Test/review of Samsung INR21700-50G 5000mAh (Green)
19 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 30 min ago
DSC_3798
Official specifications:
  • Capacity: 5000mAh
Samsung%20INR21700-50G%205000mAh%20(Green)-info
Samsung high capacity 21700 cells
DSC_3797
DSC_3799 DSC_3800
DSC_3801
DSC_3802
Samsung%20INR21700-50G%205000mAh%20(Green)-Capacity
The two cells tracks perfectly, they handle 15A nicely. It looks like they must be drained fairly low to get full capacity.
Samsung%20INR21700-50G%205000mAh%20(Green)-Temp-10.0
Samsung%20INR21700-50G%205000mAh%20(Green)-Temp-15.0
They may handle 15A nicely, but they do get rather warm doing it.
Samsung%20INR21700-50G%205000mAh%20(Green)-CapacityTimeHours
Samsung%20INR21700-50G%205000mAh%20(Green)-Energy
Samsung%20INR21700-50G%205000mAh%20(Green)-PowerLoadTime
Samsung%20INR21700-50G%205000mAh%20(Green)-TripCurrent
Samsung%20INR21700-50G%205000mAh%20(Green)-Charge
Discharge-Samsung%20INR21700-50G%205000mAh%20%28Green%29-pulse-1.0%2010%2010-IR
Conclusion
The batteries looks good with lot of capacity and are fairly good at delivering current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
thefreeman
Last seen: 41 min 21 sec ago
Thank you for the review.
stephenk
stephenk's picture
Last seen: 7 hours 45 min ago
Thank you again for the review!
SubLGT
Last seen: 5 hours 10 min ago
Interesting to see that the positive contact is not as deeply recessed as on the Vapcell G50.
http://budgetlightforum.com/node/73535
Superstocker
Superstocker's picture
Last seen: 4 hours 8 min ago
Thanks HKJ! Do you have plans to test the Molicel M50a? I’m curious to see how it compares to this. Thanks for all your work testing.
hasddie293
hasddie293's picture
Last seen: 2 hours 48 min ago
I’m really appreciated works done by HKJ, tq.
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
powerslave
Last seen: 8 hours 21 min ago
Thank you for the review!
SubLGT
Mooch tested the M50A
Molicel Test
Quote:
…This Molicel performed well, beating the Samsung 50E, but not quite matching the performance of the Samsung 50G (which Vapcell rewraps as the G50). For comparison, the Samsung 50E delivered 10.3Wh of energy at 10A, the Molicel M50A delivered 11.3Wh, and the Samsung 50G delivered 12.2Wh. This Molicel’s 15A continuous current rating seems reasonable but I recommend staying at 10A or lower to increase efficiency and cycle life.
The capacity of the two cells I tested was 4968mAh and 4998mAh, easily meeting Molicel’s minimum capacity spec of 4800mAh….
Henk4U2
Henk4U2's picture
Last seen: 2 min 57 sec ago
My first thought was: wasn’t this tested before.
Then I noticed that was the 50E, and this is the 50G.
Many thanks for all your testing.
I never buy anything without looking first if you have tested it. Grad
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Superstocker
Molicel Test
Thanks for sharing! I was hoping the Molicels would be slightly better. Looks like they might be slightly better for high drain applications over 10A. Thanks again!
SKV89
Last seen: 2 hours 29 min ago
I’m wondering why this does not have a recessed top like the Vapcell 50G
vapcell Dennis
vapcell Dennis's picture
Last seen: 3 hours 33 min ago
Thank you very much for HKJ’s test
But I have a question
we compared the vapcell G50 with the Samsung 50g, which is the same cell
Curve comparison also shows that
But vapcell G50 was cut off immediately during 15A discharge. Was the temperature too high to prevent the discharge? Why does the same cell have this difference
thank you
HKJ
HKJ's picture
It was a temperature cut-off, but exactly why it happen to the Vapcell and not the Samsung I cannot explain.
I can see the ambient temperature is about 1°C cooler for the Samsung, that is hardly enough to explain it. Other reasons can be different placement of temperature sensor and different connection resistance (Higher resistance would produce more heat).
Havok
Last seen: 1 week 1 day ago
Same thing with my Epoch 21700. Recessed top. It says 50G on the can after I removed the label.
Mine are stamped: 2J23 => Feb 03, 2019
HKJ has 2J84 => Aug 04, 2019
Maybe they made a revision, and we have V1?
***Edit***
Just noticed on HKJs’.. it has a 2 on it before the date code “2 [space] 2J84”
Maybe that means 50G Revision 2. Just like how new Samsung 30Q’s have a 6 on ‘em. “6 [space] KH1T”. Revision 6 of the 30Q?
Just a theory.
d_t_a
Last seen: 19 hours 19 min ago
The Vapcell G50 I got don’t look recessed either.. could it be there are a few different variations of the Samsung 50G, one variant having a top that’s more recessed and another that isn’t that recessed?
Caleb
Caleb's picture
Last seen: 6 hours 22 min ago
Does anyone know where to buy the a Samsung 50G?
Agro
Agro's picture
Last seen: 2 min 2 sec ago
It’s interesting to see how close are the discharge curve shapes for 48G, 50E and 50G.
vapcell Dennis
For the same cell, the positive pole is slightly concave, but it is not obvious
Samsung cell is a big international brand, all of which are consistent in appearance
Unless Samsung is customized for some big companies
vapcell Dennis
we have some 50G, liionwholesale have vapcell G50,it is samsung 50G
