● Output and Runtime of three constant output modes (uses one CR123A)
180 Lumens (1.5hrs) - 60 Lumens (10hrs) - 4 Lumens (70hrs)
Turbo Mode: 230 Lumens (uses one 16340 battery, do not run the light continuously at turbo mode for more than 10 minutes)
Two Hidden Modes: Strobe, SOS
● Digital Sensor Magnetic Control system, slightly twist the rotator ring to select from different modes
● Constant current circuit, constant output
● Working voltage: 0.9~4.2V
● Dimensions: 75mm (length) x 23.2mm (head diameter)
● Weight: 45.5g(battery excluded
● Tail stand capable- can be used as a candle
● Accessories: Clip, Holster, O-ring, lanyard
I love those but can't go to that battery size :( I want them to make a 1x18650 XML with magnetic control ring. I love the T40cs but i dont like the long skinny layout.
But SWM is the best built and most handsome light maker in my book.
