XM-L T6 - P60 drop in DIY
22 posts / 0 new
old4570
Last seen: 5 days 3 hours ago
OK got 2 XM-L T6 emitters from hong kong  , Ive thrown one into a P60 pill , and low and behold , I dont have enough pills , only enough for one build , damn ..
Also got some emitters from Cutter , 3 x T6 and one more T5 since the first one was so impressive ..
Back to the P60 - T6 ...  Using KD driver =  http://www.kaidomain.com/ProductDetails.aspx?ProductId=10995
And it pulls over 2A , I think I measured 2.3A  and 700+ Lumen ..
There is a much better hotspot with the P60 pill than with the A20 [ small reflector ] , but not quite as good as with say a XP-G R5 ...
Id say the XR-E Still rules for throw , I will put the other Chinese supplied T6 into my HS802 [ pencil beam thrower with XR-E ] , it currently has a MC-E in it [ 400+ Lumen ] , and see what happens ... [ That still leaves me with 3 more T6's and a T5 , but they will have to wait for some P60 parts ]
Back to the P60 ... Beamshots tonight ... Should throw better than the A20 and looks like the skies are clearing up [ better beamshots ]
Uploaded with [URL=http://imageshack.us]ImageShack.us[/URL]
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: Anonymous (not verified) on 08/23/2012 - 16:14
fran82
Last seen: 7 hours 31 min ago
I am anxious. So with wider reflector, more throw, and viceversa, less diameter reflector more flood?
This post/thread "may" contain referrals, a little contribution I "earn" in form of points ONLY if you buy the item. The purpose is to redeem items using the points and then making reviews of them in the forums to shar
Kokopelli
Kokopelli's picture
Last seen: 1 year 3 months ago
Planning to do the same with the same driver on the mail. But I ordered one T5 on 20mm star and a T6 on a 16mm circle board. P60 drop-in allows only 16mm and below, doesn't it?
I wonder if I should buy a set on 14mm boards from Cutter. I don't know if they really suit for every light I have. They may have useless beams on previously good throwers with XR-E's or could XR-G's be better for smaller lights up to 1000mA output, any thoughts?
old4570
P60 drop in handles 16mm and down ......  [ YES ]
Will test in a thrower shortly to see what happens ...  I put a MC-E into my HS-802 [ Nice , but the quad leaves a big X ] , and I will put in a XM-L T6 to see what happens .
http://www.makeagif.com/TFRbAP   Comparison gif ... BLF Y4E [ 14500 ] , A20 XM-L T5 , and my Solarforce L2x with the XM-L T6 [ from Hong Kong ]
old4570
Les dia ???  Shorter not so deep , not so wide [ Worked well with the XR-E though ] , I think someone is going to have to work on reflector angles etc to see about focusing the XM-L ...
26mm might not be enough , might need to go up to 40mm DIA to focus the beam , and create a hot spot ..  Wont be a P60 host any longer ..
Might need to try a smooth reflector ..
fran82
Results of "Solarforce L2x with the XM-L T6" incredible!
fran82
@old4570: how about heat and P60 dropins? It generates less heat than P7 of course, but.....
Kokopelli
Kokopelli's picture
...and which would be a better heatsinking P60 host? A Seraph copy, SF L2P or L2X, or other?
I were just thinking this whole p60 system was weak in everyway except modularity but I can change my mind easily. SolarForce bodies start appealing me Smile
Budgeteer
Budgeteer's picture
Last seen: 5 years 4 months ago
I have quite some p60 hosts . The best heat wise is the commonly called skyray, probably just because it has a greater surface even with a little less mass than a solarforce clone which is basicly identical. The worse but not very much would be an 501B by my experience. To back it up, it has slightly less mass and surface compared to others. But we are talking a few degrees here... Unfortunately i don't own (yet) a contactless thermometer but perhaps i'll get one some day.
kragmutt wrote:
They're gonna send you a green redcat with a black LED.
old4570
Not nearly as bad as SSC P7 / MC-E / or SST 50  ....
I.ll do a side bye side comparison ....
old4570
OK , after about 10 minutes , THE SAME !
Both lights have similar current draw , and the heat seems also about the same ...  So as far as heat ???
But your looking at 500 VS 700 at similar current levels ...  ...
I will make another gif ....
old4570
http://www.makeagif.com/Wmkn5K
Not a fair comparison , as the picture taken for the T6 was under much better conditions ...  Anyhow , SSC P7's VS T6 [ P60 ]
rzezniq
Last seen: 6 years 3 months ago
OLD4570 I really want to see that xm-l in hs-802! I can't wait for pictures!
Budgeteer
Budgeteer's picture
Me too me too!
old4570
Me too , hopefully will get it done tomorrow ....  I was impressed with it moded to MC-E , so hopefully it will be nice with the XM-L
So many projects , so little time , so close to Christmas .
Don
Don's picture
Last seen: 1 year 9 months ago
I want to see that one too - it might help me get around to doing something with my HS-802 which was very firmly glued indeed.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
old4570
I did the HS 802 , It has a nice beam , A tight hotspot and very bright spill ..
Output is around 530L , the hotspot runs about 15000Lux @ 1 meter ...
I thought the output down a little , but it is a different driver [ efficiency ? ]  Also didnt glue the emitter in place [ Thermal transfer ? ] though I used thermal paste
I will take some white wall shots .... [ beams tonight ]
old4570
http://www.makeagif.com/XL2px3   Didnt turn out nearly as nice as I would have liked  , Dark green outer ring is HS802 [ dont worry , effect is all the camera ]
But there is a nice small spot that stays small ...
Outdoors tonight ...
old4570
I tried a bunch of different reflectors and whilst they changed the beam a little , there was no real improvement to throw , 9000+ Lux @ 1meter [ T6 in P60 ]
Don
Don's picture
I was hoping that it would do a lot better than that. Ah well, maybe just stick an R2 back in mine and a 1400mA driver.
old4570
I would not worry about it too much , even if it cant throw a small dot 200+ Meters ...
When it was MC-E it was 450L and had a larger spot less bright spill but really impressed with the way it lit things up ...
I look forward to seeing how it goes , I think it might impress ...
old4570
http://budgetlightforum.cz.cc/node/1002  Some beams of the HS802 here , not the best place for throw , but you can see how the beam tightens up in the larger deeper reflector ...
