[Review] Klarus E2 (1600 Lumens, 18650 deep carry EDC) Video&Written
4 posts / 0 new
liquidretro
Last seen: 4 days 6 hours ago
Today I have Klarus’s new Deep Carry EDC light, the E2. This is the second light in the Klarus E series, and I reviewed the E1 last year. Make sure to check the description for a link to that review. This light is designed with EDC in mind to minimize the size of an 18650 light while providing a good amount of output and features. Thanks to Klarus for sending this to me to take a look before it’s widely available.
Watch this review on YouTube:
Follow me on Instagram: https://www.instagram.com/liquidretro/
Join the Facebook Page: https://www.facebook.com/LiquidretroReviews/
Packaging
Packaging is a nice white Retail box with a red hanging tab. It has a photo of the light on the front, with the model number prominently displayed.On the back and side there are stats about the light and a chart telling more specs.
Inside the package you get the following. The light itself, along with a Klarus 3600mAh 18650 battery, deep carry pocket clip, lanyard, extra o’ring, micro USB charging cable, and small gray felt bag.
Construction
The Klarus E2 is made from Aluminium and hard anodized a semi gloss black. It’s a nice fit and finish as recent Klarus lights have been. The tail and body are all the same as the E1 had. Starting at the tail cap, we have a dual switch design. The main switch is a larger round button that sits up somewhat proud, next to it is a paddle that acts and the secondary switch There is half a shroud built up around the larger button on the outside, to help it from getting pressed accidentally, and it’s the lanyard attachment point. This is nicely styled and works well from my experience but the downside is it’s not magnetic and it can’t tail stand.
Threads are anodized, acme cut, and fairly small. There are springs on both ends of the light, and a dual ring system in the head like we saw on the Klarus XT21X. The body section of the light has concentric rings milled into it which gives some grip but not a ton. The head of the light is one piece with the body, in fact the entire diameter of the light is the same. There are no buttons and only minimal labeling. In my example the laser engraved serial number is not straight. The clip fit’s up on the head, and does rotate around, it can be removed if you wish. Up near the very top there is a very small tricolor LED on the side of the light that’s used for a power indicator and when changing UI modes. The front of the light unscrews in theory, and under it is a plastic lens I believe. Under that is the reflector which is similar to a TIR style optic. As a result you can’t really see the LED underneath.
*Size & Weight *
I measured the length at 115mm, and the diameter at 23mm. Weight with the included battery and clip was 110g.
Comparisons
When compared to the E1 the E2 is 8mm longer, and the same diameter. For me for the lights I own, the Olight S2R II and S30R III, both being small 18650 lights with TIR style optics.. Diameter wise they are identical.
Retention
The light carries in my front pocket really nicely. It’s an incredibly deep pocket clip that can also be used to attach to the bill of a hat to use as a makeshift headlamp in a pinch. Being a head up carry, it does require you to flip the light around in your hand to turn it on without having a side switch. I found this a little awkward and I think I prefer a side switch for this reason on this style of light but it was a minor complaint. The slim diameter, relative shortness, and deep carry pocket clip make for a comfortable EDC in my testing.
LED & Beamshot
The Klarus E2 receives an upgraded LED and outputs from the E1. It’s using a Cree XHP35 HI LED in cool white. No tint data is given but it’s not crazy cool. The beam here is nice out of the TIR style flat optic, you get a hot center thats a majority of the light with minimal diffused spill and it throws further then you think with Klarus quoting 190 meters of 9025 candela.
  • High 1600 lumens
  • Medium 400 lumens
  • Low 100 lumens
  • Moon 8 lumens
  • Strobe 1600 lumens
  • SOS 60 Lumens
Runtime & Heat
For my Runtime and heat tests I used the included Klarus branded 3600mAh battery. The lights high output of 1600 lumens began stepping down from the moment it came on and it was down to 46% of relative output at 1:10. This is an a much faster decline then I expected. The light does have some active thermal management and the light increased slowly over the next 4 minutes to 62% relative output before decreasing again around the 8:30 mark down to the 46% relative output. From here it sat pretty flat out to 10% relative output at 2:40:00 mark. Just before LVP kicked in on the light at the near 8 hour mark it did gain in brightness the last 20 minutes by 6 relative percent. You notice heat quickly on this light in high mode, the hottest I saw was 51.9C at the 45 second mark.
UI
UI on this light is the exact same as the E1 and controlled all with the switches in the tail cap of the light. Like other recent Klarus lights, there are 2 UI modes on this light. Factory default mode is Outdoor Mode, which I found to work for EDC pretty well.
You have a paddle switch that starts allowing the light to work on low either in momentary if just clicked briefly or if you click and hold for about 1 second it will stay on. Once in the on position this paddle can be used to step through the lights 4 main modes in increasing order. 8LM, 100LM, 400LM, 1600LM.
Also on the tail cap is a larger round mechanical switch that will give you instant access to turbo. You can half press this for momentary or full press to lock on. Once the light is on you can use the paddle to cycle between modes.
To switch modes when the light is off, press and hold the paddle for 5 seconds and the battery indicator on the front side of the light will begin flashing red/green. Then click the large primary switch without releasing the paddle.
The second mode is a tactical setting where the primary button turns the light on to high, then use the paddle to change modes, and in tactical the light goes from high and decreases in brightness to medium (400 lumens), Low (100 Lumens), and then Moonlight (8 Lumens). To enter the strobe while the light is on, hold the paddle for 2 seconds. When the light is off, pressing the paddle will give you direct access to the strobe.
Lockout in either mode can be accomplished via unscrewing the tail slightly to reset.
Recharging
The Klarus E1 again uses a proprietary battery here, where both the positive and negative terminals are on the traditionally positive end of the battery. The positive terminal has a plastic spacer around it that sticks out a bit. A normal flat top battery will work in the light with a magnet spacer but you will lose the recharging feature of the light. The light uses MicroUSB for recharging which is disappointing in mid 2020.
Speaking of recharging I charged the light from LVP at 2.86V to full at 4.18V in a total of 4 hours and 25 minutes. Charge speed was around and ranged from 0.66A to right at 1A. Definitely on the slower side but safe. What I didn’t like was the light’s LED indicator on the side changed from red (charging) to green (Charged) before the light was completely full. I got the full indicator an hour before the light actually stopped using current and I tested the battery here at 4V. It would be good to see the light actually go green when it was done charging instead of being almost done.
Pro
  • Good factory deep carry clip, but it only allows for tip up carry and it rotates a bit to easily.
  • Good fit and finish, it’s a good looking production light.
  • 2 UI modes for users to pick from.
Con
  • Minimal change from the Klarus E1
  • Proprietary battery, this time it’s larger capacity at least.
  • Doesn’t tail stand, or is magnetic, because of the dual button configuration on the tail cap.
  • Wasn’t a fan of taking it out of my pocket and having to change grip to turn it on.
  • Moonlight mode here is brighter at 8 lumens than the E1 which isn’t moonlight at all.
Conclusion
The Klarus E2 looks familiar because it is largely the E1 that’s slightly longer, with a different LED to produce more output (still in cool white only) and comes with the battery the larger capacity E1 should have shipped with originally.
I like it’s size for an 18650 light, it’s short, and about as narrow as possible. It has a pretty good UI and I love that it has the optional Outdoors mode or Tactical mode. The light isn’t perfect though, I found in my daily IT work I missed the ability to tail stand and a magnetic tail cap, and I didn’t love having to rotate the light in my hand when pulling it out of my pocket to use it. Moonlight mode is too bright here at 8 lumens, and it steps down super fast from it’s highest output. It’s good to see they went with the larger capacity battery here vs the E1. I hope before the light ships they revise the firmware to let the green charged light come on at closer to 4.2v vs the 4.0v it comes on in my example.
MSRP at a few retailers who are listing the light for sale now at the time of this video is about $70 which is a little on the steep side with the competition and a big step up from the E1. A drop in price would make the light more competitive. If you liked the E1 you will like the E2 as it’s basically the exact same light with a brighter LED and higher capacity battery that’s just slightly longer overall.
Full Image Gallery https://imgur.com/a/6eku23l
LumenMax
LumenMax's picture
Last seen: 3 hours 21 min ago
Nice reviews.
Tail-stand fans...could you tell me what's the appeal in tail standing? I rest my non-tail-standing flashlights on their heads.
MascaratumB
MascaratumB's picture
Last seen: 6 hours 20 min ago
LumenMax wrote:
Nice reviews.
Tail-stand fans…could you tell me what’s the appeal in tail standing? I rest my non-tail-standing flashlights on their heads.
I’ve commented this on liquidtretro’s YT channel and I’ll say it again!
First, thanks for the nice review of the flashlight! Thumbs Up Thumbs Up
Second, I guess Klarus could have improved this flashlight (starting from the E1) much more:
- battery: again, they use a proprietary, and…maybe they could have used “normal” batteries (without the need of a spacer!)
- heat management: as shown, the flashlight could have better thermal management…
- recharging: they could have implemented USB-C
- led vs optic: using an XHP35 HI (a throwy led) under that optic for a floody beam, seems a bit Facepalm
- clip: that clip on the head and non-reversible, is just a “no” for a supposedly tactical flashlight
I do like the shape of the flashlight, I like that “paddle” (it is probably better than the one in th XT1C), I honestly don’t care that much about tailstanding. I do think they could have improved much more since the E1.
Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
liquidretro
LumenMax wrote:
Nice reviews.
I use it to bounce light up off something (under a desk, etc) for hands free mode. Putting something in my mouth when I need both hands isn’t the best of ideas in a pandemic or in all work environments.
For me the bigger issue with this is being a tip up carry and only have buttons on the tail you have to flip it around in your hand when drawing from your pocket to turn it on.
MascaratumB wrote:
LumenMax wrote:
Nice reviews.
Thumbs Up
Thanks!
