Yes, it's a cross post. It's warmer over here :)
Hi, and welcome to this edition of... My 2 Lumens. There will be plenty of more detailed and technically qualified reviews out there so this is only intended to be a super quick overview to temper my giddyness with a new light purchase :) Just remember these are my opinions and are subjective. The idea is to cut through the glossy photos and brochures to give you a simple laymans overview -- perhaps draw out some discussion.
If you want more technical details like "is it PWM, how many amps does it draw... etc" please see Selfbuilt or other long standing member reviews (coming). Sometimes I'll put the mA draw information on different modes if I want to know (or are asked).
Manufacturer's Link: http://www.xtarlight.com/en/05-chanpin/p-001-1.asp?styleid=195
Model: XTAR S1 - Production
Battery: XTAR (Sanyo) 2600mAH - 18700 size
Rated Lumens: 2350 (1h20m), 15 (500h)
SOS / Strobe: Yes
Multi Mode: Yes
Reflector: Smooth
Beam: Flower petal shaped beam pattern, lending to the tri-XML-U2 LEDs.
Finish: Smooth black HA III aluminum
Notable Features:
- 2350 rated lumens
- magnetic selector ring
- deep star anti-roll tail cap
- nice braided lanyard
- did I mention 2350 rated lumens?
- very nice white color (surprisingly)
Notable Changes from Prototype:
- lower rated lumens on high and low modes
- longer low runtime
- usable PAUSES during the preset ramping selection!
- sticker inside battery compartment indicating direciton/polarity
- some slight knurling/machining differences (see pictures)
- more "white" than "blue" light
- AR coated lens instead of clear glass
- detents are stronger at each mode. The ring overall feels "tighter" out of the box.
Quirks:
- I can't find any yet. Why? The massive reflector on is FLAWLESS. In contrast, a few of the Fenix TK70 have dust specks/bumps in the chrome. EDIT: Ok one quirk. The lanyard is much too thick to thread in the little holes provided for it. Time to break out the fishing wire to get it through...
I Like it Because: It's a very compact cloud spotter. Sure, the 80w HID baseball bat is better but that's a disgusting beam pattern. In PRESET mode, there are now very noticable "stops". The time for the flashlight ramping from low to high is about 23 sec instead of 7 sec (in the prototype), and have a 1 sec pause at 3%, 25%, 75% 98% output to make it easier to choose the mode you want.
I Dislike it Because: I don't know yet. I guess I wish it could have an even LOWER low mode. 15 lumens is super bright in the dark. If anything, I wish the selector ring isn't as much on an angle or if they added some sort of gripping to it. As in the previous reviews, the ring is difficult to change with gloves. Over simplistic packaging really downplays the light -- that can be a good or bad thing.
Comments: The bare light rings in about $225 CAD if you know where to look. The S1 kit comes with the awesome WP6-II charger and *SIX* XTAR (Sanyo) 2600mAH 18700 (yes 18700) batteries. Per XTAR, the 18700 format allows it to give the current hungry S1 the juice it wants on high mode. I'm not sure if that rings true or not. The kit runs about $270 CAD (coupon'd).
Other Technical Reviews: None yet for the production version. Let me know and I'll add it here.
Quick pics from iPhone:
^^ Production version on BOTTOM
Color Temperature:
Proto on LEFT
Production on RIGHT
Comment: When looking at them on at the same time, the prod version almost looks 4300k. By the way if you see donut holes in this pic, it's an optical illusion. Not so (or as bad) as the monitor is showing you.
For the driver board pics, back over to BLF: https://budgetlightforum.com/t/-/6031
NOTE: The S1 in that link is the Proto and not Prod version.
