Runtime, output, general expectations? How does it throw? How about battery life? A good match for the Olight M31? My friend has moved me to consider getting one.
XML is better than SST50. The Sky Ray SLT-V2 or FandyFire SLT-V6 (these two are the same flashlight) are the budget power choice. A little more cash can get you the Crelant 7G5. These two flashlights have quite a following on here. I have one of the FF V6 (modded with a 4A driver) and SR V2 and am pleased with both. With the exception of my modded light the XML run times will exceed the SST50 because it is a more efficient led. Brighter with less power = better emitter.
Oh yes, I have noticed how popular those are. I just figured driven twice as hard with large reflector would be appealing, but those are too long. I may give them a try, still, or try this one from manfont...
The downside to the mentioned single cell flashlights is less light. According to the links both are regulated to 2200ma vs 3000ma of the two cell flashlights listed in post #2.
The one SST-50 drop in I did have had a decent tint and was pretty much equal to an XML when both are driven to there limit. The only problem is SST-50 needs 5 amps to put out the same amount of light as an XML at 3 amps.
