Got these bad boys out of a new power bank - tips on how to remove tabs?
15 posts / 0 new
YYesZir
YYesZir's picture
Last seen: 4 days 22 hours ago
I’m new here so still working out how to post pics correctly. Anyways is there a way to remove these tabs or is it better to solder over them? These are brand news LG’s that are doing nothing so I may as well try to use them if I’m able to.
YYesZir
YYesZir's picture
Been told they have CDR of 5A. Not really any good.
YuvalS
YuvalS's picture
Last seen: 2 hours 16 min ago
I used to do it with Dremel with sanding or cutting head but then realized there is no point in doing it and there is no problem use the cells like that
When you get more experienced you will remove the tabs entirely without leftovers Smile
RobertB
RobertB's picture
Last seen: 1 day 8 hours ago
They are pretty good cells. They run well in a Convoy S2+ or other lower draw lights. I run 3 in parallel in a Fireflies ROT66. Just sand down the sharp edges and run with them
Silent_Star
Silent_Star's picture
Last seen: 2 weeks 2 days ago
I did it with Dremel.
 Genesis 1:3 "And God said, "Let there be light,"  and there was light."
2A
Last seen: 33 min 10 sec ago
I normally leave the tabs on, never had any issues with it. In rare cases I put a blob of solder on top to make it more smooth.
will34
will34's picture
Last seen: 1 hour 35 min ago
Are these from a xiaomi powerbank? Then they work well at up to 1C, but not recommended for anything above.
Sirstinky
Last seen: 7 min 45 sec ago
I leave them on. Unless you run into clearance issues with or just want them to look nice you can use flush cutters or the Dremel to pry o rd cut them off.
Robin Dobbie
Last seen: 1 hour 14 min ago
There’s a nickel or some kind of plating on the cells to keep them from rusting. Sanding that will encourage oxidation.
I haven’t opened too many batteries, but my first one looked like OP’s with the massive tabs. But it’s fine, though. It’s just nickel and the thickness isn’t going to be a problem.
I just opened a different pack. I was careful to tear the tabs off as cleanly as I could. I don’t know if I could have done better?
When I was done, I used a screwdriver shaft to burnish the welds so they’re not rough. One I idea is to make a mini burnisher so the factory wraps don’t get stressed in the process.
Skylight
Skylight's picture
Last seen: 1 hour 50 min ago
I use this kind of cutting pliers: https://www.aliexpress.com/item/32945829748.html
You can cut things very flat with them. They are a bit sensitive and break off easily if you cut too thick wires.
wle
wle's picture
Last seen: 19 hours 53 min ago
flat file
dremel
grinding wheel
the metal is not hard, it is a quick job even with a file.
30 sec each
2 on a grinder :”)
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Sirstinky
I’ve broken at least 3 pairs of these in the last 2 years from being too physical with them. On soft metals up to 3mm they work great though.
Sirstinky
Be super careful with filing or sanding. You risk damaging the wrap near the positive end and expose the bare can. Touching the positive end and that bare spot causes a short which is bad. Ask me how I know!
Barkuti
Barkuti's picture
Last seen: 1 hour 4 min ago
Some grinding stone(s) with the proper geometric shape, a rotary tool, and subtlety with a little skill is all you need to leave those cells very nice:
Something like the above, for example (site link).
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Robin Dobbie
I guess if I was going to take a rotary to a cell it would be with one of those silicone carbide grinding stones Barkuti is showing. Then the goal would be to touch only the welds and nothing more.
I’ve actually sanded cells before and had one of them visibly rust, afterwards. More of them just didn’t work from time to time unless I sanded them immediately before use.
Once you get rid of the nickel, you never know when you’ll have to sand them again before they’ll work. Just my experience.
