++ Nice box, feels high quality, square threads (though fairly small), nice finish, good knurling, no machine marks, stainless bezel, slide resistance is just right, boxed w/ 1TF flame, ~18mm slide travel
-- tail cap has some uncomfortable corners when operating switch, plastic lens (but higher quality than any others I have), PCB isn't screwed down (but is huge and has thermal grease), pill needs mass (but I haven't seen a screw in I didn't think that about lol), unknown (to me) charger, purplish tint, purists will want to paint the white pcb cover (i generally like all the light i can get)
high quality 18650 at 4.11V --> 2.3A, 1A, .2A, strobe and SOS. driver has last mode memory.
When I get some snap ring pliers I will add pics of the pill. There are tiny holes in the PCB for accessing the holes in the pill and my skinniest needle nose don't fit.
Overall - I'm giddy over this light. The tail cap feel, lack of a solid pcb retainer are the only parts I don't like. I'll fix the tail cap tonight (and find out how hard, or not, the anodizing is lol). If I swap the emitter to a better tint I will tap the existing holes and screw the emitter down...
There's a black washer on the driver in the next photo, just for a size reference (measured in next photo)
Measurement is of pcb diameter...but it doesn't look like it because the calipers are 1/4" above pcb in photo.
triple conversion anyone?! maybe after i stick a massive chunk of copper rod inside the pill
Z6 - sk68 clone w/ li-ion - C10 zoomie
same shot, same settings, 20 seconds later - obvious heat sag in z6
