[Interest Check] Sofirn SP10R - deep red AA/14500 EDC
137 posts / 0 new
caramba
caramba's picture
Last seen: 23 hours 33 min ago
Interested in 2
TimMc
TimMc's picture
Last seen: 1 hour 6 min ago
SP10S appears to single click to Low and then cycles through Low, Med, High, Eco, Low.
I hope that the SP10R UI is different. E.g. Hold to access firefly. Single click through each mode in a uniform manner (Low, Med, High, Med, Low, Firefly, Low, Med, High…).
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 57 min ago
TimMc wrote:
SP10S appears to single click to Low and then cycles through Low, Med, High, Eco, Low. I hope that the SP10R UI is different. E.g. Hold to access firefly. Single click through each mode in a uniform manner (Low, Med, High, Med, Low, Firefly, Low, Med, High...).
Nope...
The UI is drafted like this:
Hold from OFF ► firefly mode (~0.2lm)
1 click ► ON/OFF
Hold from ON ► Cycle modes low-medium-high (no mode memory from OFF)
2 clicks from ON/OFF ► Turbo ► 1 click to turn OFF / 2 clicks to return to previous mode
4 clicks from OFF ► electronic lockout (on/off)
It is set that there will be no strobe modes at all.
Luminous and wired, we'll be glowing in the dark.
Lightbringer
Lightbringer's picture
Last seen: 35 min 49 sec ago
Like.
SwissFlashy
Last seen: 1 day 8 hours ago
I am interested in 2! Let’s make it happen!
matik42
Last seen: 6 days 10 hours ago
All depends, but right now interested in one.
Blggg
Last seen: 3 min 2 sec ago
What is the status of the project, Lux? I have already got the C01R, but I find it running out of battery too quickly for my use (mostly as a bulb at night).
Lux-Perpetua
I don't have any status update yet. Sofirn's factory is currently quite busy, so there might be some delay in rigging up a prototype of SP10R. I will keep you updated as soon as I get any news.
lamppu
Last seen: 4 days 17 hours ago
Interested.
Blggg
Lux-Perpetua wrote:
I don’t have any status update yet. Sofirn’s factory is currently quite busy, so there might be some delay in rigging up a prototype of SP10R. I will keep you updated as soon as I get any news.
Thank you very much.
skinny_tie
skinny_tie's picture
Last seen: 23 min 42 sec ago
With the UI described I’m in, and I would take one with a white emitter too.
Jonnor
Last seen: 10 hours 20 min ago
I would also like one with a white emitter with this UI, do you think this UI will be available on all the SP10X?
Lux-Perpetua
I must admit, I have no idea about Sofirn's plans for the next generation of AA / AAA lights. It could be that they will introduce a whole new line up of lights or focus on improving the details only. What I can tell so far is that I collected as much (negative) feedback about SP10S as I could find and tried to eradicate any downsides with the concept of SP10R. These improvement suggestions can be found in the OP of this thread.
As soon as Lexel and Sofirn have finished the SP10S Andúril dual chemistry boost driver, there might be a nice option for those looking for a better SP10S with white light.
Sean Ingram
Sean Ingram's picture
Last seen: 2 weeks 9 hours ago
Lux-Perpetua wrote:
Sean Ingram wrote:
Can I assume it’ll be significantly brighter with lithiums like the other one?  […]
That’s yet to find out but I expect a truly visible difference between SP10R and C01R on full power. While Sofirn applied a bit more than 1A on C01R’s XP-E2 photo red (on high mode), SST20-DR can possibly driven with 2A (or even more) on full power. In the end, the thermal design of the SP10S host will have a significant impact how far Sofirn can push the limits. As much as I love hotrod lights that can burn your skin (at own risk), there will need to be a reasonable balance between shorting the lifespan of the LED, having a safe maximum temperature and draining the battery.
Ah I see; Thanks for the info. You can put me in as interested.
And thanks for your continued diligence in working with Sofirn to refine and improve these lights for the BLF community.
WalkIntoTheLight
Last seen: 3 weeks 5 days ago
Interested in 1.
DaveyC
Last seen: 2 days 9 hours ago
Interested
james0tucson
Last seen: 3 weeks 10 hours ago
Hi, I’m very new to the flashlight community and this is my first post here.
I discovered this forum after making my first flashlight order.
The C10R is the flashlight that drew my attention in the first place, and was the first thing I ordered!
I added on that order an SP36 and an SP31, and I also bought an FC11 from a different vendor.
Have no doubt that I will want to add a SP10R to my collection, and will likely want several of them if the bodies have a choice of color finishes.
Please add me to this list if I’m not too late to the party!
james0tucson
TimMc wrote:
I doubt I’d use SOS and strobe modes.
Different blink intervals and intensities may be useful when using this red light with a diffuser as a Rear Light on a bicycle. Too complicated?
This is one of the main use cases that brings me to the flashlight community in the first place.
I’m sick and tired of bike lights that have such opinionated modes.
I’m hoping to find good devices that work well as a bike headlight (considering mounting options as well as all the light characteristics), helmet light, and tail light, while also being useful for general purpose applications.
I can’t count the times my bike headlights have been pressed into service as flashlights, and I can’t count the times I’ve been embarrassed as my flashlight goes into lightning strobe mode or some crazy thing. That’s a feature that literally no one has ever asked for, right?
adam7027
Last seen: 9 hours 12 min ago
Interested! (2pcs)
Eventually I skipped purchasing C01R, as I saw this version coming into consideration, which is much better for my needs.
Thank you for arranging this.
Sari33
Last seen: 2 hours 1 min ago
Lux-Perpetua wrote:
I must admit, I have no idea about Sofirn’s plans for the next generation of AA / AAA lights. It could be that they will introduce a whole new line up of lights or focus on improving the details only. What I can tell so far is that I collected as much (negative) feedback about SP10S as I could find and tried to eradicate any downsides with the concept of SP10R. These improvement suggestions can be found in the OP of this thread.
Would be appreciable if you tell him to change the rought knurling of their lights on smooth
Sillen
Sillen's picture
Last seen: 4 min 41 sec ago
Interested. Got C01R on the way but good to get something bigger.
Gr8Scott
Last seen: 6 days 5 hours ago
I’d be interested in one or two of these.
rost333
rost333's picture
Last seen: 15 hours 17 min ago
Interested in 2.
Kona G
Last seen: 5 hours 24 min ago
Please count me in for one
Sirius9
Sirius9's picture
Last seen: 1 day 9 hours ago
Hi, just glimpse over the first post, did not find price! Let me know.
I like red leds, although they are completely useless to me but I like them Facepalm Big Smile
Theodore41
Last seen: 1 hour 54 min ago
what is the price?I ask,because if it is over 22.00€,I will pay some 20.00€ more,for taxes and fees,if it is not delivered through BG.
caramba
caramba's picture
Sirius9 wrote:
Hi, just glimpse over the first post, did not find price! Let me know. I like red leds, although they are completely useless to me but I like them Facepalm Big Smile
No worries, You don’t need to commit.
They didn’t even think about the price This is just an “Interest check”. So feel free to say “Yes” it will help Lux and Sofirn to start taking the project to the next level and maybe even lower the average cost/price per piece.
M78
Last seen: 34 min 56 sec ago
Interested
amplificus
amplificus's picture
Last seen: 2 days 3 hours ago
Interested. Why not Anduril UI?
Lux-Perpetua
caramba wrote:
Sirius9 wrote:
Hi, just glimpse over the first post, did not find price! Let me know. I like red leds, although they are completely useless to me but I like them Facepalm :D
No worries, You don't need to commit. They didn't even think about the price This is just an "Interest check". So feel free to say "Yes" it will help Lux and Sofirn to start taking the project to the next level and maybe even lower the average cost/price per piece.
Thanks caramba.  Beer
