Does anyone have a good remedy for repairing corroded contacts from battery leakage? I've use the usual contact cleaner but, how about cleaning up the metal after the corrosion is removed?
tks
tks
Deoxit gold
^^^^^ What he said.
I like to apply a paste of baking soda and water to neutralize any remaining electrolyte, followed by WD-40 to remove any residual moisture, then a generous application of DeOxit Gold.
That stuff is quite pricey, so I try to use cheaper stuff to do the heavy lifting.
That's a good protocol. The bicarb works well.
If you use a lot of Deoxit, I've recently discovered in many cases you can substitute Sta-bil fuel additive. Potent anti-oxidant, lube and corrosion inhibitor that I suspect might be quite similar in composition to DeoxIT D100L, for a lot cheaper. ;) I do still use the Gold on certain applications though.
Electronic tool suppliers (and eBay) stock a thing called a 'fibreglass pencil'.
Its like a little fibreglass abrasive brush, inside a propelling pencil-like body, and its brilliant for cleaning metal contacts, PCBs etc - maybe it would help?
Caution:
Using a fibreglass brush creates little bits of fibreglass dust, which is an irritant and suspected carcinogen, so work over a paper napkin or something, and throw it out after use - don't blow the dust in the air to clean up!
Good Luck!
Pete
