5k lumen lights: Sofirn BLF SP36 vs. Astrolux MF01 Mini
14 posts / 0 new
river345
Last seen: 2 hours 18 min ago
Both of these are now in the ~$50 range, and I’m wondering what people think of them. Both are USB-C rechargeable. Of particular interest for me, the Astrolux MF01 mini can use a single 26650 down to 18650 battery. The Sofirn SP36 uses three 18650 cells.
It seems like the Sofirn battery requirements are more complicated because it uses three cells? They recommend protected cells. Is it because when using three 18650’s, they aren’t using the cells independently, so they need to be well balanced? And when charging, it’s not charging the cells independent, so it can’t prevent over charging if the cells are not well balanced? Multi-18650 setups are kinda confusing and I’m concerned I don’t know how to use them safety.
The Astrolux can draw like 15A on turbo. So you just need a battery that’s capable of 15A continuous draw. With the Sofirn, are the 3 cells in parallel the turbo amp draw can be divided by three to figure out the max continuous current draw capability of the battery? I’m assuming the batteries are in parallel.
Edited by: river345 on 07/28/2020 - 11:58
MoreLumens
MoreLumens's picture
Last seen: 4 min 39 sec ago
I got both of those. Mini 4000k and SP36 5000k and I still cant decide which tint I prefer. SP36 is a bit throwier, little heavier, good size in hand. Mini on the other hand is a bit lighter, lovely aux-leds, really nice body colors and more convenient size to edc. Both are great in outdoor/indoor use and overall really impressive lights. Both get really warm and can sustain pretty good lumens.
Really loving these. Got both just because I joined BLF and what the eye sees, the brain wants. Silly
Serlite
Last seen: 5 hours 39 min ago
The cells that the SP36 normally comes with aren’t protected cells – the only crucial detail is that they have to be button-top cells.
I wonder if you saw that recommendation because protected cells are always button-top, since I haven’t heard much about the SP36 over-charging/discharging cells.
zoulas
Last seen: 19 hours 12 min ago
Both nice lights but I don’t think its fair to compare the two.
Rat_Racer
Rat_Racer's picture
Last seen: 13 hours 16 min ago
I have the BLF SP36, and the mini’s sister light, FireFly E07.
The MF01 mini is a fun OMG light, being a more pocket friendly wall of light flood, with TIR optics and cool aux lights.
The BLF SP36 with Anduril and high CRI Samsung LH351D, is a beer can light that is mid flood/mid throw compromise. There is also the BLF SP36 with Narsil, and the SP 36S, with a simple 4 mode UI.
Rexlion
Last seen: 1 day 9 hours ago
The SP36 will run on a single 18650 if needed, can’t it? The 3 cells are run in parallel so the voltage remains the same whether you have 1, 2, or 3 cells, right?
vietnamreviews
Last seen: 2 hours 53 min ago
I will choose Astrolux MF01 Mini Copper (XPL HI) its price is very good for only 45.06 $ (including shipping insurance)
http://budgetlightforum.com/node/73740
river345
Oh, I didn’t consider that. I didn’t see that mentioned in the reviews whether it can optionally run one 1, 2 or all 3 batteries. Maybe someone who has the SP36 can chime in.
Scallywag
Scallywag's picture
Last seen: 5 hours 14 min ago
Any of the soda-can lights that use cells in parallel can do this. The lights that can’t use cell carriers instead and some amount of series – I think a lot of the Astrolux lights are 2S2P, in which case you could use two or four cells (if you get the right two).
I checked a review for pics (this one, first Google result) and the SP36 uses 3P, so it will run on 1, 2, or 3 cells. You’ll probably lose top-end output and of course you’ll lose runtime on fewer than three cells, but there’s no reason it won’t work.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Lightbringer
Lightbringer's picture
Last seen: 1 hour 46 min ago
Unless you melt the spring. LOL
cleo_stary
cleo_stary's picture
Last seen: 2 days 36 min ago
They look good, I like MINI and EDC flashlight, especially pen-light.
d_t_a
Last seen: 1 hour 52 min ago
I've done beamshot comparisons of the SP36 with the MF01-Mini
(pardon the videos quality, sometimes the camera starts out de-focused (likely due to me starting the camera rolling with no light and the camera doesn't know what to focus), but will focus better after more light)
1) Left side:  Sofirn SP36 BLF Anduril (4x Samsung LH351D 5000k)  vs
  Right side:  Astrolux MF01-Mini (7x SST20 5000k)
2) Left:  Astrolux MF01-Mini (7x XPL-Hi 5000k)  vs
Right: Sofirn SP36 (4x XP-L2)
  (note: this is a more special version of MF01-Mini that uses XPL-Hi instead of the regular SST20 LEDs; also the SP36 here uses different LEDs than the one in the video above)
river345
d_t_a wrote:
I’ve done beamshot comparisons of the SP36 with the MF01-Mini
That was really helpful, thank you. I think the MF01-Mini with the 5000k XPL-Hi that you used in the second video is the same one I’m looking to buy – copper head with aluminum body? To my eyes, the Samsung LH351D looked good for tint, but XPL-Hi 5000k looks really good too. On BangGood, the LED options for MF01 mini’s XPL HI are “1A” or “3B”. Is the 5000K XPL-HI you have equivalent to the “3B” option?
MF01 Mini
d_t_a
MF01 Mini
Yes, it’s called the XPL-Hi 5000k is the XPL-Hi “3B” tint.
On Mateminco’s website (AliExpress), you can purchase the MT07 all-aluminum (not copper+aluminum) with XPL-Hi 5000k option. (MT07 is the same flashlight as MF01-Mini). It’s a bit cheaper (due to not having a copper head) and also lighter in weight. Although depending on your area, it may be more difficult to order from AliExpress.
Banggood only has XPL-Hi on the MF01-Mini Cu+Al version, but XPL-Hi doesn’t appears as an option in the regular aluminum MF01-Mini.
