Also is there any reason I shouldn't buy non-protected cells? They will be going in a jet beam BC40 and solarforce l2s and l2t. I though about some Xtars but I have 2 Trustfire flames and a cheap charger that came with them. The charger is actually quite good but the trustfires are very tight and the Xtars are longer. So instead of buying a new charger I thought I would get the Sanyos.
Good cells, with a little care no problem in multi cell lights IMO. The ones I have are my best matched cells. I'd sooner use these than *fire or some other rubbish, protected or not.
I use unprotected cells with my custom built 3 mode 2x18650 light with Kaidomains driver. They discharge parallel and I haven’t got any problems so far. To be safer, you can exchange the for and aft cells after a while. The cell closer to the head heats more and this my unbalance things.
Yes over discharge is the main issue, but even if you do take them too far you should only end up with scrap cells if you test when removing them. The main issue I believe is once recharging a cell that has been taken too low. Lots of chargers will not allow charging of an over discharged cell tho.
If they discharge in parallel, that’s same as single-cell cause reverse-charging is impossible in parallel usage. But in series usage nothing prevents cells from getting reverse-charged after getting emptied.
Does anybody know what the working voltage of the BC40 is? I have tried searching but all I can find is a review saying it is somewhere between 5 and 12v.
I know the drop-ins in my solarforce's work on 3 fresh eneloops but not 2, which means they wont run at 2.8v so that should be fine for an unprotected Sanyo.
Well, BC40 has a low voltage protection at 5 or 5.5v anyway. So even if a cell is discharged further than the other the circuit will never let the voltage go beyond the boundries of reverse charging.
Lets say the both cells start at 4.1v. Both should have the same start voltage, this is what the consensus says. But let's say the weaker cell has 10% less capacity. At the end of its capacity the other cell should have spent its 90% already. So it should be around 3.0v already. The other cell can still touch down to 2v for a few seconds but would recover fast as the light turns off. It's voltage is never meant to drop below 2.5v If both cells are well balanced from the start.
I'm Lang and the C,J&L are the kids first initials. I always want to make a cool user name but that one has been with me since Al Gore invented the internet.
OK, good stuff. I have just found a data sheet on the cells saying you must not go below 2.3v. So I don't imagine we will get that low. I think the BC40 only works on high with 6V. It would be go if Jetbeam would tell us.
