Ended up inserting the battery in backwards in my eastward YJ06) now the light operates as a single mode direct drive light..Wondering if someone could tell me what driver (link) I need and how to remove the old one...Is the driver pressed in??? By the way this light is a great torch it's never really talked about on the forum, I find it to be a majorly underrated light, as it has great build quality and is a lot bright than other more talked about lights on this forum. Would really like to restore back to it's multi mode glory...Thanks for the help.
What is the diameter of the driver? And can you take it out so we can see the front of it? I'm not too familiar with the light, other than what I've seen on some forums.
Any idea what kind of amperage draw you were getting?
On the other side of the pill (remove the reflector) are holes for the leads to the LED. You can sometimes fit something down in the holes to help poke the driver out of position. But be aware that when that happens suddenly it can rip the wires from the LED or the driver. You might want to unsolder the leads from the LED before doing that.
okay I just measured it to b 18mm...I still have no idea how to remove the driver...it's in the same state as the pic above....is it pressed in??????I measure 18.02mm from the inside of the brass colored ring(pic above) thanks for the help
Okay I took brted advice above and pooped out the driver. This is what I found can anyone tell by the pic what driver this is and where I could get a replacement...or a similar driver that will work as well or better. I measured the driver to be 16.9mm. Thanks for all the help guys
The 7135*8 is perfect , regulated, modes at your disposal.
