Hi guys, I'm trying to track down any other hosts where the p60 pill screws into the host like the Dereelight DBS or the Trustfire TE-R2/TF-R2 (http://www.manafont.com/product_info.php/trustfire-ter2-led-5mode-memory-led-flashlight-118650-p-5634)
Can anyone help? I'm not worried if you can't use the original p60 reflector.
Cheers
The light you linked is not a P60 host.
The P60 design does not screw into the light body. it simply drops into the body tube and is clamped down by the bezel as it is tightened.
While you are correct in that is how the p60's normally work, both the Dereelight DBS and that trustfire host will accept p60 pills. They screw into the body. https://budgetlightforum.com/t/-/1094#comment-17885
Edit: If you were referring to the CL1H then you were correct, I didn't realise it was just like a normal P60 host, as such I removed it from my examples.
