Bought some 14500 batteries for the first time and charged them up then went to use them in my Tool AA 2.0. First thing I noticed with my Vapcell P1418A 1800mah (protected) is it’s slightly shorter than the Vapcell 14500 Gold 1000mah, I figured the protected one would be slightly longer as it also has built in USB charging. Anyway, the protected one fits just fine; however the built in light on the tailcap does NOT turn on with it and any mode higher than low produces massive flickering. With the non-protected gold one, the light in the tailcap turns on and there’s no noticeable flickering on any modes.
The tail cap screws in completely with both.
Is this normal or an issue with the battery/flashlight?
Hi, P1418A has the output voltage 1.5 meaning it has buck converter built in the battery. It’s different type of battery, this why it’s shorter. It won’t light up the tailcap, because only 3.7V li-ions can do that.
Regarding the Vapcell P1418A, I also bought 1 to test out 1.5v Li-Ion AA (it’s my first 1.5v Li-Ion AA battery).
I’ve been trying this 1.5v Li-Ion AA battery in a few AA/14500 flashlights, and notice that for flashlights that use something like more than 2 Amps, the protection on the P1418A battery appears to shut off power. (At first, I was wondering what could be the reason, so I checked tailcap currents of the various flashlights when using the P1418A).
From what I understand, the Tool AA 2.0 uses like direct-drive, so it may be pushing the limit of the P1418A’s protection circuitry, and thus causing the flickering.
I don’t have a Tool AA 2.0 with lighted tailcap (I think that’s the Ti version?), but testing the Vapcell P1418A on a regular Tool AA 2.0 (the one I tested uses XPL-HD, some later Tool AA 2.0 use XP-L2, which may gobble up more power), I notice that when I set to highest brightness level (tailcap current measures around 2.3-2.4Amps), the light will stay on that max brightness level for several seconds only, then the light shuts off and goes to Low.
I wonder if the light-up tailcap is available for sale as a stand-alone item… Would like to try one, since I already have several Tool AA 2.0 (one with XPL-HD, another with XP-L2, and another with Nichia 219C, but none of them have light-up tailcaps…)
I recall reading about “high parasitic drain” (or some similar issue) with the ‘lighted tailcap’ on the Tool AA 2.0 Titanium — would there be a similar issue with this lighted tailcap on the Tool AA 2.0 (regular aluminum version)?
I have two Tool AA, and 1) they flash like that when the battery gets low and 2) I use 14500 protected button top batteries with no problems.
Yours sounds like a bad battery.
As a side note: I like the led tail cap. In a completely dark environment, I have found the light several times. However, I’d still prefer a tritium tube on a magnetic tail, and use it as a twisty. I have had many rubber tailcaps deteriorate and fail through the years. I have already purchased a pair of magnetic tail caps for WHEN these fail.
