if you don’t keep it clean and oiled; even blades with coatings will rust on the most important part – the edge. If you use a D2 knife on certain foods it will start to patina in seconds. I prefer steels like VG10 and S30V because they are more rust resistant.
No need to get too caught up on the exact steel – heat treatment and blade geometry are far more important than the exact type of steel.
lazerEagle
I clean my rat d2 with mineral oil and wipe off excess, seems to help the blade slice a bit. It came with a nice oil feel out of the box.
BurningPlayd0h
xxo wrote:
If it’s real D2 it will rust if you don’t keep it clean and oiled; even blades with coatings will rust on the most important part – the edge. If you use a D2 knife on certain foods it will start to patina in seconds. I prefer steels like VG10 and S30V because they are more rust resistant. No need to get too caught up on the exact steel – heat treatment and blade geometry are far more important than the exact type of steel.
I hope to see the trend Spyderco has been on of moving from VG10 (already a fantastic steel) to CTS-BD1N continue and be emulated by other companies. Better edge retention, still easy to sharpen and even more corrosion resistant IIRC.
Sirstinky
Last seen: 4 hours 35 min ago
D2 is a good tool steel. It is a carbon steel so it will rust (like 1095, et.al.) and heat treatment is important to get the most out of it. It’s good for general purpose and sharpens well and takes a very fine edge. I personally like good carbon steels like 1095, D2, O1 (Cold Steels Carbon V is great), and the crucible steels like CPM154 for that reason. Some of the newer steels like VG10, S30V hold an edge, take a beating, and are corrosion resistant, but wear out up my stones so I went to diamond for those. I mainly do cutlery, but some pocket knives.
xxo
I haven’t got a new knife in a few years, so most of my Spydercos are VG10, S30V, H1 or ZDP 89. No one is more cutting edge when it comes to blade steels than Spyderco and that’s great. I always enjoyed trying out the latest and greatest wonder steels but it’s really not all that important. Give me a well made, well designed knife with good ergonomics and a half way decent rust resistant steel with a good heat treatment, a thin full flat ground blade that cuts well and I’m happy.
polarweis
polarweis's picture
I got a para 3 recently and I have to say im impressed. I love the frn handle, it makes it feel like the old clipit delicas. Steel is very impressive and the compression lock is the best lock imo
Souichirou
If you like the Para series knives check out the Spyderco smock ! its the knife that replaced my previous daily the para 2, the fit and finish along with a button compression lock the fidget factor is through the roof !
BurningPlayd0h
Right on, with the price increases of the Delica the Para 3 is pretty much better in every way for a very close price. Better steel (vs non-sprint run Delicas) and better locking. IIRC the Delica doesn’t have a deep-carry clip stock either.
lazerEagle
Para 3 lightweight is a phenomenal pocket knife, it errs on the side of light use (being so lightweight albeit sturdy) so I try to swap it out for outdoors and construction focused days. Mine gets a workout and is aging fairly well, have pulled apart, cleaned and lubed once, would recommend to get the action tuned in.
Chronovore
xxo wrote:
… No one is more cutting edge when it comes to blade steels than Spyderco and that’s great. I always enjoyed trying out the latest and greatest wonder steels but it’s really not all that important. Give me a well made, well designed knife with good ergonomics and a half way decent rust resistant steel with a good heat treatment, a thin full flat ground blade that cuts well and I’m happy.
I agree. Fancy super steels are cool but I’m fine with VG-10. Good ergonomics and great cutting geometry matter a lot. Two of my recent favorites are the Tangram Santa Fe in Acuto 440 and the Kizer Mini Domin in N690. Both feel good in my hand. Both have thin slicey blades. The Mini Domin’s 0.10” blade stock really helps it to slide through material.
BTW, did you see that Spyderco has an exclusive blade steel now?
xevious
xevious's picture
Last seen: 4 hours 34 min ago
I have a nice folder with a D2 blade. A sub $25 one from China. VERY well made for the price. I honed the D2 blade a bit and it’s super sharp. I’ve cut fine slices of ginger with it. Also lemon. Those are caustic. But even after letting the knife sit for a good 10 mins before rinsing off & drying, I noticed no spotting. No rust whatsoever.
Kiwi-Hunter
Kiwi-Hunter's picture
We have a fellow goes by the name Tahr on the hunting and shooting forum nz, he’s one of the knife lovers.
He also has a fine collection of bark river knives some in D2.
What I understand is what others have said, true D2 ( not nock off steel posing as D2) holds a good edge, but doesn’t like bone.Mostly I just strop on leather strip 2“wide and 24 “ long glued to a board and Polishing paste to sharpen my knives.
Do it regularly and shouldn’t need serious touch up work for sometime.
KH
polarweis
polarweis's picture
Then its simply not D2..
xxo
I have not been keeping up on the latest Spyderco steels, though they are always ground breaking when it comes to steel. I remember that Spyderco was the first or among the first to make folding knives in a bunch of steels: Gin 1, CPM440V, ATS55, VG10, CPM S30V, ZDP-89, H1 to name a few.
Spderco knives I like: Stretch, UKPK and Calypso JR LW, all of these lock your hand into the handle for a comfortable and secure grip and have thin full flat grinds that really slice. And with Spyderco the steel is always good with no worries when it comes to heat treatment.
xevious
xevious's picture
I’ve been educating myself a bit on knife steels. It’s really very fascinating. There’s so many combinations of factors. But there’s one you can’t avoid: one factor being stronger is usually a trade-off on weakening another factor.
Blade HQ has an excellent Knife Steel Guide.
PREMIUM: M390, CTS-204P, CPM-20CV, CPM-M4, CPM-S90V, CPM-S110V, Elmax
HIGH-END: CPM-154, CPM-3V, CPM-4V, CPM-S30V, CPM-S35VN, CTS-XHP, LC200N
MID-RANGE: 1095, 154CM, A2, D2, H1, O1, N690, VG-10
BUDGET: 400 Series, AUS-8, CTS-BD1, Sandvik Series, Others
Some people are calling D2 “budget…” but seems that needs to be qualified by the source. Unknown heat treatment D2 from China? Very likely budget. Quality heat treatment German D2? Very likely mid-tier. Curious enough, D2 has been around since WWII.
At this point I have two D2 knives. Both came from China. I don’t know for certain if they’re authentic… And actually, I suspect the sub $20 D2 knife I bought (2.5” blade) might actually be 440C. It holds an edge very well. It “feels” like it takes a few more passes to hone it close to perfection than it does on another knife I have which is 440C. But, that’s all subjective. Given the price I paid, I’m not losing sleep over it. Wink
Btw, on the earlier post I made, the D2 knife I mentioned about not corroding… it has a coating on it. So that may have helped avoid corrosion. I don’t know if there’s a reliable & easy test to prove it, without ruining the blade (e.g. soaking in lemon juice).
____
Anyway, for light duty EDC, the steel grade isn’t so critical. Any fairly decently forged steel is going to do just fine cutting packages, cardboard, food, etc. Some will require more frequent honing than others. It’s when you get into heavier duty usage that the steel quality becomes a more important factor—you don’t want to skimp.
Of course, cost is always a factor. Some people don’t subscribe to paying a lot more upfront for a knife that will last much longer. It can be more attractive to go for a bargain & hope for the best. Especially when attractively designed. China is certainly trying to aggressively feed that need. While there’s flood of very affordable knives coming from China with slick designs, the one “catch” remains—how good is that steel being claimed? There are more reputable brands emerging like WE, Kizer, Artisan Cutlery, Civivi, TwoSun, etc., that are striving for good reputation and appear to be fairly trustworthy on the steel grades they claim. But then you have these other brands which… while achieving very attractive designs, seem to be doing it at a price point that doesn’t match steel grades being claimed. For instance, I saw one nicely designed folder knife on AliExpress, priced at $68, and claiming M390 steel. But then there’s other knives in the same price range labeled as D2 steel. In fact, that very knife design has a “D2” counterpart at the same price from other sellers. It seems far more likely that “M390” is really mislabeled D2… or possibly 440C. This exemplifies that trust issue.
So bottom line, maybe a really good deal on a suspect D2 knife isn’t all that worthwhile in the end. Better off paying a little more and getting something you can definitely trust.
RapidLux
RapidLux's picture
Last seen: 5 hours 7 min ago
Treated with care, D2 is a good budget steel, else it will easily rust, and you better go for 440C.
VG10 and M390 and are considered super steels. Instead of buying dozens of budget knives, buy 2-3 supersteel knifes.
Good budget stainless steels for kitchen knives are AUS-8 (Molybdenum Vanadium), 3CR13 and X50CrMoV15.
Souichirou
RapidLux wrote:
Treated with care, D2 is a good budget steel, else it will easily rust, and you better go for 440C. VG10 and M390 and are considered super steels. Instead of buying dozens of budget knives, buy 2-3 supersteel knifes.
440C is a very budget steel sure it has better corrosion resistance but if you a dont like or know how to sharpen a knife then D2 would still be a better option especially since cleaning a knife isn’t hard and D2 holds its edge significantly longer than 440C. In essence 440C is just a harder to sharpen AUS-8….
VG10 is a GOOD steel no doubt, but if comparing steels its not even in the same category is M390…
xevious
xevious's picture
There’s really no point in owning a super steel like M390, unless you’re prepared for the work & skill to sharpen properly. Some people have it just for collecting purposes. I’ve seen so many M390 knives up for sale by individuals on Blade Forums, where they’d never been sharpened or used aside from a few test cuts (if that).
Btw, VG-10 is not a “super steel.” It’s a very good one, though.
I haven’t yet developed the necessary skill to sharpen higher end steels, but what I have found is that if you’re doing mostly light duty with your knives (cutting boxes, weeds, food, etc.), no major duty like cutting/splitting wood, you can get by simply honing the edge. I have a VG-10 blade and an ATS-34 blade, both of which I’ve never put to sharpening stones. I’ve only honed them. And… they’re still very sharp!
